CFI oral intel
Old June 6th 08, 06:19 PM posted to rec.aviation.piloting,rec.aviation.student
Robert M. Gary
Default CFI oral intel
On May 30, 9:00*am, "F. Baum" wrote:
On May 29, 9:54*am, "Robert M. Gary" wrote:
Huh, that's not right. There is nothing in the PTS that says you get
to skip the FOI stuff just because you have an AGI. The only thing you
get to skip is showing your FOI exam results. I had my AGI and
probably spent 5 hours of my CFI oral on FOI stuff.
Is there anything in the PTS that says you have to be retested on
previously completed material ?
Yes, the PTS says you have to cover FOI during the oral even if you
have the AGI certificate. Actually the PTS does not allow you to skip
*any* part of the initial CFI practical test just because you have the
AGI.
Remember, there is no practical for the AGI, you just walk into the
FSDO (after making an appointment, going through security, signing in,
swearing you're not a terrorist) and show them your AGI and FOI exams.
-Robert
  #113
Old June 6th 08, 09:20 PM posted to rec.aviation.piloting,rec.aviation.student
Marty Shapiro
Bertie the Bunyip wrote in
Michael wrote in
news:7dad14f5-8015-
If the demostration is wrong, then the plane WILL remain wings level
(the way a ram-air parachute will). Now THAT would be useful for
inadvertent IMC encounters. Just tell people to let go of the
controls, and the plane will fly out of it. In fact, that is exactly
what parachutists do if they inadvertently encounter a cloud.
Some of them will undoubtedly do it, but most prolly won't.
There is one that probably would save your bacon if you had either an
engine failure or you got caught in IMC down to the ground.
It's the French Rallye and it will sit in a semi stalled attitude
power on or off as long as you hold the stick back with a relativley
low rate of descent. Some people call it the "Tin Parachute" I've
flown a couple of the small engined ones in Yerp and they're pretty
marginal in climb, though..
Bertie
Move up to the Rallye 235. Not marginal in climb at all.
At power off, yoke full back, the 235's nose bobbles (more like light
buffet) very slightly on the horizon whle you descend at just over 1,000
fpm in this nose level attitude.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
  #114
Old June 6th 08, 09:24 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_25_]
Marty Shapiro wrote in
Yeah, so I believe. Not very fast, though, is it?
You'd probably walk away formit, but it would hurt! You're forward speed is
pretty low in this flight regime then, eh? Less than 40?
Bertie
  #115
Old June 6th 08, 09:40 PM posted to rec.aviation.piloting,rec.aviation.student
Marty Shapiro
No. Top speed is 152 MPH (131 kt). The automatic leading edge slats and
fixed gear add quite a bit of drag.
With half tanks, just me in the aircraft, 1/2 flaps, and a cool day (10 C)
I can be almost 1,000' AGL by the end of a 3,100' runway if I hold Vx all
the way.
(Fowler flaps. 1/2 has them fully extended but only 10 degrees or so
down.)
1,000 fpm in this nose level attitude.
speed is pretty low in this flight regime then, eh? Less than 40?
About 35 MPH.
Bertie
Marty Shapiro
Silicon Rallye Inc.
  #116
Old June 6th 08, 09:55 PM posted to rec.aviation.piloting,rec.aviation.student
and fixed gear add quite a bit of drag.
Really? I thought they were a good bit slower than that.
(10 C) I can be almost 1,000' AGL by the end of a 3,100' runway if I
hold Vx all the way.
Good bush airplane alright. Rare enough nowadays too, since most seem to
have corroded away.
Is it a French one or a Polish one?
I saw a Taildragger one recently in Spain. That'd probably be quite a
useful machine..
down.)
light buffet) very slightly on the horizon whle you descend at just
over 1,000 fpm in this nose level attitude.
About 35 MPH.
That's pretty good OK.
  #117
Old June 7th 08, 02:23 AM posted to rec.aviation.piloting,rec.aviation.student
Marty Shapiro
The light airframe models are slower.
Rallye's have multiple models. The "light" airframes were mainly 2 seat,
stick, and engines from 100 HP through 150 HP (Rolls Royce, Continental,
Lycoming). The 180 HP was a 4 seater and you could order with stick or
yoke. Lycoming engine.
The "heavy" airframes were the Minerva (Franklin 220 HP engine) and the
Rallye GT aka 235E (Lycoming O-540-B4B5 235 HP). All the "heavies" had 4
seats, yokes, and 2 hard points on each wing.
The 235C was a tail dragger version of the 235E. The 235's also came with
a factory opiton of a glider tow kit.
have corroded away.
Only the 235C would be a good bush airplane. The prop clearance on the
trike is at best 2". It does have a decent payload capacity. Empty weight
is 1,535 lbs and MTOW is 2,645 lbs. Max landing weight is 2,513, so plan
on burning 22 gals if you take off at max weight.
The last time I looked, there was something like slightly less than 100
Rallye's of all models (both French and Polish) on the FAA registry.
French. To my knowledge, PZL Koliber only sold a version of the 150. They
were working on a version of the 235 but I'm not aware of it ever being
released.
The original Rallye's were made by Moraine-Soulnier, which was eventually
merged into SOCATA, which is now part of EADS. SOCATA licensed it to PZL,
which used it to produce the Koliber 150. I seem to remember reading that
SOCATA has bought the license back from PZL.
useful machine..
down.)
About 35 MPH.
The design is STOL. Huge oversized control surfaces. In a power off stall
configuration, you can still steer with just the ailerons, although you
will get a dramatic adverse yaw demonstration.
We have a 300' displaced threshold at my home field. I can pop the mains
off before the landing threshold and well below the white arc. Yes, it
will wallow in ground effect a bit, but then settles right down and climbs.
With a little concentration, you can land in 500' and just light brakes.
Great visibility from the cockpit. The sliding canopy comes down almost to
your waist. The first time I did a 45 degree bank it seemed that I was
going to slide right out of the cockpit. You can also fly with the canopy
open, although you do have speed restrictions based on how far it is open.
Up to 4" and there are no restrictions. Fully open you're limited to 93
MPH.
Marty Shapiro
Silicon Rallye Inc.
U.S. Navy Plans EPX Intel-Gathering Aircraft [email protected] Naval Aviation 0 February 23rd 08 02:38 AM
FOI...lol... CFI oral? gatt[_2_] Piloting 29 January 5th 08 05:01 PM
Q: Apple MAC Book (pro) with Intel core 2 duo running Windows XP plus soaring software Ruud Soaring 1 October 31st 06 01:02 AM
INTEL BILL CON JOB Cribsheet Piloting 0 December 7th 04 05:40 PM
