#111
RK Henry writes:
Don't underestimate the capabilities of a trained, experienced crew to cope with equipment failure. Case in point, United flight 232 at Sioux City, Iowa. Despite complete hydraulic loss and concomitant loss of flight controls the crew was able to bring the aircraft to what turned out to be a survivable crash for most of the occupants. They were also flying an aircraft that did not have fly-by-wire systems. Fly-by-wire means that no command bypasses the computer. If the computer malfunctions, or if it decides to ignore your command, you're out of luck, and no amount of skill will help you. If flight 232 had been a fly-by-wire aircraft, everyone aboard would have died. The problem with fly-by-wire is that digital systems have typically catastrophic failure modes, which is the dark flip side of their superlative performance within the envelope. If flight remains within the envelope foreseen by the developers of the system (and assuming there are no bugs in the software), FBW aircraft fly better and more easily than non-FBW aircraft. However, if flight ventures outside the programmed envelope, failures in the system _will_ occur--and failures in digital systems are often catastrophic failures, because of the way digitization separates control from any constraining physical parameters. This issue is not limited to FBW aircraft, but it is much more critical in FBW because the results of a malfunction are usually fatal. Everything is different in more conventional aircraft. You might lose the hydraulic assist on control surfaces, but you can still move them to some extent, and they won't snap into implausible positions that exceed the physical limits of the system. As an example, if you have a purely analog throttle, if you push it beyond the maximum or below idle, the worst you're likely to get is no effect at all, i.e., you'll still have full throttle or idle, respectively. In a poorly-designed FADEC, however, your throttle will just be providing a number to a computer. If the computer has throttle settings from 00 to 99, and you push the throttle to a point that sends the internal computer setting beyond 99, it may roll over to 00, setting the engines abruptly to idle. Thus, the FBW throttle has a catastrophic failure mode that is completely absent in the conventional throttle. Add to that the fact that many FBW systems are not ergonomically designed and may have features that were conceived by engineers or project analysts rather than pilots, and you multiply the chances of problems. I think every FBW should have a button that says "do exactly what all the control inputs tell you to do," but many engineers apparently disagree, and most people (including some engineers) don't know enough about computers to realize the danger in this. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#112
Thomas Borchert writes:
BS! Point me to where the FBW does something the pilot doesn't. Habsheim. The pilot apparently put the throttles all the way forward, but the FADEC ignored this, because the aircraft was not in the right "mode." We don't know for sure because of tampering with the flight recorders, but this is one of several plausible scenarios. Normally, a pilot expects engines to spool up when he advances the throttle. But FBW systems do what they want, not what the pilot wants. In Habsheim, the pilot did something the plane wasn't designed nor able to do, namely extremely low flight in a wooded area. His last words were probably along the lines of "Hey, watch this!". I read the transcript, and those were not his last words, although I've forgotten what they were (and it's not certain that the published transcript actually reflects what was originally on the voice recorder). FBW had nothing to do with it. The accident report reflects this. FBW had everything to do with it. There were too many FBW systems aboard, and they were too complicated, and they worked in ways that were counterintuitive for an experienced pilot. When the pilot followed his instincts in an emergency situation, the FBW refused to follow. Yes. That reason is called "Boeing Marketing Department". The real reason why I prefer Boeing is the ten-day disappearance of those flight recorders. If the aircraft were so reliable, there would be no reason to sneak away with the hard data. Boeing has a long history of concern for safety and experience therewith that its main competitor does not share. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#113
On Thu, 28 Sep 2006 05:56:24 +0200, Mxsmanic
