Battery switching without tears
Old April 18th 20, 04:49 PM posted to rec.aviation.soaring
jfitch
Default Battery switching without tears
On Friday, April 17, 2020 at 5:36:50 AM UTC-7, Martin Gregorie wrote:
On Thu, 16 Apr 2020 23:00:28 -0700, jfitch wrote:
On Thursday, April 16, 2020 at 10:27:48 AM UTC-7, 2G wrote:
On Thursday, April 16, 2020 at 9:29:50 AM UTC-7, jfitch wrote:
On Wednesday, April 15, 2020 at 11:36:35 PM UTC-7, 2G wrote:
On Wednesday, April 15, 2020 at 9:12:33 AM UTC-7, NM wrote:
On Tuesday, April 14, 2020 at 9:28:12 PM UTC-4, 2G wrote:
On Tuesday, April 14, 2020 at 6:38:00 AM UTC-7,
On Tuesday, April 14, 2020 at 9:31:13 AM UTC-4,
On Tuesday, April 14, 2020 at 1:25:55 AM UTC-4, Andy
Blackburn wrote:
I used Shottky diodes plus power resistors plus
capacitors. I'm no EE but I took enough circuits courses
to handle this problem. The Shottky diodes keep the
batteries from cross-discharging each other, the
capacitors keep the instruments powered when the switch
is disconnected from battery 1 and before it is connected
to battery 2 and the resistors keep the capacitors from
drawing too much current when you power them up since
they make the circuit (even with the diodes) look like a
direct short initially.
Andy
KISS. Just the two diodes (and no switch) should be
enough. Whichever battery is stronger (higher voltage)
would take the load. Automatically. No switching needed.
With the higher voltage of LiFePO4 batteries (relative to
lead-acid) the voltage drop in the diode is acceptable,
especially if it's the Schottky type.
Or, if you really want to remove the voltage drop in the
diodes, add an SPDT switch (perhaps one with also a
center-off position) IN PARALLEL to the diodes. No matter
which position that switch is in, both batteries will still
be connected. But the battery the switch leads to will
feed the avionics with no voltage drop since the switch
bypasses the diode on that side. The other diode will
meanwhile prevent current from going INTO the other
battery. The middle-off position (or no switch at all) is
the safest though, since if either battery develops a
shorted cell (or shorted or loose wiring, blown battery
fuse, etc) without your knowledge, it won't affect the
other battery and the avionics, thanks to the two diodes.
- Clarification: I meant a diode between each battery and the
avionics bus as a whole. Not separately for a specific
instrument.
I measured the inrush current once again and found that the
vertical of the scope was set for a 1X probe instead of the 10X
actually being used. This meant that the peak current was 90A
instead of 9A, which is a bit high. I added a 1.1 ohm resistor
and the peak current dropped to 6A. A simulation shows that a 2
ohm resistor drops it to 3A. This is a good value to use if you
have a 1A current drain as the voltage drop will be 2V. The
wattage of resistor is unimportant because so little energy is
being dissipated by the resistor. The energy transferred
remains constant regardless of the resistor value as it is the
energy required to charge the capacitor (the current pulse
lengthens for larger resistor values).
Tom
Tom,good plan to increase the value of the resistor to limit the
current inrush. One could even make the resistor 100 ohms and
have a reversed diode in parallel with it so that when the
capacitor is needed to sustain the instrument during switching,
the current would flow in the reverse direction through the
diode, bypassing the resistor. You now have the best of both
worlds - slow charge of the capacitor when the power is turned
on, and a fast discharge to support the instrument without IR
drop across the resistor, instead the drop would just be the bias
voltage of the diode.
I don't really think that the resistor is necessary, but offer it
to those that are overly concerned about the inrush current. The
bottom line is the energy that is transferred from the battery to
the capacitor heating the switch contacts. Switches have current
ratings to limit the temperature rise to tolerable levels when the
current is flowing continuously; this short current pulse will not
raise the switch contact temperatures to any significant level.
Remember, the SAME amount of energy will be transferred between the
battery and the capacitor REGARDLESS of the resistor value (joules
= C * V). This translates to the SAME amount of switch contact
heating. If you make the resistor insanely large so the time
constant is on the order of minutes, the heat will dissipate and
lower the maximum temperature. A better approach is to use a
smaller capacitor that still maintains voltage during switching.
Tom
The concern isn't heating in the switch contacts due to their
specified resistance. It is high current arcing during switching.
This can cause erosion of the contacts, in more extreme cases welding
them together. A 12V battery is quite capable of generating a vey
high energy arc, one can be used to arc weld steel. Arcs are peculiar
phenomena with negative resistance, not easy to measure their
presence or characteristics. All DC switched arc on make, the current
of the arc is limited by the impedance of the circuit - in this case
very low.
