#131
Seriously - 20 samples per second? Engineers put men on the moon with slide rules. You just don't need the kind of accuracy being touted these days.
The sensors used are not that well-behaved. Not very linear, noisy, etc. So you might actually need that 20Hz to produce a proper value at 1Hz. Many noisy measurements average out as one pretty good measurement. This has even been proven, by letting 1000 people guess the number of balls in a fish bowl. The average was spot-on. Also, fast sampling allows one to do all kinds of filtering in software which required analogue filters in the past. |
#132
What I have read on this forum has led me to think that the Butterfly is currently a decent vario in operation but nothing special. Can anyone with practical experience say different?
I surmise that the software engineers have not yet discovered what to do with all the data available to them. Since my LX 9000 has the optional giro box what data would it not have that would potentially make the Butterfly better? |
#133
At 17:34 13 February 2013, waremark wrote:
What I have read on this forum has led me to think that the Butterfly is currently a decent vario in operation but nothing special. Can anyone with practical experience say different? I surmise that the software engineers have not yet discovered what to do with all the data available to them. Since my LX 9000 has the optional giro box what data would it not have that would potentially make the Butterfly better? The very alluring Butterfly vario is using the sensor data but the concern that has stopped me choosing it so far is the importance for its performance of getting an accurate reading from the magnetometer. It is inside the main sensor box which has all the electrical and pneumatic connections and that makes it awkward to mount in a way that meets the installation manual's specifications for distance from electromagnetic field interference - especially in a retractable motor glider. Two friends have returned them because theye were unable to achieve this. I have the same worry about getting the similarly configured CN vario for the same reason - although it doesn't matter at present while the magnetometer is not used (AFAIK). The LX 9000 AHRS unit has "3 axis Gyros with MEMS technology and 3 axis digital +-6g accelerometer" according to the website. If the separate LX 9000 compass module is 3-axis(??) then including that along with the GPS in the 9000 and the pneumatic sensors from the V5 vario would appear to make it match the sensor mix of the Butterfly. Whether they could all be integrated to work as a full intertial sensor unit I have no idea - nor whether LX Nav have any plan to try to make it do so. The fact that the magnetometer is a separate box should make it easier to locate away from interference. John Galloway |
#134
On Wednesday, February 13, 2013 11:33:57 PM UTC+2, John Galloway wrote:
At 17:34 13 February 2013, waremark wrote: What I have read on this forum has led me to think that the Butterfly is currently a decent vario in operation but nothing special. Can anyone with practical experience say different? I surmise that the software engineers have not yet discovered what to do with all the data available to them. Since my LX 9000 has the optional giro box what data would it not have that would potentially make the Butterfly better? The very alluring Butterfly vario is using the sensor data but the concern that has stopped me choosing it so far is the importance for its performance of getting an accurate reading from the magnetometer. It is inside the main sensor box which has all the electrical and pneumatic connections and that makes it awkward to mount in a way that meets the installation manual's specifications for distance from electromagnetic field interference - especially in a retractable motor glider. Two friends have returned them because theye were unable to achieve this. I have the same worry about getting the similarly configured CN vario for the same reason - although it doesn't matter at present while the magnetometer is not used (AFAIK). The LX 9000 AHRS unit has "3 axis Gyros with MEMS technology and 3 axis digital +-6g accelerometer" according to the website. If the separate LX 9000 compass module is 3-axis(??) then including that along with the GPS in the 9000 and the pneumatic sensors from the V5 vario would appear to make it match the sensor mix of the Butterfly. Whether they could all be integrated to work as a full intertial sensor unit I have no idea - nor whether LX Nav have any plan to try to make it do so. The fact that the magnetometer is a separate box should make it easier to locate away from interference. John Galloway I thought exactly same about placement of Butterfly IMU. Separate magnetometer would be more convenient, as you have to route GPS antenna, three pneumatic tubes and CAN-bus to the box. AFAIK succesful installation requires quite a distance from *everything*. BTW common radio speakers don't have any magnetic shielding around speaker magnet, for some reason. Strong magnets can disturb compass as far as 1,5 metres away... |
#135
If the butterfly -- or clearnav, with future software -- did read out 3 d wind 20 times a second, this would be a big advantage. Not only could you detect lift long before F = MA gets the glider moving upward, you could tell upward gusts from forward gusts and sideways gusts. Dynamic soaring might even become possible, or at least better energy extraction from gusts. Even the 302 has the necessary sensors, my impression is that we're all waiting on the software development.
