Kawa rough landing?
Old August 31st 19, 08:31 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Kawa rough landing?
Not sure how accurate FB translate is, but it appear as if Mr. Kawa had some sort of incident with an electric motor not working and a rough uphill landing. Gas, electric or jet be careful guys!
Old August 31st 19, 09:09 PM posted to rec.aviation.soaring
As I read it from google translate the pylon didn't make contact with the upper limit switch. He hit an unseen hump on a steep uphill landing bounced, lost energy because of the uphill trajectory and dropped in tearing off the undercarriage
Old August 31st 19, 11:10 PM posted to rec.aviation.soaring
Andrzej Kobus
Link?
Old September 1st 19, 07:43 AM posted to rec.aviation.soaring
Mike the Strike
Link?
I only found a brief report on his Facebook page - a short description with half-a-dozen photos. My reading is that he got stuck in a long valley and deployed the motor at about 1,000m AGL, the boom deployed but the motor failed to run. He landed on what looked like the best field but found it was rougher than it looked as well as steeply uphill. After touchdown, a hump sent him airborne, but because of the uphill landing was unable to regain flying speed and it fell in from about 2 meters, breaking both wheels.
He says that all major airframe components were undamaged apart from the gear. The tone of his post sounds a bit embarrassed, but this is exactly the sort of accident that can happen to any one of us in a field landing.
Old September 2nd 19, 08:30 AM posted to rec.aviation.soaring
Tim Taylor
From tvn24, translated with Google:
Glider pilot and multiple world champion Sebastian Kawa was hospitalized after an accident during a competition in Italy. - Sebastian is feeling well and left the hospital at his own request - his father Tomasz Kawa informed on TVN24. The pilot's father explained that the bad weather on the Apennine Peninsula had contributed to the accident. It is about the storms occurring there, which impede visibility during glider flight. - Storms closed Sebastian over an area where there are no landing places - he said. "It threw him into the air high over a dozen meters" - The glider has calculated emergency or accidental landings, but it was a very unfavorable system. Sebastian happily spotted a piece of grass-covered slope, but when he came in contact with the ground, and you need to land at an increased speed, about 130 kilometers per hour, he hit a kind of threshold on an aircraft carrier, threw him into the air a dozen meters high (... ) was in a vertical configuration, at an angle of about fifty degrees and hung without speed - he explained. - Luckily, this glider dropped symmetrically, but with such energy that the landing gear broke down, the hull was also damaged, the pilot was affected by the appropriate forces, but the athletic, young body somehow endured it and it's ok - he added. As Tomasz Kawa said, medical aid "had no chance" to get to the scene of the accident. The glider and pilot were downloaded by themselves, and then Kawa went to the hospital. Multiple world champion in gliding 46-year-old Sebastian Kawa is the most successful pilot in history. He has a dozen or so world championship titles, as well as, among others, two gold of the World Aviation Games and seven European championship titles. Author: mjz // kg / Source: tvn24 (http://www.tvn24.pl)
Old September 2nd 19, 01:05 PM posted to rec.aviation.soaring
Michael Opitz
hospitalized
af=
well
informed
Apennine=
occurrin=
Seba=
threw
h=
calculated
emerg=
Sebastia=
came in
conta=
about 130
k=
thre=
configurati=
explaine=
energy that
was
affec=
somehow
endured=
no
chance=
downloaded=
champion=
in
hist=
among
othe=
championship
ti=
The central mountain ridge system in Italy is tough for out landings.
The land has been handed down and subdivided among the heirs
over many generations, leaving mostly small fields available. The
ground is hard clay, and they plow it using bulldozers to pull the
plows. The clay is turned up in hard clay clumps about a foot in
diameter. When I flew in Rieti at the 1985 WGC, we had glider off
field landing carnage all over.
RO
Old September 3rd 19, 04:24 PM posted to rec.aviation.soaring
I had to land on an altiport in France with my Ventus 2B. My landing was hard and bent the axel and the immediate supporting struts. Fortunately, no other damage to the aircraft.
Landing uphill is more difficult than one thinks due to the visual illusion of being too high and overflying the field. I pulled full landing flaps and reduced speed as to not overfly the field. Result: never made the field proper, landed in the rough before the field. With the angle of descent being so steep and the field rising upwards, the impact was more of a collision than a forward roll. Blew the tire on impact. Fortunatedly, there was a very experienced metal worker at the field and he had me up and running in two days !
Possibly, training to land on altiports with a flight simulater is what one should do if flying such terrain with minimal outlanding possiblities.
Old September 2nd 19, 10:03 AM posted to rec.aviation.soaring
krasw
Link?
Seen it million times during big competitions, flying into unlandable terrain trusting you find next thermal or engine works. Of course everything is fine 99% of the time. And then bad day happens and you end up with that 1%. It shouldn't and definately doesn't happen to anyone of us, if you follow the very basic principle of all gliding flights: YOU GOT TO HAVE A PLACE TO LAND. This is hammered so hard to the brains of every flight student that it takes hundreds of flight hours to forget.
Old September 2nd 19, 12:00 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Link?
Mr Kawa is an awesome pilot. If he can make a mistake anyone of us can too. Maybe we should all take a few moment stand down and ask ourselves, have we attempted an engine start not over laudable terrain, have we flown into a corner with only one option that must work or else?
Old September 2nd 19, 09:26 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
krasw wrote on 9/2/2019 2:03 AM:
I don't think we should assume he intentionally flew out reach of landable
terrain. The remarks quoted by Tim Taylor suggest the weather changed much faster
than expected, leaving him with only poor choices.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Avro Tudor pics 2 [04/13] - Avro Tudor rough landing.jpg (1/1) Miloch Aviation Photos 0 September 11th 17 03:38 PM
Martin PBM Mariner pics 2 [09/15] - Martin-PBM-Rough-Landing.jpg (1/1) Miloch Aviation Photos 0 August 13th 17 03:04 PM
Kawa..... [email protected] Soaring 34 August 11th 14 07:43 PM
Kawa [email protected] Soaring 3 December 2nd 13 06:26 PM
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) Kyler Laird General Aviation 0 March 1st 04 12:11 AM
