#121
![]() . So everything coming from abroad is seen as bad. I am sitting here in front of my imported computer, sitting on my imported chair, drinking my imported coffee, and not believing what I am reading! I don't know for sure, but I suspect that every stitch of clothing I am wearing was imported too. When I drive to the end of the road to fetch the newspaper (that is probably largely an American product) I will be using an automobile that, while built in Maryland, bears a foreign mark. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
#122
On Mon, 25 Jul 2005 02:46:05 GMT, Repo Man wrote:
Did you manage to comprehend ANYTHING I wrote? I doubt that he did, because it was garbage. Ahistorical garbage. Mindless, paranoid garbage. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
#123
Thomas Borchert wrote in
: Yes, but the American look at mileage is worlds apart from a European look at mileage. Europeans don't look at Mileage. They look at Kilometerage. |
#124
Judah wrote:
Europeans don't look at Mileage. They look at Kilometerage. Actually, they look at Literage. Liters per 100 km, that is. But then, last I checked my map, Great Britain was still European, too. Stefan |
#125
AH! That's where you're wrong! The Brits do not consider themselves to be
part of Europe either geographically or politically. They are a seperate and sovereign nation which just happens to adhere to the EU regulations. I made the mistake when I first moved here of thinking I was in Europe. I was quickly set straight. Which leads to some funny anomolies here in the UK. Everything is metric except for two measurements. Beer is still sold in pints (thank God for that!). Road distance is still measured in miles but fuel is sold in liters. Brits still talk about miles per gallon (Imperial, mind, not US) but I've started thinking about gas economy in terms of miles per liter because the math is easier. A bit bizarre but you soon get used to it. You gotta love the quirkiness of this place! Shawn "Stefan" wrote in message ... Judah wrote: Europeans don't look at Mileage. They look at Kilometerage. Actually, they look at Literage. Liters per 100 km, that is. But then, last I checked my map, Great Britain was still European, too. Stefan |
#126
Peter Duniho wrote:
I've always wondered about the reasoning behind that as it just doesn't make sense. In some cases when they first started this and maybe even now, they reduced the ppm by actually increasing the total amount produced. I think you are mistaken there. Emissions are mesured in ppm, because it's the only possible way, you can't collect the NOx from an exhaust stream and put it on a scale. I believe the ppm-measurement is done by gas chromatography. However, from the ppm and the total mass flow, you can easily calculate the total weight of NOx emitted, and that is the figure that has to be within certain limits to meet emissions standards, as you can see he http://www.dieselnet.com/standards/us/light.html (Actually the limits are gramm-per-mile, but as the emissions test cycle is a defined distance, this amounts to the same.) Having said that, there are different emission gramm-per-mile figures for different classes of vehicles, a light duty truck is allowed much higher (absolute) emissions than a passcar for the same emission standard. A test that measures absolute emissions would effectively be measuring the fuel efficiency of the car, along with the usual emissions control hardware. Instead, we have rules that require manufacturers to have a certain average fuel efficiency across their sold product, with each one having to meet specific relative emissions requirements. the fuel consumption for a given test cycle is actually calculated from the emission values, not measured by any sort of flow device. Yet the by far strongest correlation is between CO2 and fuel consumption. The correlation between emissions NOx, CO and HC (the unwanted stuff) and fuel consumption is very weak. Differences in the behavior of combustion and aftertreatment are much stronger between vehicles than an influence of the fuel consumption. After all, the nasty stuff makes up for less than 1% of the total mass flow. The correlation between CO2 and fuel consumption on the other hand is so strong, that CO2 is used INSTEAD of fuel consumption at least in Europe. IMHO, the current system is actually pretty reasonable, and would be made much more reasonable with the use of high gas taxes. That is, measuring relative emissions ensures that all vehicles sold are playing at the same level (ignoring for a moment that different limits are applied to different vehicles ![]() emissions of pollutants. In other words, testing emissions is not directly related to trying to limit emissions. Rather, it's to ensure that all vehicles are producing about the same amount of pollutants for a given amount of fuel consumed. Now if we could just change the way fuel is consumed, we'd be in business. ![]() We'd be if emissions levels were in ppm indeed. Still the main problem would be, that you cannot account for different emission standards. If you tax fuel in order to really tax the emissions behind it, you'd have to fix different pump prices for LEV, LEVII, ULEV, which is just not practical. (Of course you SHOULD increase fuel taxation nevertheless, to bring the CO2 down...) regards, Friedrich -- für reply bitte die offensichtliche Änderung an der Adresse vornehmen |
#127
Roger wrote:
You will find that many of our engines run rich to keep the combustion temperature low and then have to pump air into the catalytic converter so the excess can be burned. I hope not :-)) That would be a sure way to burn out your catalyst. Gasoline engines do run rich however at high load conditions, which are not met during emission cycles. But the excess fuel turns into CO instead of CO2 (thus burning more fuel with less O2) or even goes down the exhaust pipe unburnt. Noone cares, at it will never be measured. This is one of several reasons, why the ongoing tightening of emission standards has become a joke by now. The only conditions, when so called scondary air is pumped into the (rich) exhaust is at fairly light loads during warmup. This is done to get the catalyst to its operating temperature range more qickly. At least a good portion of the reason for poorer mileage over here is due to some specific anti-pollution measure. There is a slight influence, but it's not a big deal. regards, Friedrich -- für reply bitte die offensichtliche Änderung an der Adresse vornehmen |
#129
On Mon, 25 Jul 2005 06:43:48 -0400, Cub Driver
wrote: . So everything coming from abroad is seen as bad. I am sitting here in front of my imported computer, sitting on my Hey! My Computer is 100% American... well as much as GM, Ford, or Chrysler. The motherboard came from china, the drives from Taiwan, Singapore, and Japan. HOWEVER the Silicon in most of the chips came from Michigan. The RAW Silicon was made here. The poly crystal was shipped to Taiwan where it was made into single crystal and then cut into wafers. The chips? Mostly Japan and Taiwan although more and more are coming from China. My Router (D-Link) was made in China, along my Link-Sys stuff. I didn't find any networking components, regardless of brand that weren't made in China. BUT it was 100% assembled here. Right here in my den with no outsourcing. Albeit the software comes from all over the world and the US companies are importing programmers from India. Still it (there are 4 of them) was assembled, configured, and put into operation here in the US. I don't think there is a TV set made in the US any more. imported chair, drinking my imported coffee, and not believing what I am reading! I don't drink coffee! I don't know for sure, but I suspect that every stitch of clothing I am wearing was imported too. Probably by child labor in sweat shops. When I drive to the end of the road to fetch the newspaper (that is probably largely an American product) I But in a plastic Chinese mail box? I actually have a steel, US manufactured mail box from US steel. Of course it's flanked by one for the paper and one for the shopping guide that are of Chinese plastic. will be using an automobile that, while built in Maryland, bears a foreign mark. Even if you purchased an American brand car you will find many parts in it came from other countries. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
#130
Nothing like a cold splash of 100LL in the face to wake up a pilot | Peter R. | Piloting | 20 | October 1st 04 11:25 PM |
Future of 100LL? | Michael | Owning | 0 | August 2nd 04 09:29 AM |
Future of 100LL? | Michael | Piloting | 0 | August 2nd 04 09:29 AM |
How blue is 100LL? | Ben Jackson | Piloting | 26 | May 1st 04 11:10 AM |
When was the switch to 100LL? | Roger Long | Piloting | 0 | August 21st 03 11:01 AM |
