#131
Can a Plane on a Treadmill Take Off?
"BDS" wrote in message m... "Michael Ware" wrote Yes, but an airplane isn't propelled by its feet. This is where everyone who seems to think that the airplane will fly is getting confused. The method of propulsion doesn't matter. You can drive an airplane down the runway by driving its wheels just like a car and it will still reach takeoff airspeed and fly briefly. The propeller is only important once you are airborne, because you need something to pull you through the air. And all this time, I thought it was the propellor that made the airplane move across the ground. I stand corrected. The bottom line is this - you cannot take off without first moving across the ground unless the wind (airmass movement relative to the ground) is blowing hard enough to give you sufficient airspeed to fly without moving. In this case, once you take off your airspeed will immediately begin to decrease unless you are using a prop to pull you through the air, or a tether to hold you there (relative to the ground). What do you mean, 'unless you are using a prop to pull you through the air'? How does your airplane work? Example - a floatplane is sitting in a river that is moving at 30 mph (hey, it's a fast river!). There is also a wind blowing down the river at 20 mph. If the floatplane is anchored and facing into the wind, it has an airspeed of 20 mph. If you release the anchor and use enough engine power to get the plane going through the water upstream at 30 mph you will be standing still with reference to the shore, and your airspeed will be 20 mph. If the river was flowing at a rate in excess of the maximum speed of your airplane, then you could never move forward going upstream with reference to the shore, and your airspeed would never exceed 20 mph, even at full throttle. If you fully understand this then you would know that you could shut your engine down, face downstream, and take off and fly briefly. This is not an anology. With the wheels turning on the treadmill, friction (and thus the force exerted) are negligible. The force exerted by the running water on the floats is much greater. BDS |
#132
"BDS" wrote in message m... "Michael Ware" wrote Yes, but an airplane isn't propelled by its feet. This is where everyone who seems to think that the airplane will fly is getting confused. The method of propulsion doesn't matter. You can drive an airplane down the runway by driving its wheels just like a car and it will still reach takeoff airspeed and fly briefly. The propeller is only important once you are airborne, because you need something to pull you through the air. The bottom line is this - you cannot take off without first moving across the ground unless the wind (airmass movement relative to the ground) is blowing hard enough to give you sufficient airspeed to fly without moving. In this case, once you take off your airspeed will immediately begin to decrease unless you are using a prop to pull you through the air, or a tether to hold you there (relative to the ground). Example - a floatplane is sitting in a river that is moving at 30 mph (hey, it's a fast river!). There is also a wind blowing down the river at 20 mph. If the floatplane is anchored and facing into the wind, it has an airspeed of 20 mph. If you release the anchor and use enough engine power to get the plane going through the water upstream at 30 mph you will be standing still with reference to the shore, and your airspeed will be 20 mph. If the river was flowing at a rate in excess of the maximum speed of your airplane, then you could never move forward going upstream with reference to the shore, and your airspeed would never exceed 20 mph, even at full throttle. If you fully understand this then you would know that you could shut your engine down, face downstream, and take off and fly briefly. BDS BUT... the initial condition, as stated in the OP, is that the river(conveyor) is moving at the same speed as the airplane but in opposite directions. So, with a 30 mph river(conveyor) and a 20 mph headwind the airspeed would be 50 mph. The plane is moving at 30 mph in the opposite direction with respect to the shore(runway). The airplane would then be travelling upstream at 60 mph relative to the rivers surface. The only difference between the river example and the conveyor example is how firmly the airplane is coupled to the conveyance. The floats/river scenario would require more thrust to overcome the resistance than the wheels/conveyor example. Same mathmatics, different numbers. The floatplane just needs a bigger motor. |
#133
#134
Flyingmonk wrote:
If you tie a 100 foot rope to the tail of an airplane (or some other part of the airframe), attach it to a good strong post, and run the propellor up to whatever rpm is available, is anyone claiming the airplane can then lift up say a feet off the ground? (Assuming the tail doesn't tear off) (and, a conveyor belt under the airplane is optional) Depends on the airplane, if a plane is built in such a way that it can actually attain enough lift just from the prop wash alone than yes. The Monk Yeah Monk that airplane is called a helicopter. |
#135
"The Flying Scotsman" wrote:
DONT BE STUPID.... IT CANNOT BE DONE !!! IF IT CAN BE THEN SOME CLEVER BUGGER 50 YEARS AGO WOULD OF DONE IT BY NOW.. plus, has anyone thought what will happen to that aircaraft if i does manage to generate enough lift..... ITS GOING TO HAVE NO AIRSPEED, stall and fall out of the sky like a brick. Simple physics lads... Ok, now suppose the treadmill is on the moon. . . (ducks) |
#136
However the airspeed-vs-wheel-rotation argument works out,
I think it is worth pointing out that all this time on the treadmill should result in a _significant_ loss of weight for the aircraft, resulting in more useful load. |
#137
Category and class of aircraft...
aircraft includes all types of flying machines. AIRPLANE does not include helicopters, see FAR Part 1 ASEL ASES AMEL AMES the A means category airplane and the rest is the class AMEL B747 includes the type. Rotorcraft is the category and helicopter is the class. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "601XL Builder" wrDOTgiacona@coxDOTnet wrote in message news:43E62B1E.6080403@coxDOTnet... | Flyingmonk wrote: | If you tie a 100 foot rope to the tail of an airplane (or some other | part of the airframe), attach it to a good strong post, and run the | propellor up to whatever rpm is available, is anyone claiming the | airplane can then lift up say a feet off the ground? | | (Assuming the tail doesn't tear off) | | (and, a conveyor belt under the airplane is optional) | | Depends on the airplane, if a plane is built in such a way that it can | actually attain enough lift just from the prop wash alone than yes. | | The Monk | | | Yeah Monk that airplane is called a helicopter. |
#138
"BDS" wrote:
"alexy" wrote If the conveyor keeps the airplane standing still relative to the ground, then it cannot take off. Yeah, but the original statement of the problem made no such claim. Alex - here is what the statement said: "An airplane on a runway sits on a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward. Does the airplane take off?" (Assuming the tires hold out, of course.) The plane cannot move forward - that means that it is standing still to me. If the plane does not move forward, how fast is the conveyor moving? Hint: "a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward." -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#139
On Sun, 5 Feb 2006 00:39:47 -0800, "Peter Duniho"
wrote: "Flyingmonk" wrote in message roups.com... Depends on the airplane, certain lpanes are built in such a way that they can actually attain enough lift just from the prop wash alone. Other than the ones we call helicopters, I've never heard of such a thing. Care to elaborate? I've been told that a Maule will do that. With a little wind, just apply power and it jumps into the air instantly. Similarly, in wind it'll land vertically. But then the Maule pilot who told me this was from Alaska, where airplanes routinely perform mythic feats. RK Henry |
#140
"Peter Duniho" wrote in message ... "Flyingmonk" wrote in message oups.com... Depends on the airplane, certain lpanes are built in such a way that they can actually attain enough lift just from the prop wash alone. Other than the ones we call helicopters, I've never heard of such a thing. Care to elaborate? Tilt wing... Osprey? Ducking and running! :' ) Joe Schneider 8437R ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Similar Threads | ||||
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
