#131
"John Mazor" wrote
In other words, even you might make hundreds of runs through a procedure simulator and finally get it right, but that doesn't make you a qualified surgeon nor does it qualify you to say that "surgery is easy". There's a lot more to being a surgeon than just being able to complete some sim runs. That, in my opinion, is one of the major points that he fails to appreciate - that you have to be able to get it right when it matters. It is not possible to have a proper appreciation for any of this with no real world experience - doing it right when it matters in real life is nothing like being able to do it in a sim while sitting safely and comfortably in front of your PC. We are, after all, human beings, not machines. Athletes face this type of human performance factor all the time - it is much easier to perform flawlessly in practice when nothing is on the line than it is to do so when in an actual competition. BDS |
#132
On Mar 23, 3:54 pm, "Robert M. Gary" wrote:
The biggest question in that scenario is how was the student able to aquire the required solo time since most insurance co's will not ensure student pilots in a twin. I believe the student's view was that he did not need insurance - if something happened he would reach into petty cash and cover it. Michael |
#133
Kingfish wrote:
Total stream-of-consciousness post here... Anbody learn to fly in a high performance complex aircraft? Bonanza, Saratoga, 182RG and the like? I know it's possible, just wonder how much longer it'd take for a student to master something with significant power and prop & gear controls. (I did all my instructing in 172s and PA28s) Anythings possible, as you said. I would venture to say the problem isn't with the complexity (gear, props), but rather the speeds at which something happens. Cruising at 90 - 100 kts in a 150 is a lot different than in a Bo at 160 kts (or higher). Things happen quicker, more ground is covered. Landing is faster... A slower plane allows you to develop and hone your skills as things happen. You dont have to think as far ahead than in a fast mover. Just my 2 cents. Dave |
#134
John Mazor writes:
Wrong again. That's been around for years. http://www.golimbs.com/offer_index.p...FSBhgQodyC2pRA http://www.haptica.com/ They're sophisticated enough to provide force feedback: http://www.ercim.org/publication/Erc...elingette.html They even have their own expositions: http://www.surgery.arizona.edu/expo/...ulatorExpo.htm which specifically compares them to flight simulators. I'm aware of these. They make Flight Simulator look like a holodeck. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#135
On Mar 25, 7:19 pm, "Peter Dohm" wrote:
Traumahawk-worst of both worlds. Scary thing is that it was a "clean-sheet" trainer... I trained in a Traumahawk. I liked it. When I checked out in the 152, I found it to be a dog in comparison. Jose I trained in a 152, then bought a Tomahawk. It was a much more enjoyable aircraft to fly due to the wider cockpit, better crosswind ability, and better visibility. The only downside was that the Tomahawk needed 10 more knots in the pattern, which is fairly standard when you compare the slow speed regimes of Pipers and Cessnas aiming at the same market segment. I never found the stall characteristics in the Tomahawk to be bad. Keep the ball centered during a stall, if a wing drops, use opposite rudder, then use pitch and power to recover from the stall... KB The main nuisance in Tomahawk is the spring -operated pitch trim. I flew my basic training in a Tomahawk. It's still light-years more an airplane than a C150. -- Tauno Voipio tauno voipio (at) iki fi My only criticism on the spring-operated pitch trim was that didn't add any redundancy to the control system. OTOH, I have never heard of a Tomahawk losing its elevator control linkage; so the added redundancy may have never been needed. The wider cockpit, improved visibility, and crosswind ability were certainly a great improvement over the C152--and the more direct and precise ground handling was very nice as well. Peter- Hide quoted text - - Show quoted text - To the list of pluses for the Tomahawk add Fuel Capacity. It has nearly 2 hours more range than most 150/152's. As an interesting note if you research the NTSB reports for Spin Accidents in Pa38's you will find that for the most part only Flight Instructors and Examiners seem to have issues with the Stall spin Charateristics. I have taught a lot of pilots to fly in Tomahawks and I think they are great. My biggest pluses are, in no particular order,the Switchable fuel tanks, Large Cockpit, and Fuel Capacity. Brian CFIIG/ASEL |
#136