wrote: RK Henry writes: Don't underestimate the capabilities of a trained, experienced crew to cope with equipment failure. Case in point, United flight 232 at Sioux City, Iowa. Despite complete hydraulic loss and concomitant loss of flight controls the crew was able to bring the aircraft to what turned out to be a survivable crash for most of the occupants. They were also flying an aircraft that did not have fly-by-wire systems. Fly-by-wire means that no command bypasses the computer. If the computer malfunctions, or if it decides to ignore your command, you're out of luck, and no amount of skill will help you. If flight 232 had been a fly-by-wire aircraft, everyone aboard would have died. The similarity is that in both cases there's no hard connection between the control surfaces and the flight controls. The DC-10 had no cables between the controls and the flight surfaces, just pipes, so with no hydraulic power there was no control action at all. But the crew was left with control of the engines and that made it possible to control the airplane. My assertion is that there is insufficient evidence to conclude that everyone would have died had the airplane been FBW. Uncertainty remains as to that outcome. However, much as it may disturb some other, less tolerant, members of this group, I tend to agree with your qualms about FBW. FBW makes it possible to implement exotic airframe designs by defining their flight characteristics in software instead of in hardware. That's fine when the pilot sits in an ejection seat, but when this technology is extended to airplanes whose occupants don't have the option of pulling a handle when things go badly then we must be very careful. I'm sure the problems can be solved, probably with multiple redundancy, but a century of experience with aviation shows that we must always consider the possibility of failure. I've been similarly apprehensive about glass cockpits in light aircraft. A single point of failure in an inadequately designed and tested system could conceivably leave a pilot deaf, dumb, and blind. Show me the test plan. RK Henry |
#114
RK Henry writes:
The similarity is that in both cases there's no hard connection between the control surfaces and the flight controls. The DC-10 had no cables between the controls and the flight surfaces, just pipes, so with no hydraulic power there was no control action at all. But the crew was left with control of the engines and that made it possible to control the airplane. True, but at least the control system didn't have a mind of its own. It may stop working, but it isn't likely to start doing things that the pilot doesn't want it to do. My assertion is that there is insufficient evidence to conclude that everyone would have died had the airplane been FBW. Uncertainty remains as to that outcome. From what I've read, they weren't even supposed to have survived the accident as it was. I don't know if anyone ever managed to duplicate their landing feat in a simulator (I've read that it has never been successfully done in simulation). However, much as it may disturb some other, less tolerant, members of this group, I tend to agree with your qualms about FBW. FBW makes it possible to implement exotic airframe designs by defining their flight characteristics in software instead of in hardware. That's fine when the pilot sits in an ejection seat, but when this technology is extended to airplanes whose occupants don't have the option of pulling a handle when things go badly then we must be very careful. I agree. Furthermore, I just don't see a need for it. Just because you can do it doesn't mean that you must or you should; it doesn't even mean that you have anything to gain from it. Military fighters need the best possible performance (or at least they did, until they hit the obstacle of keeping pilots alive). FBW can achieve that in certain situations, but at the expense of higher risk for all flight in general. I don't see how any of this would be applicable for general or commercial aviation. I'm sure the problems can be solved, probably with multiple redundancy, but a century of experience with aviation shows that we must always consider the possibility of failure. Perhaps the problems can be solved, but if there is nothing to be gained by FBW in the first place, why bother? Does anyone who flies a plane for pleasure dream of being able to fly by just pushing one button, or having a plane that does what it thinks is best, instead of what the pilot tells it to do? When planes are for pure transportation, perhaps that might argue in favor of such systems, but in that case why bother keeping a pilot in the cockpit at all? If FBW is completely reliable, you don't need a pilot. If you need a pilot, then FBW is not completely reliable, and the pilot needs a way to override it. I've been similarly apprehensive about glass cockpits in light aircraft. A single point of failure in an inadequately designed and tested system could conceivably leave a pilot deaf, dumb, and blind. And he would already be broke from paying for the avionics. Wouldn't this also be a risk for any other aircraft? Show me the test plan. That's the part that worries me most. I know what passes for "testing" in the world of computers, and it's an accident waiting to happen. Yes, avionics are tested more thoroughly--but not thoroughly enough. The failure modes multiply exponentially as gadgets and features are added, and nobody is testing all the possible scenarios. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#115
