spaceship one
Old June 25th 04, 03:27 PM
Pete Schaefer
You gotta have control power sufficient to deal with the instability, plus
some for maneuvering. The M2-F2 ($6M Man) didn't have it. Fly-by-wire would
have done nothing for it; it was just a bad design. The M2-F3 (big center
vertical fin) flew much better due to adequate open-loop roll damping and
directional stability.
That crew return vehicle concept (X-38??) that was/is in the works was
basicallly a lifting body design. But that one used a steerable parachute
for final approach and landing. Not a bad trade, actually, when you
consider the weight cost of something like a deployable control/lift device.
This way, the shape can be optimized for controlled re-entry and initial
descent.
Pete
"Doc Font" wrote in message
So is it feasable at this time considering the advancements in computer
controls? Like the F-117 or F-16 are unstable without their computer
systems but they work because the computer constantly adjusts the
flight. Could they build an easy to fly lifting body now?
  #132
Old June 25th 04, 03:29 PM
Pete Schaefer
Ya know, for $6M these days, you'd only get powerpoint slides and promises
of a better/faster/stronger dude.
"Jim Carriere" wrote in message
I don't understand- they cancelled Dyna-Soar, took the money from that
budget, and used it put Steve Austin back together???
  #134
Old June 25th 04, 03:32 PM
Pete Schaefer
Hmmm...... Suborbital global high-speed strike concept? Maybe, maybe not.
What spinnoffs might come from the X prize venture Good question, I
can't think of any.
  #136
Old June 25th 04, 03:55 PM
anonymous coward
On Fri, 25 Jun 2004 04:14:25 -0700, ChuckSlusarczyk wrote:
In article , pacplyer says...
Yes, I believe you are correct Rich. Was listening to the 104.9 disk
jockey that was claiming this was the ten million dollar x-prize
attempt. But I believe you are correct on the plan. But if I was
Burt: I would have stuck in a couple of sand-filled mannequins and
claimed this was attempt #1 since it is so dangerous.
pac
If he did that he probably would not have made the altitude required. They
barely made it as it was due to a minor mechanical glitch.This flight proved the
systems and what adjustments must be made. JMHO
Has anybody made a guess as to how high spaceship 1 will be able to go
when it has passengers + a full rocket engine?
AC
  #137
Old June 25th 04, 05:56 PM
Big John
Dan
True story.
Guy in P-51 at low altitude (10K). Opened mask and lit a cigarette.
Oxy from mask caused cigarette to flare and burned his face.
Made me nervous about the cigars I used to smoke after we got airborne
with mask open just hanging by strap.
Used the flare gun port on left side of cockpit to get the ashes out
of cockpit. Just put cigar down near the hole and flick and poof they
were gone.
Would be interesting to see the specs on cockpit of SS1. Had to have
some pressurization and probably used pressure breathing in
conjunction to keep pilot awake/alive.
Big John
On 24 Jun 2004 02:01:07 GMT, (B2431) wrote:
Date: 6/23/2004 8:40 PM Central Daylight Time
Message-id:
Matt
My computer bombed so this may go as a dup?
I have thousands of hours in jet fighters breathing 100% oxy.
We had all kinds of electrical stuff in cockpit(s) and aircraft. High
power Radar, Radio's, etc., etc.
Big John
On Wed, 23 Jun 2004 18:28:37 -0400, Matt Whiting
Richard Lamb wrote:
In the aftermath of the Apollo 1 fire, NASA took a year (and $75 mil)
to redesign the space craft, mature their mental attitudes, and yes,
did come back with a much safer vehicle.
Yes, but I still wonder how anyone in their right might would use a
nearly pure oxygen atmosphere in a vehicle full of humans and electrical
equipment...
Matt
The difference is Apollo 1 was flooded with pure O2 where jet fighters push O2
from a LOX converter to a face mask. Big difference. The only electronics in
the mask is a microphone.
Having said that the electrical systems in Apollo 1 were poorly routed and
protected.
It was an accident waiting to happen.
Dan. U.S. Air Force, retired
  #138
Old June 25th 04, 06:45 PM
Dillon Pyron
On Fri, 25 Jun 2004 14:29:02 GMT, "Pete Schaefer"
I'll bet AOL spent more than $6M on their ad.
dillon
When I was a kid, I thought the angel's name was Hark
and the horse's name was Bob.
  #139
Old June 25th 04, 07:04 PM
Richard Lamb
Ron Wanttaja wrote:
Like I said on an earlier post, I don't have much background on re-entry
physics. But I think it's possible to deorbit going slowly at a fairly
shallow angle...you just have to time the deorbit burn properly.
Me either, Ron. And I don't think my Holiday Inn Express line is gonna
work on this one, either.
I thought I'd try to see if I could at least set the problem up.
Hey, it's only calculus, right? But I found nothing there I could get
hold of except the (obvious) arrogance of ignorance. Humbling...
For a body in motion, the first derivative gives the rate of change
in position per unit time (i.e.: speed = rate of change of position
per second)
If the object is accelerating, the second derivative gives the rate
at which the first derivative is changing, or the rate of change in
speed (acceleration = rate of change in position per second per second).
Third derivative gives the rate of change in acceleration (what the
physics guys call 'jerk' = rate of change of position per second per
second per second). Like the way an old car jerks if there is too
sudden a change is how it is accelerating.
Quoting Martin Gardner, "Beyond the third, higher order derivatives are
seldom needed. This testifies to the fortunate fact that the universe
seems to favor simplicity in it's fundamental laws".
BUT
Simplicity is relative.
On orbit, our ship is in steady state unaccellerated motion, right?
Well, not exactly.
Due to the curved path of the orbit there is an 'outward' centrifugal
force that is exactly opposed by the opposite 'inward' centripetal force
(of gravity).
So our steady state 'unaccelerated' motion is actually a _second_
derivative from the straight line path (ASSUMING the orbit path is
perfectly circular?).
therefore
Adding an acceleration to our _forward_ motion (second and third
derivatives) causes an immediate third derivative reaction of the
orbital
altitude, i.e.: motion inward (if slowing) or outward (if speeding up).
If I'm not too badly mistaken, we are up to the SIXTH derivative,
and still haven't accounted for any deviation that would result if the
acceleration vector is not EXACTLY aligned with the true orbital path
in both pitch and yaw.
Taking those into account, we are looking at the TWELFTH derivative
just to predict what's going to happen when we try to change speed.
If we are off in pitch, I think the end result would be an oscillation
in the the orbital path. Think about an AC electrical signal imposed on
a DC carrier.
If we were thrusting straight 'outward', the thrust pushes us to a highe
altitude that our orbital velocity will not be able to maintain.
As soon as the thrust is removed, and momentum decays, we will drop back
down, gaining inward momentum on the way, which will cause an
'undershoot'
of our previous altitude, which will again bleed off momentum until we
go back 'up', and over shoot again.
There is probably going to be a fairly strong damping effect that will
eventually (sota) stabilize at the original altitude, but I haven't a
clue
how to set THAT one up...
Sheesh! Rocket Science....
  #140
Old June 25th 04, 07:14 PM
Richard Lamb
Big John wrote:
Dan
True story.
were gone.
Big John
Message-id:
Matt
Big John
equipment...
Matt
protected.
Mike was wearing a standard military style oxygen mask, so the cockpit
had to
be pressurized. But what the cabin altitude was is anybody's guess.
Rihcard
Spaceship 1 hits 212,000 feet!!!!!! BlakeleyTB Home Built 10 May 20th 04 10:12 PM
