Rutan hits 200k feet! Almost there!
Old May 15th 04, 06:54 PM
Mary Shafer
On Fri, 14 May 2004 22:44:42 -0700, Steve Hix
In article . net,
"Steven P. McNicoll" wrote:
"Vaughn" wrote in message
news
Sorry, but I have to go with Pete here, the relevent point is that
it is being done by a small private corporation...and they are making
it look easy!
What is significant about a private corporation duplicating a feat that a
government agency accomplished decades earlier?
They don't need a cast of thousands and a couple hundred million to do
it.
The X-15 program didn't have a cast of thousands. It also didn't cost
a couple hundred million. In fact, it didn't even have a cast of a
thousand, now that I think about it. Maybe two or three hundred
people, for all three vehicles, at most. The cost was in the
millions, of course, but not hundreds of millions.
Mary
Mary Shafer Retired aerospace research engineer
  #112
Old May 15th 04, 07:00 PM
Larry Dighera
On Sat, 15 May 2004 10:54:58 -0700, Mary Shafer
wrote in Message-Id: :
The cost was in the millions, of course, but not hundreds of millions.
What would the cost be adjusted for four decades of inflation?
Irrational beliefs ultimately lead to irrational acts.
-- Larry Dighera,
  #113
Old May 15th 04, 07:31 PM
Chad Irby
(Peter Stickney) wrote:
However, granting that - here's the list of altitude flights by X-15
#3 66672, (Which, it should be pointed out, wasn't the ablative coated
X-15A-II 66671.
Date (1963) Elapsed since Altitude Comment
previous flight
18 June 0 Days 223,700' Pilot: Rushworth
27 June 9 Days 285,000 Rushworth, (over 50 miles)
U.S. Astronaut
qualification
19 Jul 22 Days 347,800 Pilot: Walker (Over
100 Km) Intl Atro
qualification
6 Aug 17 Days Abort Weather Abort &
Computer overheat
13 Aug 7 Days Abort APU doesn't start
15 Aug 2 Days Abort weather Abort
22 Aug 7 Days 354,200 Walker: second
Intl Astro Qual
All X-15 operations postponed due to weather for 6 weeks after this
flight.
So, we've got 2 high altitude flights separated by 9 days,
Two-thirds of the height of the max alt flights needed under X-Prize.
What we have is two "qualifying" flights in July/August, separated by a
month, two hardware failures and a couple of weather failures. So, by
your own admission, they couldn't do it.
I'd say that if somebody had really wanted to fly 2 over 100 Km X-15
flights somewhere around 10 days apart, they'd have certainly been
able to do it.
But, in the actual records, they *couldn't*. Computer overheat,
vulnerability to weather, bad APU... nope, they couldn't manage it, even
with the less-stringent "rules" in effect.
If the Rutan craft doesn't manage to do the two flights in two weeks
because of some weather issues, will you argue that they could have done
it?
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
  #114
Old May 15th 04, 07:33 PM
Chad Irby
In article .net,
Well, if that's true, you'll be able to cite the statements I made
that are incorrect. Please take a shot at establishing some
credibility and do so.
Every time I've mentioned it so far, you've gotten a sudden case of
amnesia, with a side-dose of "I didn't say that."
**** off.
cirby at cfl.rr.com
  #116
Old May 15th 04, 07:37 PM
Chad Irby
Mary Shafer wrote:
You misunderstand. If carrying a crew of three in the X-15 had been
necessary, the X-15 would have been designed to do so from the
beginning. The X-Prize contenders knew that they had to carry three,
so the vehicles are designed to do so.
The only way they could have managed to design the X-15 to carry three
people was, well, they did that with the Dyna-Soar.
Saying that the X-15 can't meet the X-Prize rules, promulgated four
decades after the X-15 was designed, is an irrational statement.
Nope, claiming that it *could* meet the X-Prize rules is an irrational
statement. Telling someone it couldn't is what we use to *counter* that
guy's statement.
The X-15 was a very significant and important craft. We're still taking
advantage of the things it taught us. It was not an Arndt-like
ubercraft that could do anything if you added pieces on or redefined the
problems 40 years later.
cirby at cfl.rr.com
  #117
Old May 15th 04, 08:44 PM
Steven P. McNicoll wrote:
wrote in message ...
The significant part, which you so blithely dismissed, is that
it is being done by private industry. No government funding, no
trying to "beat the Ruskies" to manned spaceflight. Just because
the richest government in the world could afford to do it 40 years
ago does not mean a private project could have. Certainly no
privately funded project has done so yet. I know you say that
isn't significant, but it very much is.
Prove it.
Uh, prove what? That you don't think it's significant?
You have said as much. If you can't see the signifigant
difference between government funded and private
I'm not going to try to "prove" it to you, because you
are just being deliberately obtuse.
Bill Ranck
Blacksburg, Va.
  #118
Old May 15th 04, 09:51 PM
Keith Willshaw
nk.net...
"Keith Willshaw" wrote in message
The problem is that merely reaching the altitude is only a
part of the problem. The real issue is achieving orbital velocity
and the Rutan aircraft doesnt achive much more than 15%
of the velocity required to put something in orbit.
Why is that an issue?
Because without reaching orbit you cant do anything useful.
Reaching the altitude is all they're trying to do.
Thats obvious
Keith
  #119
Old May 15th 04, 09:54 PM
Keith Willshaw
"Chad Irby" wrote in message
.com...
No, it's not.
http://www.xprize.org/teams/guidelines.html
I'm aware of the rules of the X prize. Lots of posters in this thread have
made
comparisons with NASA and alluded to civilian space flight.
You need to achieve orbital velocity to do that.
Keith
Spaceship 1 hits 212,000 feet!!!!!! BlakeleyTB Home Built 10 May 20th 04 10:12 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 07:05 AM
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) Peter Stickney Military Aviation 45 February 11th 04 04:46 AM
Ta-152H at low altitudes N-6 Military Aviation 16 October 13th 03 03:52 AM