There is little mortal danger, the switch isn't going to catch fire
or explode. It probably will have a markedly shorter life. In the
worst case it may weld itself on one day. The capacitor may be the
easiest solution, but not the most elegant, and it may not be without
tears. The best solution is to parallel the batteries always so that
routine switching is unnecessary. This has higher reliability, will
result in longer battery life, and requires no operator action. If
circumstances make that impossible then as suggested above a select
switch shunted with diodes, followed by an on-off switch is safe,
zero energy loss, and keeps all components in spec.
As I have mentioned several times now, a small series resistor will
reduce the current down to acceptable levels. How many times must I
repeat this?
Tom
A small resistor will reduce the inrush current to the capacitor, but it
will also use power all day. A 1 ohm will reduce your effective battery
capacity by 8% - making the need for switching all the more likely!
How do you work that out?
There is no inflow to the capacitor once it is charged to the same
voltage as the prime battery. This happens when you first connect the
battery and set the switch to connect the prime battery to the panel.
Don't forget that the capacitor is on the PANEL side of the switch.
When you switch power over from prime to backup battery the capacitor
will discharge for a millisec or two when no battery is connected and the
capacitor is running the panel, followed by an equally quick inflow as
the backup battery tops up the capacitor to match its voltage.
If you want to be really picky, there will also be a very small outflow
from the capacitor: as the battery voltage slowly drops under load, the
capacitor will discharge slowly to match the battery voltage.
Martin | martin at
Gregorie | gregorie dot org
Martin, yes it was late at night and I was thinking (or not...) that he had put the resistor in the battery lead side of the circuit - which would of course be stupid. If in the capacitor lead, there is no ongoing energy loss.. Which is why I deleted the post within 15 minutes when rational thought returned.
The comment about arcing is generally true, whether you limit the inrush current to 90A or 9A. Switches arc even with resistive loads. It is a dominant failure mode of switches. Even at 2A, the life will be determined by contact erosion due to arcing. If you are switching 9A instead of the switch rating of 2A, you will reduce the spec'd life of that switch. Take an old one apart, take microphotographs of the contacts, and report back. The contact erosion from arcing will be obvious. Whether you see it on an oscilloscope will depend on many details of the setup. Again, the switch isn't going to burst into flames due to the capacitor - it just isn't the most elegant solution to the problem, or the most simple. The make before break scheme that JJ expounds is simpler and has less high current switching, but wiring all the batteries as one large bank is simpler, more reliable, and results in longer battery life.
  #132
Old April 18th 20, 08:07 PM posted to rec.aviation.soaring
2G
Andy
other battery and the avionics, thanks to the two diodes..
instrument.
Tom
Tom
very low.
repeat this?
Tom
Martin | martin at
Martin, yes it was late at night and I was thinking (or not...) that he had put the resistor in the battery lead side of the circuit - which would of course be stupid. If in the capacitor lead, there is no ongoing energy loss. Which is why I deleted the post within 15 minutes when rational thought returned.
Of course the resistor is in series with the capacitor, forming what is called a snubber circuit. "Snubber" means it snubs transients, which is what arcing produces. But there is no arcing as evidenced by the current waveform.. No wonder, the gap for a 12V circuit to arc is about 160 μinches. Switch manufacturers don't specify instantaneous current limits, only continuous currents. So the datasheet simply doesn't apply to instantaneous currents.
No, YOU should take apart an old part and take the microphotographs of switches you claim to have.
Here are high-speed videos of actual arcing:
https://www.arcsuppressiontechnologies.com/
Here is a demonstration of using a capacitor to suppress arcs:
https://www.youtube.com/watch?v=Xr5_gUrUZxY
  #133
Old April 18th 20, 11:28 PM posted to rec.aviation.soaring
Dan Marotta
I hear the arc from a bolt of lightening on my aircraft radio. Nothing
from flipping a battery switch...Â* In fact, there's not a switch in my
cockpit that causes the slightest crackle in my radio. Sure there's and
arc, but it is (to coin a phrase) a Tempest in a Teapot.
Andy
instrument.
Tom
Tom
very low.
repeat this?
Tom
Martin | martin at
Of course the resistor is in series with the capacitor, forming what is called a snubber circuit. "Snubber" means it snubs transients, which is what arcing produces. But there is no arcing as evidenced by the current waveform. No wonder, the gap for a 12V circuit to arc is about 160 μinches. Switch manufacturers don't specify instantaneous current limits, only continuous currents. So the datasheet simply doesn't apply to instantaneous currents.
Dan, 5J
Airplane tears off winglet on jet bridge a[_3_] Piloting 0 July 8th 10 08:06 PM
Tears in the eyes, - 1 attachment RobG Aviation Photos 4 June 17th 08 10:51 AM
The Tears Of Finding The Truth algaga Piloting 9 January 3rd 08 04:33 PM
“Particularly on May 19th”— with the tears of his father X98 Military Aviation 0 May 18th 04 10:34 AM
