BA 777 crash at Heathrow
Old March 17th 08, 01:03 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default BA 777 crash at Heathrow
"Blueskies" wrote in
et:
Tina wrote in
This was brought up by some newspaper or another around the time it
happened.
It's looking like it was fuel waxing in any case, but they'll be a
hile with this one. Meanwhile some other airline had one spool down
in a similar fashion in LA, I think it was.
Bertie
Maybe Bush's motorcade was passing underneath?
Mebbe!
bertie
  #112
Old March 17th 08, 05:40 PM posted to rec.aviation.piloting
On Mar 16, 3:20*pm, Bertie the Bunyip wrote:
Tina wrote :
No independent verification of this, but interesting
BOEING 777 Crash
Prime Minister Dr. Gordon Brown's motorcade was passing under the
approach path of BA038. His security system utilized an RF transmitter
to block out
any cell-phone triggered devices. Apparently this system has a two
mile
range, and it caused the Boeing 777 EEC's (electronic engine controls)
to sense a
"overboost" situation, thereby commanding a reduced-thrust situation
for
the engines, simultaneously. Most interesting.
We'll see how Boeing and the BAA handle this one. This could be
potentially bad, in view of the simplicity of technology that the bad
guys
could use to bring down an airliner.
On Jan 17, 8:23*pm, "Blueskies" wrote:
What the heck happened? Fuel starvation? Doesn't sound like wind
shear cou
ld have been an issue.
http://seattletimes.nwsource.com/htm...rld/2004130291
_apbritai.
happened.
It's looking like it was fuel waxing in any case, but they'll be a hile
with this one. Meanwhile some other airline had one spool down in a
Bertie- Hide quoted text -
- Show quoted text -
I was thinking that slush in the tanks may have been behind the power
loss. If the plane was at a fairly low fuel level and changed pitch
attitude on approach, slush could have been sucked into the fuel
lines. Only a small amount of water slush would have been required to
cause a problem. Post crash, the slush would be gone, and may even
have passed through the engines just prior to the crash, but too late
to restore power to the engines. Just a thought...
  #113
Old March 17th 08, 07:11 PM posted to rec.aviation.piloting
wrote in
Tina wrote
innews:a1277cd8-28db-416c-9034-1bf02c02
BOEING 777 Crash
transmitter to block out
mile
controls) to sense a
situation for
bad guys
shear cou
_apbritai.
happened.
Could be, but the fuel itself can freeze. it was a polar flight and
apparently the were getting concerned about fuel temp and asked for a
lower FL but didn't get it.
Bertie
  #114
Old March 17th 08, 08:49 PM posted to rec.aviation.piloting
BOEING 777 Crash
mile
situation for
bad guys
shear cou
_apbritai.
happened.
loss. *If the plane was at a fairly low fuel level and changed pitch
lines. *Only a small amount of water slush would have been required to
cause a problem. *Post crash, the slush would be gone, and may even
to restore power to the engines. * Just a thought...
lower *FL but didn't get it.
Bertie
- Show quoted text -- Hide quoted text -
True, diesel does turn to jelly at low enough temperatures, so it may
be that thickened fuel was sucked into the lines, and this still could
have been associated with the pitch attitude change on final... good
point.
  #115
Old March 17th 08, 10:22 PM posted to rec.aviation.piloting
Tina
Isn't it stretching things to think it would happen to both engines at
the same time when they are drawing from two different tanks? That's
stacking a lot of "If's" in a row.
On Mar 17, 4:49 pm, wrote:
On Mar 17, 1:11 pm, Bertie the Bunyip wrote:
wrote :
BOEING 777 Crash
mile
situation for
bad guys
On Jan 17, 8:23 pm, "Blueskies"
shear cou
_apbritai.
happened.
Bertie
point.
  #116
Old March 17th 08, 10:56 PM posted to rec.aviation.piloting
stacking a lot of "If's" in *a row.
