#121
"Chad Irby" wrote in message
om... In article , "Paul J. Adam" wrote: In message , Chad Irby writes In article , "Paul J. Adam" wrote: If that were true, then we'd have binned Eurofighter in 1994 and leased F-16s instead. Seriously examined and pushed quite hard. ...and bought for a small advantage, for (at least in part) political reasons. No, because it would be significantly less capable for not much less money. The F-16 is a provably superb aircraft but its design is thirty years old and it's running out of growth room. You should remember, though, that the Eurofighter's design is over twenty years old. That's not true. Twenty years ago we had the Anglo-French EFA flying around, but that wasn't a Eurofighter. The Eurofighter was planned to fly in 1992, and to enter squadron service in 1999. The final design for production aircraft was actually frozen only four years ago. Matt |
#122
writes In article , "Paul J. Adam" wrote: One of the reasons the Eurofighter's late is... significant changes to the original design, as newer technologies came along (the RCS reduction program being one example). But those involved fairly minor changes (the "low RCS program" mostly consisting of sticking some RAM in the intake), not major design issues. Would that it were so simple. "Sticking some RAM in the intake" merely results in a FOD hazard: how do you shield the compressor blades? -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#123
"Paul J. Adam" wrote: In message , Chad Irby writes But those involved fairly minor changes (the "low RCS program" mostly consisting of sticking some RAM in the intake), not major design issues. Would that it were so simple. Actually, it was. A layer of RAM in the intake channel, and most of the radar return went away. Look at some cross sections of the plane, and note where the airflow goes to get to the engine. "Sticking some RAM in the intake" merely results in a FOD hazard: how do you shield the compressor blades? By using the normal turns in the intake. As for the FOD hazard: it shouldn't exist, if you fasten everything correctly, and no more so than normal aircraft structure. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#124
writes In article , "Paul J. Adam" wrote: But those involved fairly minor changes (the "low RCS program" mostly consisting of sticking some RAM in the intake), not major design issues. Would that it were so simple. Actually, it was. I'll take the designers opinion on the issue, thanks. A layer of RAM in the intake channel, and most of the radar return went away. After reshaping the intake, sure. "Sticking some RAM in the intake" merely results in a FOD hazard: how do you shield the compressor blades? By using the normal turns in the intake. Those "normal turns" didn't figure in the design baseline and were a 1990s addition. -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#125
"Paul J. Adam" wrote: I'll take the designers opinion on the issue, thanks. Better yet, look at the friggin' plane and read their website. It was a minor redesign of the intake and addition of RAM. It doesn't take much to drop that one area's RCS by a *lot*. A layer of RAM in the intake channel, and most of the radar return went away. After reshaping the intake, sure. Not by much, though, and mostly enlarging it a *little* to allow for a bit more thickness due to the RAM. They did little more than the USAF did with the F-16... -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#126
writes In article , "Paul J. Adam" wrote: I'll take the designers opinion on the issue, thanks. Better yet, look at the friggin' plane and read their website. Right. I talk to the design engineers, you read a website. Fuurfu. It was a minor redesign of the intake and addition of RAM. It doesn't take much to drop that one area's RCS by a *lot*. Also doesn't tale much to choke the engine or give it some nasty habits at high AoA. (Remember how much fun the F-111 had with inlet design, and that wasn't even trying for low RCS?) After reshaping the intake, sure. Not by much, though, and mostly enlarging it a *little* to allow for a bit more thickness due to the RAM. With what knock-on effects elsewhere...? Where's the "reduced RCS" field modification for the F-15 or F-16, if it's such a simple change? -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#127
"Paul J. Adam" wrote: Right. I talk to the design engineers, Suuure you did. In the minutes between reading my post and replying to it. On a Saturday. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#128
writes In article , "Paul J. Adam" wrote: Right. I talk to the design engineers, Suuure you did. In the minutes between reading my post and replying to it. On a Saturday. No, two years ago up at Farnborough. -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#129
"Paul J. Adam" wrote: In message , Chad Irby writes In article , "Paul J. Adam" wrote: Right. I talk to the design engineers, Suuure you did. In the minutes between reading my post and replying to it. On a Saturday. No, two years ago up at Farnborough. ....and they spent a lot of time telling you about the specific problems they had with the intake design... "Oi, we had some problems with the intake, eh, Herbie?" "No foolin. First, Mikey here forgot to take the foil wrap off of the RAM panels, and it lit up like a fookin' flare when we hit it with a signal, then after we fixed that, Jimmy (God rest his soul) put the engine in backwards after a six-pint lunch. Pain in the fookin' arse, that intake was..." -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#130
writes In article , "Paul J. Adam" wrote: In message , Chad Irby writes No, two years ago up at Farnborough. ...and they spent a lot of time telling you about the specific problems they had with the intake design... Well, I was an employee of the same company, interviewing them towards a Masters' in systems engineering (sponsored by that company), and they had some strong viewpoints about the cost of late changes to design versus the need to keep a design up to date when the program slipped to the right that were very relevant to my dissertation. So, yes, we had an interesting discussion. -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
Similar Threads | ||||
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________-+__ ihuvpe | Chris | Instrument Flight Rules | 43 | December 19th 04 09:40 PM |
About French cowards. | Michael Smith | Military Aviation | 45 | October 22nd 03 03:15 PM |
Ungrateful Americans Unworthy of the French | The Black Monk | Military Aviation | 62 | October 16th 03 08:05 AM |
American planes are crap! | Peter Mollror | Military Aviation | 20 | October 7th 03 06:33 PM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
