Why don't voice radio communications use FM?
Old September 3rd 06, 05:23 PM posted to rec.aviation.piloting
Larry Dighera
Default Why don't voice radio communications use FM?
On Sun, 03 Sep 2006 13:39:09 +0200, Mxsmanic
wrote in :
Larry Dighera writes:
I would guess that noise-blanker and noise-limiting circuits are
incorporated in the current radio designs.
You can't actively remove noise over a radio channel because you have
no unique identifier of noise vs. information.
I believe you'll find Mr. Weir* will take issue with your statement
above.
Other than the occasional heterodyne squeal that occurs in the
receiver when two transmitters are transmitting on the same frequency
simultaneously, there shouldn't be any other noise. Ignition noise
should be suppressed by Faraday shielding, and generator/alternator
noise should be bypassed to ground.
Anything that isn't signal is noise. AM transmissions are fuzzy and
hard to hear. In fact, aviation AM radio is probably the noisiest
type of radio voice communication still in use. Most other types of
radio communication today are FM.
Where do you get these unsupported statistics?
What is the nature of the noise you are hearing? Can you describe it?
Is it a hum, pulses, growling, squealing, what?
White noise. It doesn't come from anything within the aircraft or
station.
Now we're getting somewhere. So that we are all on the same page,
here's a definition of White noise:
http://en.wikipedia.org/wiki/White_noise
[There's an audio sample here also, so you can actually hear it]
White noise is a random signal (or process) with a flat power
spectral density. In other words, the signal's power spectral
density has equal power in any band, at any centre frequency,
having a given bandwidth. White noise is considered analogous to
white light which contains all frequencies.
An infinite-bandwidth white noise signal is purely a theoretical
construct. By having power at all frequencies, the total power of
such a signal is infinite. In practice, a signal can be "white"
with a flat spectrum over a defined frequency band.
http://en.wikipedia.org/wiki/White_noise_machine
A white noise machine is a device that produces a sound that is
random in character, somewhat like air escaping from a balloon.
They generally do not produce actual white noise, which has a
harsh sound, but more often pink noise, whose power rolls off at
higher frequencies, or other colors of noise. They are often used
to protect privacy by masking distant conversations, say in a
psychiatrist's waiting room, and are also sold as sleep aids.
White Noise Machines produces a sound like the gentle whoosh.
Since the sound is absolutely constant but has no structure, the
brain simply tunes it out - just like you have tuned out the noise
from the fans in your computer. You hear the fans, but how often
do you actually notice them?
So, there is a hiss in your receiver when you listen to aviation
communications, and you find it masks intelligibility. Now that you
mention it, I suppose you are correct, because when I turn the Squelch
down, I hear a hiss. The volume of the hiss is much greater when
there is no radio signal present, because the AGC/AVC circuits are
operating at maximum amplification; when a radio signal is present,
that hiss is significantly diminished in volume to the point, that in
36 years of aviation experience, I've never found it an issue.
Perhaps the hiss to which you object is unique to your radio receiving
equipment. How many aviation radios have you had the opportunity to
listen to? Have you found the same objectionable hiss in all aviation
radio receivers you've used?
Regardless of when it occurs, there will ultimately be an additional
cost.
Sure, but one that companies and individuals can assume on a phased
basis at their convenience.
So you are proposing that the worldwide aviation community re-equip
all their aircraft and facilities with FM, and that all aviation
stakeholders bear the cost of those conversion, so that you won't hear
a hiss?
Do you really believe that what you propose will pay dividends
commensurate with its cost?
The fact that transponders and VORs exist today (when they did not in
the early days of aviation) proves that this works.
In the case of transponders, they were not necessary to operate within
the NAS. Anyone who believes that radio communication is not
necessary to operate within the NAS isn't operating in Class B, C, or
D airspace without prior permission, and the flight mission is not
really meaningful in the sense of accomplishing a meaningful result
like transportation.
In the case of VORs replacing Radio Range and NDBs, those are not
_two-way_ communications, so they are in a different class than
aviation radio communications.
Concurrent operation of differing radio based communication systems is
possible, but to concurrently operate two incompatible aviation
communication systems isn't practicable, because it would require
_all_ air and ground systems to be equipped with both AM and FM
equipment simultaneously and instantly. If not, FM transmissions
would not be received by those stations not equipped with FM
receivers, and vice versa.
For situational awareness, it is vital for all participants to know
what the others in the vicinity are doing by hearing their
instructions and intentions over the radio. For example, when I'm VFR
en route, and hear a military transport "cleared for the approach" to
an airport across whose instrument approach path I'm about to
traverse, although the transmission isn't directed to me, it provides
me with safety information that may be vital to my visually acquiring
conflicting air traffic.