John Cochrane |
#136
On Thursday, February 14, 2013 12:58:13 AM UTC+2, wrote:
If the butterfly -- or clearnav, with future software -- did read out 3 d wind 20 times a second, this would be a big advantage. Not only could you detect lift long before F = MA gets the glider moving upward, you could tell upward gusts from forward gusts and sideways gusts. Dynamic soaring might even become possible, or at least better energy extraction from gusts. Even the 302 has the necessary sensors, my impression is that we're all waiting on the software development. John Cochrane I believe the inertial system needs to sort out the F=MA part before solving 3D-wind. Gyros and acceleration sensors don't measure vertical wind, they measure glider vertical movement. |
#137
#138
On Feb 14, 4:49*pm, John Galloway wrote:
At 22:58 13 February 2013, wrote: If the butterfly -- or clearnav, with future software -- did read out 3 d w= ind 20 times a second, this would be a big advantage. Not only could you de= tect lift long before F =3D MA gets the glider moving upward, you could tel= l upward gusts from forward gusts and sideways gusts. Dynamic soaring might= even become possible, or at least better energy extraction from gusts. Eve= n the 302 has the necessary sensors, my impression is that we're all waitin= g on the software development.=20 John Cochrane Regarding gusts, the Butterfly website (in FAQ) *already claims: "A conventional variometer uses changes in air pressure (TE- pressure, static- and total-pressure) to determine energy changes the aircraft experiences. Butterfly Vario does the same. Additionally it uses an inertial sensing platform that allows for real-time determination of airmass-movement and realtime determination of wind. With this technology a pilot can judge the difference between gust induced energy changes and thermal induced energy changes." John Galloway The Butterfly vario does not filter out gusts. The other sensors are used only to drive the blue ball that shows air mass movement. The pilot responsibility is to put the two together and decide what is a gust and what is lift based on the two sources of information. It is not a bad solution as one can learn the vario behavior. If algorithms are used to filter out gusts a pilot might have a difficult time to learn the vario behavior or understand what it is showing as an algorithm may have many paths covering many different scenarios behaving differently in different situations. Of course if algorithm is perfect that would not be a problem, but this is not an easy problem to solve. I assume it will be years before this happen mainly to extensive testing/feedback process that is required to develop and test these kinds of algorithms what works in theory might not be good in practice. So for the near future approach that Butterfly took is a good one, we need to see in practice how workable it will be. |
#139
After Argentina some competition pilots were quite disappointed
with the new variometers using acceleration to calculate lift. I have not tested myself, just telling their opinion. At 21:49 14 February 2013, John Galloway wrote: At 22:58 13 February 2013, wrote: If the butterfly -- or clearnav, with future software -- did read out 3 d w= ind 20 times a second, this would be a big advantage. Not only could you de= tect lift long before F =3D MA gets the glider moving upward, you could tel= l upward gusts from forward gusts and sideways gusts. Dynamic soaring might= even become possible, or at least better energy extraction from gusts. Eve= n the 302 has the necessary sensors, my impression is that we're all waitin= g on the software development.=20 John Cochrane Regarding gusts, the Butterfly website (in FAQ) already claims: "A conventional variometer uses changes in air pressure (TE- pressure, static- and total-pressure) to determine energy changes the aircraft experiences. Butterfly Vario does the same. Additionally it uses an inertial sensing platform that allows for real-time determination of airmass-movement and realtime determination of wind. With this technology a pilot can judge the difference between gust induced energy changes and thermal induced energy changes." John Galloway |
#140
On Thursday, February 14, 2013 3:19:21 PM UTC-7, Kimmo Hytoenen wrote:
After Argentina some competition pilots were quite disappointed with the new variometers using acceleration to calculate lift. I have not tested myself, just telling their opinion. At 21:49 14 February 2013, John Galloway wrote: If the butterfly -- or clearnav, with future software -- did read out 3 d w= ind 20 times a second, this would be a big advantage. Not only could you de= tect lift long before F =3D MA gets the glider moving upward, you could tel= l upward gusts from forward gusts and sideways gusts. Dynamic soaring might= even become possible, or at least better energy extraction from gusts. Eve= n the 302 has the necessary sensors, my impression is that we're all waitin= g on the software development.=20 John Cochrane Regarding gusts, the Butterfly website (in FAQ) already claims: "A conventional variometer uses changes in air pressure (TE- pressure, static- and total-pressure) to determine energy changes the aircraft experiences. Butterfly Vario does the same. Additionally it uses an inertial sensing platform that allows for real-time determination of airmass-movement and realtime determination of wind. With this technology a pilot can judge the difference between gust induced energy changes and thermal induced energy changes." John Galloway Not sure, but I suspect they are mixing frames of reference. In theory, the way to do this is solve the TE equations in the inertial and air-data domains separately then compare them. A gust will show up strongly in the air-data but less so in the inertial data so a computer - or a pilot - can tell the difference. A purely inertial vario will require a full IMU with GPS updating. These things are probably still too expensive for sailplanes but only just. |
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario | ufmechanic | Soaring | 0 | March 24th 09 05:31 PM |
Martin Mars, Performing Live In Downtown Vancouver! | Zomby Woof | Aviation Photos | 3 | January 20th 08 03:10 PM |
Martin Mars, Performing Live In Downtown Vancouver! | Zomby Woof | Naval Aviation | 2 | January 11th 08 06:10 PM |
Navy Performing Well, Keeps Eye on Future Force | Otis Willie | Naval Aviation | 0 | February 14th 05 10:06 PM |
AN-2 performing a loop | Maro_SK | Aerobatics | 1 | March 25th 04 08:18 PM |
