Hmmm a BD5J with zero hours FS
Old December 27th 06, 10:47 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
Default Hmmm a BD5J with zero hours FS
I doubt you will find a URL. SOES is the Station Operations and Engineering
Squadron. I worked there from 1979 to 1981 maintaining their CH-46A SAR
birds.
Oh, wait a sec. I see why you can't find it. It's been renamed and is now
VMR-1.
http://www.cherrypoint.usmc.mil/mcabe/vmr1/vmr1.asp
Look at the history page, you'll see this is what used to be SOES.
They now have HH-46D's. Looks like they finally upgraded sometime after I
left for MCAS(H) Tustin in Southern California and was assigned to HMM-161
until I got out in 1982. They are also listed as having UC-12B King Air's,
but that's not what we had when I was there, back then they had Piper
Apache's, I forget the designationm U-something too. There were rumors they
were going to be replaced with the King Air's but when I left they had not
arrived. We already had the C-9B's and we also had some T-39 Sabreliners for
VIP transport.
This was our hangar. I assume it still is, there's one of the C-9B sitting
at its usual parking spot on the ramp.
http://maps.google.com/maps?f=q&hl=e...06781&t=k&om=1
This is a picture I took on the ramp in 1981, if I remember correctly. Been
a while. Look at the discussion page for the image, a Marine who currently
works for VMR-1 saw it and commented on it.
http://en.wikipedia.org/wiki/Image:CH46-At-SOES.jpg
Juan
"Scott" wrote in message
Can you provide a link URL? I searched on the MCAS Cherry Point Website
with no luck (since I don't know what SOES is...searching with that turned
up a Sony Online Entertainment tribute). Searching with your name only
turned up 3 hits...all in 2003-2004.
Scott
Juan Jimenez wrote:
Tell you what, if you ever grow balls large enough, go check the records
of SOES, circa 1979 through 1981, at MCAS Cherry Point. In fact, check
out the records of a medevac mission in 1981 involving a mom who had just
given birth and was hemorraging, and the preemie to which she had just
given birth. Then check out the comments of the (at the time,
double-digit midget) Vietnam-vet crew chief on the aircraft that took
them from Cherry Point to the main hospital at Lejeune.
Go ahead, putz. I dare ya. But don't worry, I don't hold my breath for
all bark, no bite keyboard cowards like you.
Posted via a free Usenet account from http://www.teranews.com
  #112
Old December 27th 06, 11:04 PM posted to rec.aviation.homebuilt
"Juan Jimenez" wrote in message
"Wayne Paul" wrote in message
Juan,
Who do you use to inspect your injectors? I live in Idaho and hopefully
the company is located nearby.
A friend who specializes in warbird restoration, has the equipment and
did it as a favor. You don't really think I will post that information
here, do ya?
Juan,
OK,,, was it Bob Hannah Aviation in Caldwell, ID; Warbird Restoration &
Maintenance in Jerome, ID; or, John Paul's (no relation) Warhawk
Museum,,, here in Nampa, ID?
If you don't want to post the ansewer here, you may email me at
Thank you,
HP-14 "6F"
http://www.soaridaho.com/
See private email.
Juan,
Thank you for the prompt and informative email.
HP-14 "6F"
  #113
Old December 27th 06, 11:06 PM posted to rec.aviation.homebuilt
Scott[_1_]
Thanks for the link. However, I was unable to find a reference to the
"medevac mission in 1981 involving a mom who had just
them from Cherry Point to the main hospital at Lejeune."
It sounds like it might be interesting reading...
Scott
birds.
VMR-1.
VIP transport.
Juan
Scott
  #114
Old December 28th 06, 07:27 AM posted to rec.aviation.homebuilt
Roger[_4_]
On Wed, 27 Dec 2006 13:26:23 -0500, "Morgans"
It's good that you found a problem that may get your engine running
again
but aren't you missing something? If your engine truly is "new", then
all
that injector clogging happened in just a brief ten hours. There must
be an
underlying systems problem that caused the clogging. Have you found
that
problem? If not it will just re-occur in the next ten hoursof running
time.
This is a valid point, don't you think? Is there something in the tanks, or
somewhere in the fuel system causing the injectors to be clogged so quickly?
Was there some problem previously existing in the engine?
With these plastic airplanes (like I'm building) clogged fuel filters
are common until all the crud is cleaned out of the tanks. After all,
working with fiberglass is mostly sand and fill, sand and fill, fill
and sand, fill and sand and if you get bored you can change that back
to sand and fill... At any rate that creates a *lot* of dust, not all
of which is easily blown out of tanks.
If the injectors are truely clogging it sounds like a fuel system
needs a thorough flush and the addition of a really good fuel filter.
That little jet engine isn't exactly over endowed with thrust so any
loss is substantial.
Fixing a problem is good.
Fixing the cause of a problem is even better. g
It certainly can save a lot of work in the long run and maybe even
hospital bills.
www.rogerhalstead.com
  #115
Old December 28th 06, 01:38 PM posted to rec.aviation.homebuilt
Morgans[_5_]
"This is a valid point, don't you think? Is there something in the tanks,
or
quickly?
hospital bills.
You plainly state what I was hinting around at.
If it were me, I would be wanting to know what the substance plugging the
injector consisted of.
Fiberglass or slosh compound would be high on my list.
  #116
Old December 28th 06, 02:57 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
Juan,
hopefully the company is located nearby.
here, do ya?