You really should read the information at some of the links I provided
to get an idea of what has been tried, and what is on the FAA's
horizon regarding aviation communications. This topic has been very
thoroughly researched by government personnel and it's unlikely that
you will hit upon a superior system to what the professionals have
examined.
How much of aviation was designed by "professionals"?
You'll find it difficult to find a pilot who regards today's NAS as
armaturely designed. Are you familiar with TERPS?**
* http://www.rst-engr.com/rst/about_us...%20Engineering
http://www.faa.gov/about/office_org/...afs400/afs420/
  #132
Old September 3rd 06, 05:24 PM posted to rec.aviation.piloting
Emily[_1_]
Mxsmanic wrote:
Emily writes:
We haven't yet, in almost 100 years.
Cutting-edge technology is relatively new in its current profusion,
and there's always a first time. Will you bet your life on it?
Since our technology is used on most aircraft I fly on, I already do.
  #133
Old September 3rd 06, 06:59 PM posted to rec.aviation.piloting
Larry Dighera
On Sun, 03 Sep 2006 16:04:01 +0200, Mxsmanic
wrote in :
However, you're not supposed to listen to other pilots; you're
supposed to listen to controllers. All conversations are air-ground,
not air-air.
You'll have to cite a source for this nugget of knowledge.
FAA AIMs and CFRs make it pretty clear that communications involving a
controller are pilot-controller exchanges, not pilot-pilot exchanges.
While that may be true, it in no way relates to your statement quoted
above.
Stating "you're not supposed to listen to other pilots" is just plain
wrong. Pilots listen to other pilot transmissions to increase their
situational awareness.
Are you familiar with Common Traffic Advisory Frequency (CTAF)?
Yes, but it and similar schemes don't involve a controller, so
obviously the communication is between aircraft directly.
Thank you.
  #135
Old September 3rd 06, 08:25 PM posted to rec.aviation.piloting
Jim Logajan
Mxsmanic wrote:
Dan Luke writes:
******** again. I have a radio that does actively remove noise--it
has a button to turn the feature on and off, and it works quite well.
What kind of noise does it remove, and how does it distinguish noise
from signal?
One proven way to reduce noise is to repeat the signal N times and the
receiver adds up the repetitions and eventually the noise averages to zero
while the signal does not. Of course this is not what is done in practice
in real communications.
(I once wrote software for a Tunneling Electron Microscope (TEM) that did
the above - the target object is repeatedly scanned and the scans are
basically averaged - the noise falls off. Though IIRC, the amplitude of the
noise drops by a factor of 1/sqrt(N) for N scans. I'm too lazy to look it
up so that might not be the correct factor.)
  #136
Old September 3rd 06, 08:44 PM posted to rec.aviation.piloting
Mxsmanic
Emily writes:
The difference is, I never said I'd read it. YOU did.
A key to progress in debate is knowing what you are talking about.
What you actually say about what you know is irrelevant.
  #137
Old September 3rd 06, 08:45 PM posted to rec.aviation.piloting
Mxsmanic
Emily writes:
Show me the line where it says AM had anything to do with it.
All of the radio communication was AM.
  #138
Old September 3rd 06, 08:55 PM posted to rec.aviation.piloting
Mxsmanic
above.
He is welcome to do so.
a hiss?
I suggest that a less noisy method of communication be found and
implemented, so as to increase safety by improving the reliability of
voice radio communication.
Yes.
the NAS.
At one time, transponders were not needed at all. Then they were. So
obviously things can change.
They still require new equipment at both ends of the communications
link.
Why?
Since everything would be transmitted in both AM and FM by stations
equipped for FM, they would always be receivable by stations equipped
only for AM.
Which is one reason why things like message queuing are potentially
dangerous.
You can do even better by flying IFR, but you can also get by with
visual contact only. Every increment in technology ideally provides
an increment in safety, but it's best to avoid designing systems that
increment safety for those who have them but reduce safety for those
who do not.
No.
  #139
Old September 3rd 06, 09:05 PM posted to rec.aviation.piloting
Thomas Borchert
Mxsmanic,
You're truly a piece of work.
Thomas Borchert (EDDH)
  #140
Thomas Borchert
Mxsmanic,
It was gravity's fault. All the planes were under its influence. No
wait, it was the ocean's fault. All planes were surrounded by it. And
so on...
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
AirCraft Radio Communications [email protected] Rotorcraft 0 November 13th 03 12:48 AM