On Thu, 28 Sep 2006 19:23:39 +0200, Mxsmanic
wrote: Military fighters need the best possible performance (or at least they did, until they hit the obstacle of keeping pilots alive). FBW can achieve that in certain situations, but at the expense of higher risk for all flight in general. I don't see how any of this would be applicable for general or commercial aviation. There is one potential advantage to computer enhanced control for civil aviation: fuel economy. We can build more efficient airframes, but they're often unstable. We can compensate with software. FBW offers the promise of allowing airplanes to use less fuel. That's too important a benefit to ignore, but we can't sacrifice safety in the process. RK Henry |
#116
Mxsmanic,
If flight 232 had been a fly-by-wire aircraft, everyone aboard would have died. Oh, are we clairvoyant now, too? You are spreading more clueless BS. -- Thomas Borchert (EDDH) |
#117
Mxsmanic,
but this is one of several plausible scenarios. A flat earth is one of several plausible scenarios to many people, too. -- Thomas Borchert (EDDH) |
#118
RK Henry writes:
There is one potential advantage to computer enhanced control for civil aviation: fuel economy. Yes, but you could still build a system that the pilot can override and yet preserve fuel economy. Autopilots and flight computers are existing examples of this. Overriding them requires only the press of a button, or (in some cases) merely a movement of the controls by the pilot. We can build more efficient airframes, but they're often unstable. Why would a more efficient airframe be unstable? Something that requires constant computer surveillance to stay in the air likely has some aerodynamic instabilities, which implies sources of drag or lift that would sap energy from the powerplant. Gliders require very little energy. FBW offers the promise of allowing airplanes to use less fuel. That's too important a benefit to ignore, but we can't sacrifice safety in the process. Corporations don't care about safety. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#119
RK,
but when this technology is extended to airplanes whose occupants don't have the option of pulling a handle when things go badly then we must be very careful. I'm sure the problems can be solved, probably with multiple redundancy, but a century of experience with aviation shows that we must always consider the possibility of failure. And your worries show in the accident statistics of the Boeing 777 and the Airbus 32x and up exactly where, after over 20 years of service? A single point of failure in an inadequately designed and tested system could conceivably leave a pilot deaf, dumb, and blind. There's a ton of single points of failure in any aircraft ever designed. -- Thomas Borchert (EDDH) |
#120
On Sat, 30 Sep 2006 17:01:37 +0100, Thomas Borchert
wrote: RK, but when this technology is extended to airplanes whose occupants don't have the option of pulling a handle when things go badly then we must be very careful. I'm sure the problems can be solved, probably with multiple redundancy, but a century of experience with aviation shows that we must always consider the possibility of failure. And your worries show in the accident statistics of the Boeing 777 and the Airbus 32x and up exactly where, after over 20 years of service? Umm...20 years of service? They've got a way to go before they rack up that much service experience. However, I have few doubts. The engineers share my concerns, that's why they've provided multiple redundancy. My Warrior has non-redundant cables operating the control surfaces. As long as metal continues to obey physical laws and they get looked at once a year, I have few worries. However, there are people who suggest FBW is in the future for light aircraft. That worries me. How is a 777 flight control system going to scale to a Warrior? Is there going to be some kind of cost-saving breakthrough or are they going to cut corners? RK Henry |
SWRFI - next weekend! | Richard Lamb | Home Built | 13 | May 10th 06 03:45 AM |
DG Rudder AD - DONE! - Notes from my work | ContestID67 | Soaring | 0 | March 30th 06 07:36 PM |
Southern California airports have worst runway safety records | Larry Dighera | Piloting | 0 | November 26th 05 04:48 PM |
Information on A310 that lost it's rudder enroute to Canada from Cuba | Corky Scott | Piloting | 3 | March 27th 05 03:49 PM |
Rwy incursions | Hankal | Piloting | 10 | November 16th 03 02:33 AM |
