#111
#112
#113
![]() "MLenoch" wrote in message ... - "riser".(rimshot) You misspelled loser. Thanks for playing. |
#114
Weiss only comes here to be an unsufferable prick. The whole idea is one
cooked up at ALPA and posted on their website. It is a way to blow off steam from a job, that includes much ass kissing. It is a good thing that Weiss was able to think and then retract his rediculess assertion. Congratulations, you have just described yourself. Oops, now you will call me names again. Dan, U. S. Air Force, retired |
#115
Date: 9/29/2003 9:59 AM Central D snip "Fugoids"??? What, another Traverism? Me thinks its spelled Phugoid.......with a "PH". Go ahead....look it up. My 5th graders' dictionary has it. Yours might. VL From : http://www.mit.edu/afs/athena/org/a/...gue/node2.html "T he phugoid mode is the simplest oscillatory mode in aircraft dynamics. The only governing force is gravity, and energy is conserved, as there are no dissipative mechanisms. The airplane can only trade kinetic energy for potential and vice-versa. For a stationary observer the aircraft trajectory looks like a sine wave, while for an observer moving with the 'average' speed of the aircraft it looks like an ellipse. These are shown by the following applet: " Then they show graphics. I bet Tarver will say he doesn't have to look there since he is smarter, that I am "trolling" and he will now call me names. For the rest of you it is a rather nice visualization. Dan, U. S. Air Force, retired |
#116
"Gord Beaman" wrote...
WRT John W's post. He's just risen 'another' notch in my view when he corrected himself wrt the yaw damper providing assistance in turns. BTW, I watched from the jumpseat this morning on the approach into ICN (Incheon, Korea). The yaw damper didn't do too good a job of coordinating turns -- saw a consistent half-ball slip in the turns after established in the angle of bank. Ball went back to center when wings were level. BTW, I use the term "ball" here because virtually every pilot understands the term in context. The 744 has an electronic slip indicator that we often refer to the "sailboat" since it is a white oblong slip indicator under a white bank angle pointer triangle on the Primary Flight Display. |
#117
WRT John W's post. He's just risen 'another' notch in my view when he corrected himself wrt the yaw damper providing assistance in turns. The yaw damper didn't do too good a job of coordinating turns -- saw a consistent half-ball slip in the turns after established in the angle of bank. Agreed & very much appreciated. Thank you, VL |
#118
B-58 Hustler History: http://members.cox.net/dschmidt1/
- "Tarver Engineering" wrote in message ... "Darrell" wrote in message news:zC0eb.5045$La.3520@fed1read02... B-58 Hustler History: http://members.cox.net/dschmidt1/ No, use of the rudder is explicity unsafe. Only if you have "Splaps" extended. Whoops. Using a Tarver term again. (or was that Splats?) In fact, using spoiler flaps, as opposed to spoilers as speed brakes only, is the means through which the rudder is reduced in size for both the KC-135 and the B-52H. Current models of civilian two engine aircraft have been designed away from that notion, due to engine out requirements. Keep in mind that this is a military group, not bound by CFR14 legalese, Schmidt. Beside being a Boeing instructor I was also an AA airline captain and as for military, I spent 20 years in the Air Force and flew the B-52H you refer to at Minot for 5 years. I was an instructor and in Stan Eval in B-52Hs. (we didn't call them "splaps" or "Splats") |
#119
didn't call them "splaps" or "Splats") I believe the correct technical term is "them big floppy thingies on the wings." Dan, U. S. Air Force, retired |
#120
"John R Weiss" wrote:
"Gord Beaman" wrote... WRT John W's post. He's just risen 'another' notch in my view when he corrected himself wrt the yaw damper providing assistance in turns. BTW, I watched from the jumpseat this morning on the approach into ICN (Incheon, Korea). The yaw damper didn't do too good a job of coordinating turns -- saw a consistent half-ball slip in the turns after established in the angle of bank. Ball went back to center when wings were level. But the slip may have been larger had the yaw damper been turned off?...(IOW maybe it 'helped'?) -- -Gord. |
