V-8 powered Seabee
Old October 29th 03, 01:41 PM
Corky Scott
On Tue, 28 Oct 2003 15:43:58 -0600, Barnyard BOb --
The "wannabees, fruits, flakes and fringe folks" would include such
poseurs as Steve Wittman, Roger Mellema, Ray Geschwender, Bernie
Pietenpol, Ray Ward, Jerry Schweitzer and the Reverend Ron Van der
Camp. Some of the afore mentioned people designed auto conversions,
some designed entire airplanes, but all of the flew behind auto
conversions at one time or another. You might recognize a couple of
the names.
Corky (rolling my eyes) Scott
Enough of your brand of distortion, Corky.
Cease twisting my words to your agenda.
Pardon? I twisted your words? See below.
I do not consider Steve Wittman, Roger Mellema,
Ray Geschwender, Bernie Pietenpol, Ray Ward,
Camp in YOUR class of activity. FAR from it, sir.
Neither do I.
SO...quit flattering yourself right now !!!!!
Here are the words you typed, presumably you meant them: "The
wannabees, fruits, flakes and fringe folks deserve a shot at the
microphone.... but I'll not give them a free pass, even if it is
pointless."
What I pointed out is that better men that me (as you said and to
which I agree) have chosen to fly behind auto engine conversions,
none of whom were flakes or wannabees. What I'm doing is attempting
to follow in their footsteps. I take full responsibility for the path
I'm following.
I'm in the process of fabricating an engine test stand as you read
this. I fully intend to run the engine for many hours (with a prop
installed) prior to installing it in the engine compartment for good.
Corky Scott
  #112
Old October 29th 03, 02:48 PM
John Stricker
That's a valid point. Let's say we have a couple of early versions break
crankshafts. The cranks are changed, or maybe the balance is changed and
all appears to be well. The article is submitted with test results for
certification. It is certified. A couple dozen are placed into service.
Crankshafts start breaking.
Think the FAA will have any problems getting those pre-presentation test
results? Not if that manufacturer ever wants to sell anything as certified
again, they won't.
Certified Manufacturers are that way and charge what they do for a reason.
That reason IS the certification. If it was easy to be certified, their
SeaBee conversion would be certified, but it's not an easy thing to do or
maintain.
John Stricker
"Kevin Horton" wrote in message
news
On Tue, 28 Oct 2003 20:02:59 -0600, John Stricker wrote:
Dave,
Can we? I don't know if FOI covers that, but the FAA certification
division sure can. And they have the failure reports on file. That's
point, though. These conversions AREN'T certified. In effect WE are
certifying entity and as such the responsibility falls on us and we
can't
make that decision with glossed over reports of "trouble-free" service.
John Stricker
If the failures happen during development, and they make design changes to
address the failure before they present the engine to the FAA for type
certification, then the FAA may very well not have anything on file. The
FAA makes a very big point about not getting out the microscope until they
are presented a test article that conforms to the type design. The
definition of the type design evolves during the development process as
problems are found and fixed.
"Dave Hyde" wrote in message
If I'm going to by into something like an auto conversion, I want to
know
how it's failed in the past JUST LIKE I KNOW HOW THE LYCOMINGS AND
CONTINENTALS HAVE FAILED BECAUSE IT'S PUBLIC RECORD FOR THE LAST 50
YEARS.
I hope I didn't scare you with my shouting. 8-)
Not me, anyway, but I have an honest question: Do major GA engine
manufacturers make data on failures *in development* available to the
public? Can we see test-to-failure data on the new engines Lycoming,
Superior, Mattituck, etc. are putting out for homebuilts? Where?
Seems to me what an auto conversion needs is a 'sugar daddy' to put up
big $$$ to fund develompent and testing testing testing. I'm not
holding
my breath.
Dave 'enquiring mind' Hyde
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
e-mail: khorton02(_at_)rogers(_dot_)com
  #113
Old October 29th 03, 04:18 PM
Big John
Del
A true story that probably could be included under shock cooling.
In the P-51/Merlin (liquid cooled) we used to pitch off the deck (50
--100 feet -- 250 mph +/-) into the landing pattern. As we pitched up
we pulled the throttle to idle and the Merlin would go 'poppety pop'
out the short stacks all the way around the pattern (wonderful sound
to listen to G)
Some one got to investigating warped exhaust valves and found that the
valve timing was such that the engine sucked a lot of outside air
(cold) into the cylinder thru the exhaust valves at idle and with the
valves being 'hot' from cruise power, the cold air being sucked by
warped them.
Solution.