Juan,
Thank you,
HP-14 "6F"
See private email.
Juan,
HP-14 "6F"
You're welcome.
  #117
Old December 28th 06, 03:11 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
There is no "link" for that. There was no consumer "internet" at the time.
You'll have to go to the squadron to find the records, assuming they still
have them, otherwise you'll have to ask the Marine Corps to check their
archives. I don't know how long they keep records locally.
The story is this: At 9pm I was working night duty in the avionics shop. We
were scheduled to go home on standby at about that time and were about to
cleanup and turn in our tools when the hanglar claxon went off and the PA
system announced the usual "Launch Pedro!". Pedro was the codename for
whatever helo was the duty bird. So, myself and my sidekick sat down to
wait, because if the bird was going out we had to stay in case it came back
with squawks.
Not more than 2 minutes later we get an intercom call to go to the aircraft.
So we run out there, and we can see the APU is running but no lights. I go
inside and gesture to the crew chief and he points to the lights ... no
power. I checked the obvious things, and nothing, so I turned around to my
sidekick, the slowest kid in the shop, and asked him if they had done
anything to do the bird that day. Changed the APU, he said. D-oh. Ok, did
you check it when you were done rewiring it? No. No?? Did you bother to run
it up? No. Why not? I'm not checked out. (It takes a short check and two
switches to turn on the APU on an CH-46A... that should give you the
picture.)
So, I turned around and dropped the upper rear clamshell a bit, raised the
lower one to just a few inches under, and carefully slid up to the running
APU. I removed the small plastic cover over the wires and immediately saw
what was wrong. Wiring becomes somewhat brittle over the years, and when its
put back on the wrong way it's rather obvious because of the way it looks.
So I switched the two incorrectly installed wires, replaced the cover,
safety wired it, checked for loose safety wire, inventoried tools and slid
back down.
I tell the CC to fire up the power and even though its dark and he's wearing
a helmet, he gives me one of these "Are you out of your ****ing mind?"
looks. I repeat the hand gesture to power up, he talks with the crew up
front, I can see them looking back from the cockpit, so I walk up, asked for
permission to turn on power, they sort of nodded and I did. Power came right
back up. Big smiles in the cockpit.
I went back to finish up with the crew chief (who had another huge smile on
his face). Just then I realized why he had a huge smile. Two ambulances came
roaring down the ramp and parked right behind the helo. Out came a woman in
a stretcher, clearly in distress. Behind her came a portable incubator with
a preemie. The woman had just given birth and was hemorraghing, they were on
the way to Lejeune because that's where the big hospital was located.
We got off and the helo fired up its engines and roared off into the night
sky. Came back with no squawks, so we went home. The next day the Vietnam
vet crew chief (and senior crew chief in the squadron) told everyone in the
squadron I knew my **** down cold and he'd trust me to work on anything with
a wire on his bird. I already had the ability to do just that, but that one
compliment made my whole year. Doesn't happen very often.
Within weeks I got my best eval ever and had my txfr request out of NC
approved, to California. The rest is history, and records from that day will
verify everything happened exactly as I state here.
And yes, both the mom and the child were OK, I just never heard from them
again.
Scott
Engineering Squadron. I worked there from 1979 to 1981 maintaining their
CH-46A SAR birds.
VMR-1.
HMM-161 until I got out in 1982. They are also listed as having UC-12B
King Air's, but that's not what we had when I was there, back then they
had Piper Apache's, I forget the designationm U-something too. There were
rumors they were going to be replaced with the King Air's but when I left
they had not arrived. We already had the C-9B's and we also had some T-39
Sabreliners for VIP transport.
sitting at its usual parking spot on the ramp.
Been a while. Look at the discussion page for the image, a Marine who
currently
Juan
turned
Scott
just
  #118
Old December 28th 06, 03:18 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
"Roger" wrote in message
Already done, and the fuel system has five filters.
  #119
Old December 28th 06, 03:23 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
"Morgans" wrote in message
tanks, or
quickly?
hospital bills.
Neither. If you had an inkling of knowledge about BD-5's you'd know the
wings are all metal, no fiberglass. Been that way for 30 years, get with the
program and get off the armchair. And if you had followed my notes, you'd
know I used a sealing product that does not dry while in contact with Jet-A.
The wings must be dry, then the compound is introduced, sloshed, and the MEK
is allowed to evaporate from the formula, leaving behind an extremely tough
Buna-N layer. The substance in the injector was extremely small, probably a
grain of sand or something, because fuel flow was not interrupted, but the
pattern was not optimal.
  #120
Old December 28th 06, 06:03 PM posted to rec.aviation.homebuilt
Juan Jimenez wrote:
"ChuckSlusarczyk" wrote in message
I guess we could build one out of Balsa and go for the record seeing how
it
doesn't need to fly to get the record.Heh Heh how about a Scale RC turbo
jet
model of an F-15 I seen one fly. Beats yawn on 2 counts ,it's smaller and
it
flys .
Sorry, ChuckSteak, but it has to carry a human being. You don't rate the
privilege.
But it doesn't have to ever leave the ground while carrying a
human being right?
FF
Commerical rating question about hours req. Nik Piloting 5 September 12th 06 05:43 AM
First 2 1/2 hours PPL(H) today! Simon Robbins Rotorcraft 42 September 25th 05 12:54 AM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
