Pitch vs. trim in flight phases
Old May 16th 08, 07:00 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Pitch vs. trim in flight phases
In a small GA aircraft, in which phases of flight will you normally use mostly
trim to adjust pitch, and in which phases will you normally mostly use the
yoke?
Old May 16th 08, 01:01 PM posted to rec.aviation.piloting,rec.aviation.student
Dudley Henriques[_2_]
yoke?
You adjust pitch and hold that pitch, then trim. The general "rule" is
nose attitude, adjust power, trim the airplane.
Dudley Henriques
Old May 16th 08, 06:55 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_3_]
Mxsmanic wrote:
In a small GA aircraft, in which phases of flight will you normally use mostly trim to adjust pitch, and in which phases will you normally mostly use
the yoke?
Good question for r.a.s.
You don't want to use the trim to adjust pitch, just to relieve the
control pressure. Electronic trim switches mounted to the yoke are a
bad habit waiting to happen; they're disabled in a lot of training
aircraft. Always remember "Pitch, power, trim."
The Airplane Flying Handbook, FAA-H-8083-3A, states:
"The pilot must avoid using the trim to establish or correct airplane
attitude. The airplane attitude must be established and held first, then
control pressures trimmed out so that the airplane will maintain the
desired attitude in 'hands off' flight. Attempting to 'fly the airplane
with trim tabs' is a common fault in basic flying technique even among
experienced pilots."
It's important for the pilot to feel the elevator pressure whereas with
a trim tab you're delegating that to mechanical authority.
Also, if you get out of the habit of knowing where your trim is set, you
increase the likelihood of approaching an elevator trim stall in a
missed approach or go-around. This can be demonstrated pretty well in
MSFS2004--I think in the Mooney--by adjusting the elevator trim as if
you were in full-flaps landing configuration and then adding full power;
back-elevator trim will cause a radical nose-up pitch, exceeding the
critical angle of attack. To avoid elevator trim stall the pilot must
exert a great deal of forward pressure on the nose -and- retrim the
airplane, and it has to be brisk and smooth. Whether by hand or
electric motor, controlling it by trim is too slow.
-c
Old May 16th 08, 07:51 PM posted to rec.aviation.piloting,rec.aviation.student
Ken S. Tucker
On May 16, 9:55 am, gatt wrote:
the yoke?
-c
Quick question, (it's been awhile since I've piloted)
is the trim (Cessna 152) in the center, right of the
pilot, and has zero mark to be set null in pre-flight?
Personally I had real friggin hassle with trim. I'd get
to 4000' set a course for x-country, maybe an hour
away, set cruise, then touch-up trim, to relieve yoke
control. Well it never really worked for me.
As soon as I thought I had it right, by Descent Indicator
(no jokes guys, women of the opposite sex might be lurkin)
would start wandering off zero.
My habit became, set Trim slightly down and use my
pinky pressure back on the yoke to keep my Descent
Indicator at zero, with an occasional glance so I could
enjoy the view and work nav.
Ken
PS: Kens Rule: Use your pinky to stop being InDescent,
and use the rest of your fingers anyway you want.
Old May 16th 08, 08:49 PM posted to rec.aviation.piloting,rec.aviation.student
More_Flaps
the yoke?
control pressure. *Electronic trim switches mounted to the yoke are a
aircraft. *Always remember "Pitch, power, trim."
missed approach or go-around. *This can be demonstrated pretty well in
critical angle of attack. *To avoid elevator trim stall the pilot must
airplane, and it has to be brisk and smooth. *Whether by hand or
-c
is the trim (Cessna 152) *in the center, right of the
It's also around the windows and other edges. Hope this helps your
understading what you are seeing on your computer screen.
Cheers
Old May 16th 08, 09:19 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_3_]
Correct. (Well it has a "takeoff position" which is more or less center.)
In the '74 PA-28R I rent it's between the seats and harder to see, and
takeoff position is about "a quarter-inch back" on the slot since
there's no visible mark. I don't like the trim-wheel there. The first
time I flew in the right seat and reached for the trim handle I cracked
my knuckle against the door.
-c
Old May 16th 08, 09:49 PM posted to rec.aviation.piloting,rec.aviation.student
Ken S. Tucker
Ok thanks.
I was ok with the location of the trim wheel, but the adjustment
was too coarse for me, but I could be a bitchy sissy.
My wheel was graduated, with a zero mark and did not quite
give the fine adjustment I wanted. That could be cables out
to the tail, I should have learned the mechanism!
Regards
Ken
Old May 17th 08, 12:23 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_25_]
"Ken S. Tucker" wrote in
you normally mostly use the yoke?
then control pressures trimmed out so that the airplane will maintain
the desired attitude in 'hands off' flight. Attempting to 'fly the
airplane with trim tabs' is a common fault in basic flying technique
even among experienced pilots."
with a trim tab you're delegating that to mechanical authority.
you increase the likelihood of approaching an elevator trim stall in
a missed approach or go-around. This can be demonstrated pretty well
in MSFS2004--I think in the Mooney--by adjusting the elevator trim as
if you were in full-flaps landing configuration and then adding full
power; back-elevator trim will cause a radical nose-up pitch,
exceeding the critical angle of attack. To avoid elevator trim stall
the pilot must exert a great deal of forward pressure on the nose
-and- retrim the airplane, and it has to be brisk and smooth.
Whether by hand or electric motor, controlling it by trim is too
slow. -c
Ken
Descent indicator?
You're a moron.
Bertie
Old May 17th 08, 01:07 PM posted to rec.aviation.piloting,rec.aviation.student
Benjamin Dover
Bertie the Bunyip wrote in
slow. -c
Ken
Descent indicator?
You're a moron.
Bertie
Hey Bertie, maybe Ken will set the bow planes for emergency dive and use
the depth meter to monitor his descent!
Old May 16th 08, 11:22 PM posted to rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Gatt,
Ah, another free source our local hotshot doesn't even bother to read.
Thomas Borchert (EDDH)
Typical power settings during cruise and other phases of flight Mxsmanic Piloting 99 October 2nd 06 11:12 AM
Making a pitch trim indicator for a Glasair [email protected] Home Built 5 September 13th 06 03:30 AM
$30,000 pitch links Stuart Fields Home Built 3 January 16th 06 03:13 AM
Cherokee Electric Pitch Trim Jonathan Goodish Owning 4 November 18th 04 03:43 AM
ALTRAK pitch system flight report optics student Home Built 2 September 22nd 03 12:49 AM