They let us only pull the throttle back to 10 --12 inches on pitch. If
you went 'poppety pop' in pattaern the Ops Officer would hear and chew
A**. As we flew around the pattern at the low power setting the
valves cooled and on final we went to idle for the touchdown.
Voila, no more warped valves.
So, Liquid cooling of an aircraft engine didn't eliminate all of the
'shock' cooling problems.
Big John
On 29 Oct 2003 03:22:42 GMT, Del Rawlins
On 28 Oct 2003 05:51 PM, Dave Hyde posted the following:
Del Rawlins wrote:
----clip----
Not quite on the same level. Where can I get a liquid cooled Lycoming
for my Bearhawk? It's a little bit of extra weight to lug around, but
worth it to me. Others don't seem as bothered by the need to baby their
engine on a descent to avoid shock cooling, or the suicidal heating
system used in most GA aircraft (where a slight undetected crack can
lead to CO poisoning).
----clip----
  #114
Old October 29th 03, 08:44 PM
Jim Stockton
Big John wrote:
Del
to listen to G)
warped them.
Solution.
Big John
Del Rawlins wrote:
----clip----
----clip----
John
The mufflers on this conversion would probably go a long way to
eliminate the problem of valve warping as compared to the short open
stacks on the mustang.
Jim Stockton
  #115
Old October 29th 03, 09:56 PM
Big John
I only posted a bit of triva. Am sure no one on thread had ever heard
of the problem.
Your right, long stacks or a muffler would prevent the valve warping,
like on the Merlin, today either with an air or liquid cooled
engine.???
Big John
On Wed, 29 Oct 2003 14:44:44 -0600, Jim Stockton
Big John wrote:
Del
to listen to G)
warped them.
Solution.
Big John
Del Rawlins wrote:
----clip----
----clip----
John
Jim Stockton
  #116
Old October 30th 03, 07:10 AM
Bruce A. Frank
Some years ago a company was building Ford engines for installation in
homebuilts. They did a couple of experiments of running the engine, with
a prop, without coolant. On both occasions the broken-in engines ran for
30+ minutes. Both stopped due to expansion of the pistons in the bores.
When the engines cooled the coolant systems were filled and the engines
started. Both ran and turned the prop at the same rpm. But also both
engine's head gaskets were shot and the metallurgy of both the heads and
the pistons had changed to the point of all having to be relegated to
the scrap pile. Crank and rod bearings were still in good condition.
Bruce A. Frank
Ron Wanttaja wrote:
"Jerry Springer" wrote in message
Better way? New design yes... auto engines no. Sorry I have not been
flying quite as long as Barnyard, only about 40 years for me. BUT every
auto engine conversion I know of has had a failure of some type.
But look at the bright side: With this one, if the SeaBee engine fails,
you get to shoot the dead-stick landing in air-conditioned comfort. :-)
On Mon, 20 Oct 2003 20:22:17 -0700, "Bart D. Hull"
I can buy the third issue. But what if it was a FADEC on a
Cont or a LYC instead? They quit without juice as well.
But Continental and Lycoming had to convince a *very* skeptical FAA about
the reliability of the FADEC. They had to prove that the FADEC is at least
as reliable as two magnetos.
I remember an article, years ago, about what Porsche had to do to certify
the PFM engine for the Mooney. They had to prove the two independent
ignition systems *were* completely independent. I think they even had to
apply a sudden dead short across one, just to prove the other one would
keep running.
I'm not being argumentative, but want more details so my
auto-conversion will be more successful than a LYC or Cont
install.
A good goal, and worthy of discussion. With one exception, the failures I
hear about have been fairly random, mostly related to the subsystems rather
than the core engine.
I think the lesson would be to strive for maximum redundancy. There
*should* be two completely independent ignition systems. Two batteries,
two electronics boxes, two sets of plug wires, two plugs per cylinder. The
second should be solely a backup, connected to *nothing* in common with the
primary system. If the primary system uses the distributor drive to time
the ignition, the backup system should run off a hall effect sensor on the
flywheel.
Buy a drycell battery and run it directly to the backup ignition
electronics...no connection to the primary bus. I say a drycell simply
because of their ability to hold a charge a long time. Test the ignition
momentarily during runup and slap a charger on the backup system every week
or so.
That way if your electrical system goes to hellandgone, you've got a
completely independent backup. The drycell should be sized to give you at
least a half-hour of flight time...I'm basing that on the required VFR fuel
reserve.