BOEING 777 Crash
mile
situation for
bad guys
shear cou
_apbritai.
happened.
Bertie
have been associated with the pitch attitude change on final... *good
point.- Hide quoted text -
Not if both tanks were at similar levels, and both had similar ratios
of jelled and ungelled fuel. The change in pitch attitude on final
approach would cause both inlets to draw from the same waterline in
the tanks at the same time. The fact that the problem occured while
the plane was on final and not during cruise is pretty suspicious.
  #117
Old March 18th 08, 03:21 AM posted to rec.aviation.piloting
wrote in
wrote
innews:aa884032-60e0-46f8-996b-d201422eca30@e10g2000
prf.googlegroups.com:
BOEING 777 Crash
two mile
situation for
the bad guys
wind shear cou
_apbritai.
it happened.
down in a similar fashion in LA, I think it was.
power loss. *If the plane was at a fairly low fuel level and
changed pitch attitude on approach, slush could have been sucked
into the fuel lines. *Only a small amount of water slush would have
been required to
late to restore power to the engines. * Just a thought...
Bertie
point.
Well, the pitch attitude probably had little to do with it, more than
likely they were at or near idle with a low FF demand and when they
spooled up to stabilise after flap extension the increased demand caused
the problem. Hard to know zand the report shouldn't be too long coming
out. There has been some scuttlebut to that effect, though. Older
airplanes used bleed air, as well as engine oil and hydraulic heat
exchangers to keep the fuel warm, but the modern ones skipped the belts
and braces bleed air, which is the hottest, of course.
Bertie
  #118
Old March 18th 08, 03:33 AM posted to rec.aviation.piloting
Tina wrote in
It's not an if. When kerosene gets cold enough it waxes. Both tanks were
exposed to the same temps for many hours. Probably somthing in the region
of -65 C.
Bertie
  #119
Old March 18th 08, 03:35 AM posted to rec.aviation.piloting
wrote in
at the same time when they are drawing from two different tanks?
That's stacking a lot of "If's" in *a row.
2000prf.googlegroups.com:
BOEING 777 Crash
under the
a tw
o
mile
situation for
be
that the
bad guys
wind
shear cou
_apbritai.
time it
happened.
be a hile with this one. Meanwhile some other airline had one
spool down
powe
r
pit
ch
fuel lines. *Only a small amount of water slush would have been
require
d to
eve
n
too lat
e
and apparently the were getting concerned about fuel temp and
asked for a lower *FL but didn't get it.
Bertie
may be that thickened fuel was sucked into the lines, and this
still could have been associated with the pitch attitude change on
final... *good point.- Hide quoted text -
Not really. FF would have been low for a considerable period. FF would
be higher on approahc than in the cruise.
Bertie
  #120
Old March 18th 08, 04:38 AM posted to rec.aviation.piloting
Big John[_2_]
On Tue, 18 Mar 2008 03:33:41 +0000 (UTC), Bertie the Bunyip
Tina wrote in
of -65 C.
Bertie
Bertie
Before the Airlines started flying jets the Air Force ran into a fuel
problem in their jets at altitude. Can't remember now if it was ice
xtyls forming in the fuel or waxing as you say but the Air Force
started putting an additive in their fuel that stopped that problem
and the Airlines picked up on it when they started flying jets I was
told.
The basic problem was that the xtyls would form in the fuel and then
pack the filter and stop fuel flow.
Do the Airlines still use the/a additive in their fuel for the high
altitude problem?
Hope you had a good St Paddies day )
Erin go bre
Big John
[Fwd: Concord at Heathrow?] Markus Baur Aviation Photos 3 December 26th 07 11:55 PM
B747 at Heathrow Glenn[_2_] Aviation Photos 0 December 8th 07 09:47 AM
A380 flew into Heathrow today Kingfish Piloting 82 May 30th 06 01:55 PM
Google Earth Heathrow 9L approach news.east.cox.net Piloting 23 April 20th 06 09:36 PM