![]() My only criticism on the spring-operated pitch trim was that didn't add any redundancy to the control system. OTOH, I have never heard of a Tomahawk losing its elevator control linkage; so the added redundancy may have never been needed. The wider cockpit, improved visibility, and crosswind ability were certainly a great improvement over the C152--and the more direct and precise ground handling was very nice as well. I did my primary training in a PA38 also, back in '94-'95. Odd coincidence was 6 months or so after I finished, I started reading about all the stall/spin accidents in the Tomahawk and the empennage folding up in a few. Yikes. The 3 T-hawks at my flight school had the inboard & outboard stall strips so the stall performance was fairly benign. The two at the school where I flew also had the inner and outer strips. Those two were nearly new at the time, which was about 1981 or 1982. I have heard since that the rivets in the tail area require inspection--and replacement of those that work loose. That would not necessarily prevent me from owning one, but it would certainly jprevent me from even considering a lease back arrangement. I can personally attest to the strength of the landing gear on that plane though G I had my share of "3-wire" landings... I had the same problem--initially. Interestingly, the solution (which might be shared by a lot of low wing aircraft) was to arrive fast and enter the flare at 80 Kts, instead of 70 Kts, a couple of times. That used about 500 to 600 additional feet of runway, but also allowed the landing process to occur in "slow motion" for more detailed observation. The 3000 foot runway allowed ample room for that, especially to a full stop; and only a couple of the higher speed approaches were needed. After that, normal (and even short feild) approaches resulted in good landings nearly every time. Peter |
#137
great. My biggest pluses are, in no particular order,the Switchable fuel tanks, Large Cockpit, and Fuel Capacity. I particularly liked the nimble handling. Of course I didn't know it was nimble until I went to a 152. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#138
On Mar 26, 1:53 pm, Eeyore
wrote: Mxsmanic wrote: Eeyore writes: It's not going to happen. For so many obvious reasons. That you can't see those reasons speaks volumes. Famous last words. I don't think it will happen soon, but I've seen too much to make any absolute statements about it never happening. They also used to talk of the 'paperless office' in the heady early days of cheap modern IT. Perfectly do-able but do please show me one. When the driverless car is perfected maybe they can move on to aircraft ? Hey. Remember all those 'flying car' concepts that would have had all of us commuting in our own little 'semiautomatic' flying vehicles? No doubt there are still some being touted but none have reached further than a test flying tethered status AFAIR.. Automated systems like the Docklands Light Railway in London went back to human drivers.. How can some-one using a PC loaded with Windows be advocating computor control of anything :-) |
#139
On 26 Mar, 02:11, Mxsmanic wrote:
Eeyore writes: Eh ? Exactly. Doctors can't perform surgery on simulated human beings, at least not yet. Therefore the first surgery is a "revenue flight": a real surgical procedure on a real person, not a practice run. This is quite unlike many forms of aviation, which can be practiced in simulation, or even in real aircraft on practice flights (with no passengers, and thus "non-revenue"). wow, wannbees slurping always make my heart go pit-a-pat.. Sigh Bertie |
#140
On 26 Mar, 13:06, Eeyore
wrote: Thomas Borchert wrote: Eeyore, I did. No you didn't. No offense, but please do us all a favor and stop arguing with the village idiot. This is so reminiscent of Monty Python's argument clinic ;-) You noticed ? ;~) It was vaguely interesting to see you go through exactly all the phases many here went through months ago when the idiot first appeared here - but it is kind of tiring to see new people engage him again and again only to end up at this point. Any "discussion" with the idiot is fruitless, a waste of bandwidth and an increase of noise in a newsgroups where the SNR isn't very good to begin with. And all it will do in the end is keep him here. Let him leave just like he left the groups he came from: travel groups, breast-feeding groups, photography groups, gamer groups. Yes, he has really messed in all those in exactly the same way he is doing his stupid act here. Ignore him. Please. I've got the picture. He's in the same league as habshi and Archimedes Plutonium (see the sci. groups) . All are irredeemably stupid. Bwawhwhahwhahwhahhwhahwhahwhahhw! Says the wannabve pilot planespotter.. bertie |
Primary nav source | Wizard of Draws | Instrument Flight Rules | 17 | December 21st 05 07:11 AM |
Insurance out of hand? - AOPA flying clubs high perf retractable | Ron | Piloting | 4 | February 18th 05 08:40 AM |
Insurance requirements out of hand? - AOPA high perf retractable for Flying Clubs | ron | Piloting | 6 | February 16th 05 03:33 AM |
Need to rent an a/c for primary training | Briand200 | Aviation Marketplace | 0 | May 28th 04 04:40 PM |
WTB metal mid perf. | DGRTEK | Soaring | 2 | January 26th 04 03:27 PM |