Probably your biggest worry, compared to a Lycosaur, is cooling. The air
cooling of your classic aircraft engine is extremely reliable...if it cools
properly when it's initially installed, there's very little that can happen
to it to make it NOT cool. If the oil cooler quits working, the engine
probably will last long enough to get you to a runway (other than if it
spews oil everywhere, of course).
You're not going to match that level of reliability; your airplane will
have a water pump, water hoses, and radiator that the Lycosaur lacks and
thus can't stop running if they quit. The lesson here is probably to use
the best quality parts you can find (race-type hoses, etc.) and to oversize
the system... if you develop a coolant leak in flight, it's nice if your
plane has to lose five gallons of coolant before it starts to overheat
rather than five quarts. Gauge the heck out of it, too...you want to be
able to detect problems as early as possible. I'd try put together some
sort of annunciator system rather than depend on the pilot's eyes to catch
a fading gauge.
I wonder what could be done along the lines of emergency cooling, like the
emergency ignition? The AVweb article about flying the Hawker Hurricane
makes me wonder about a spray-bar system for auto-engine conversions.
Could you gain some flying time if you had a system that would spray the
engine itself with water? And/Or some emergency cowl flaps that would open
and expose the engine case directly to the slipstream?
The PSRU is another single point failure item. I don't know what one could
do to increase redundancy, but plenty of design margin would be a good
start. Regular, in-depth inspections would be another...guy across from me
just found a crack in one plate of his gyro's PSRU.
Years ago, Kit Sondergren had an article in KITPLANES about terminating the
A-65 engine on his Mustang. He decided it needed to get overhauled, so he
tried a little experiment...he drained out all the oil and ran it on the
ground. IIRC, that engine ran at moderate throttle for something like a
half-hour before it really started to labor. I *like* that in an aircraft
engine. Nothing for cooling but the slipstream, two independent ignition
systems that generate their own power, and a engine that'll run for a
fairly long while with no oil at all. Lycomings and Continentals have one
thing in common with the dinosaurs: They leave mighty big shoes
to fill. :-)
I'm cautious about auto-engine conversions, but I wholly support those who
want to experiment with them. I like your attitude about wanting more
details to help improve your own work. Please continue to plug yourself
into information sources to build the safest engine possible.
Old October 30th 03, 12:18 PM
Barnyard BOb --
Bruce A. Frank
What RPM?
What power level?
Unless producing realistic in-flight power....
is there value in this exercise beyond PR?
Barnyard BOb --
  #118
Old October 30th 03, 12:45 PM
Eric Miller
"Barnyard BOb --" wrote in message
Bruce A. Frank
What RPM?
What power level?
Barnyard BOb --
What PR? As I read it, if you're cooling system fails you basically have
enough time to set it down then you're looking at a new engine.
Eric
  #119
Old October 30th 03, 01:49 PM
Corky Scott
On Thu, 30 Oct 2003 12:45:26 GMT, "Eric Miller"
Bruce A. Frank
What RPM?
What power level?
Barnyard BOb --
Eric
So far, I've not read of any reported catastrophic coolant losses in
the Ford powered airplanes. There have been instances (I've read of
two in Bruce's newletter) in which the head gasket began leaking.
This resulted in pressure readings that were abnormal, and the pilots
in both instances noticed them.
The airplanes were flown back to their home fields and the head
gaskets were replaced. In one instance, the airplane was a fair
distance from the field. Inflight coolant temperatures did not change
much, it was the pressure when the engine was shut down that got the
pilot's attention.
When you think about it, where where might a catastrophic leak occur
and how? Could a hose burst? A hole develop in the radiator? Those
things normally don't just blow up and spew out everything, they leak
very slowly at first, and a thorough preflight should include looking
for signs of coolant leakage I'd think.
When you put together a water cooled auto conversion, you use premium
hoses and radiators, right? You don't install aged and hardened parts
do you? Well I'm not going to anyway.
Corky Scott
  #120
Old October 30th 03, 02:40 PM
Barnyard BOb --
Bruce A. Frank
What RPM?
What power level?
Barnyard BOb --
Eric
I sincerely and most humbly apologize.
My generosity was aimed to cut these defunct folks some slack.
However, I have no problem seeing it your way. g
Barnyard BOb --
human powered flight patrick timony Home Built 10 September 16th 03 03:38 AM
Illusive elastic powered Ornithopter Mike Hindle Home Built 6 September 15th 03 03:32 PM
Pre-Rotator Powered by Compressed Air? nuke Home Built 8 July 30th 03 12:36 PM
Powered Parachute Plans MJC Home Built 4 July 15th 03 07:29 PM
Powered Parachute Plans- correction Cy Galley Home Built 0 July 11th 03 03:43 AM
