IFR use of handheld GPS
Old May 7th 06, 05:43 PM posted to rec.aviation.ifr
Default IFR use of handheld GPS
"Sam Spade" wrote in message
news:Ygp7g.175614$bm6.138484@fed1read04...
As they probably find you to be a bit closed-mind.
You'll never find anyone more open-minded than me.
  #122
Old May 7th 06, 05:45 PM posted to rec.aviation.ifr
news:Wip7g.175615$bm6.36868@fed1read04...
You are either stupid or stubborn, or perhaps both.
I am neither.
The AIM reference is explanatory.
The AIM is not regulatory.
The 8260-16, when describing Federal Airwaty V-XXX, which is formed by VOR
facilities, is regulatory.
Irrelevant to the subject under discussion.
  #123
Old May 7th 06, 05:46 PM posted to rec.aviation.ifr
news:Cjp7g.175616$bm6.42955@fed1read04...
Not so. You just can't read with any objectivity.
Are service volumes based on AGL or MSL altitudes?
  #124
Old May 7th 06, 05:47 PM posted to rec.aviation.ifr
newskp7g.175617$bm6.114407@fed1read04...
That is pure bull****. You brought up AGL, not me. I was referring to
7110.65, not the AIM.
You brought up service volumes. Are service volumes based on AGL or MSL
altitudes?
  #125
Old May 7th 06, 05:48 PM posted to rec.aviation.ifr
news:Pkp7g.175618$bm6.124940@fed1read04...
And, it's Stevie's assertion.
Please provide a quote of Stevie asserting that.
  #126
Old May 7th 06, 06:46 PM posted to rec.aviation.ifr
k.net...
"Dane Spearing" wrote in message
So, the initial purpose of this thread was to discuss whether or not one
could use a handheld GPS for IFR navigation. Lots of people have been
tossing around lots of opinions with little or no references to rules or
guidance to back them up (hardly surprising...this is usenet after
all...)
Anyway, for my own personal edification and enlightenment, I went and
tracked down the official FAA Advisory Circular that specifies what
the requirements are for the use of GPS under IFR. It's entitled
"Airworthiness Approval of Navigation or Flight Management Systems
Integrating Multiple Navigation Sensors", and is FAA AC 20-130A.
It's about as exciting to read as the dictionary (again, hardly
surprising). However, the Gleim Instrument Pilot Flight Manueuvers and
Practical Test Prep guide (which is where I found the reference in the
first place) does a nice job of summarizing the requirements for use of
GPS under IFR as specified in AC 20-130A. It states:
Authorization to conduct any GPS operation under IFR requires that:
a) GPS navigation equipment used must be FAA-approved and the
installation
must be done in accordance with FAA requirements
i) Approval for the use of the GPS for IFR operations, and any
limitations, will be found in the airplane's POH (also called
the FAA-approved Airplane Flight Manual) and the airplane's
logbook
ii) VFR and hand-held GPS systems are not authorized for IFR
navigation, for instrument approaches, or as a principle
instrument flight references. During IFR operations, they
may be considered only an aid to situational awareness.
Aircraft using GPS navigation equipment under IFR must be equipped with
an
approved and operational alternate means of navigation appropriate to the
flight.
a) Active monitoring of the alternative navigation equipment is not
required
if the GPS receiver uses RAIM for integrity monitoring.
b) Active monitoring of the alternative navigation equipment is required
when the RAIM capability of the GPS equipment is lost.
This seems fairly clear to me.....
Did you read the first paragraph of AC 20-130A? The third sentence is
most
revealing:
1. PURPOSE. This advisory circular (AC) establishes an acceptable means,
but
not the only means, of obtaining airworthiness approval of multi-sensor
navigation or flight management systems (hereafter referred to as
multi-sensor equipment) integrating data from multiple navigation sensors
for use as a navigation system for oceanic and remote, domestic en route,
terminal, and non-precision instrument approach [except localizer,
localizer
directional aid (LDA) and simplified directional facility (SDF)]
operations.
This document does not address systems incorporating differential GPS
capability. Like all advisory material, this AC is not mandatory and does
not constitute a requirement. As such, the terms "shall" and "must" used
in
this AC pertain to an applicant who chooses to follow the method
presented.
The criteria of AC 90-45A, Approval of Area Navigation Systems for Use in
the U.S. National Airspace System, does not apply to certification of
equipment described in this AC. This AC supersedes previous GPS
installation
guidance contained in: FAA Notice 8110.48, Airworthiness Approval of
Navigation or Flight Management Systems Integrating Multiple Navigation
Sensors, and FAA Interim Guidance Memoranda dated February 25, 1991; April
5, 1991; March 20, 1992; July 20, 1992; and September 21, 1993. The
appropriate information contained in those documents is incorporated in
this
AC.
Here's another little gem from the Advisory Circular Checklist, AC No.
00-2.15:
3. Explanation of the AC system. The FAA issues advisory circulars to
inform
the aviation public in a systematic way of non-regulatory material. Unless
incorporated into a regulation by reference, the contents of an advisory
circular are not binding on the public. Advisory circulars are issued in a
numbered-subject system corresponding to the subject areas of the Federal
Aviation Regulations (FAR) (Title 14, Code of Federal Regulations, Chapter
I, Federal Aviation Administration); and Chapter III, Commercial Space
Transportation, Federal Aviation Administration, Department of
Transportation, Parts 400-450. An AC is issued to provide guidance and
information in a designated subject area or to show a method acceptable to
the Administrator for complying with a related Federal Aviation
Regulation.
Its amazing the things one can learn if one actually knows how to read.
Perhaps a reading and writing test should be part of the basic pilot's
license?
  #127
Old May 7th 06, 06:50 PM posted to rec.aviation.ifr
news:5Gm7g.175502$bm6.155268@fed1read04...
news:z%g7g.175498$bm6.169019@fed1read04...
Where is your reference that GPS is primary for sole means en route
navigation?
I don't need one. The burden of proof is on those that claim it's use is
prohibited. It's up to them to cite the FAR that prohibits such use.
That is a giant load of crap.
It seems like a basic tenet of the law to me. Where did you learn how to
follow rules that don't exist?
  #128
Old May 7th 06, 06:54 PM posted to rec.aviation.ifr
k.net...
How so? Is it your position that everything is illegal until a law is
enacted making some activity legal?
I've seen this leap of illogic before. It us usually uttered by a desperate
man who finds himself argued into a corner and is beginning to realize that
his own prejudices, opinions, feelings and beliefs do not have the force of
law.
Next you might hear him try to claim that it has the force of law because
"that's the way we have always done it".
  #129
Old May 7th 06, 06:56 PM posted to rec.aviation.ifr
"Ted" wrote in message
ink.net...
license?
Perhaps. Being able to read, speak, write, and understand the English
language is a requirement, apparently it's just assumed that applicants meet
it.
  #130
Old May 7th 06, 07:07 PM posted to rec.aviation.ifr
Default IFR use of handheld GPS - everyone brace yourselves... here comes Sam's foul mouth
...That is pure bull****....
...You are either stupid or stubborn...
Sam, does your mother wash your mouth out with soap when you try and use
that language in front of her?
Are you losing your grip, Sam?
Perhaps you should take some valium and relax a bit before you attempt to
continue this legal discussion as you are clearly overwhelmed by those who
disagree with you?
HANDHELD RADIO [email protected] Soaring 22 March 17th 16 03:16 PM
Navcom - handheld VS panel ? [email protected] Home Built 10 October 31st 05 08:08 PM
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 04:01 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
