Methods for altitude changes
Old April 14th 07, 07:37 PM posted to rec.aviation.piloting,rec.aviation.student
Snowbird
Default Methods for altitude changes
"Mxsmanic" wrote ...
Well, you really go to great lengths to demonstrate your stupidity. I wonder
why?
Let me recall the context of my question, which you cut out:
There are several ways to implement an autopilot. But no autopilot is
designed to relieve control pressures.
What do you think this one does?
"The FCCs also operate together to provide the automatic pitch trim
function. The FCCs sense torque on the primary pitch servo and generate
arm
and command signals to drive the pitch trim servo or external trim
control
system."
Then you answer with:
It maintains altitude.
Your answer is
a) out of context,
b) erroneous, being seriously incomplete,
c) demonstrates an attitude of trying to use convenient part-truths to
argument your viewpoint even when it has already lost. A not unknown
debating tactic, but useless nevertheless.
  #134
Old April 15th 07, 12:25 AM posted to rec.aviation.piloting,rec.aviation.student
In rec.aviation.piloting Just go look it up! wrote:
On Sat, 14 Apr 2007 16:25:02 GMT, wrote:
In rec.aviation.piloting Mxsmanic wrote:
Snowbird writes:
I can see you have actually begun to learn something about autopilots. There
is more to the story, though. Would you believe some autopilots act on both
the control surface and the trim device?
Another true but worthless statement.
Hmm... Is it a true statement though? The King autopilots (and the
S-Tec range AFAIK) both are designed such that they use pitch servos
to reposition the control surface (elevator or stabilator) to affect
a change (climb, descent) and have inbuilt feedback generators to tell
the trim servo to actuate such that it removes the load from the
surface at its new position. That seems to be at least two systems
who's basic design incorporates a methodology to actively relieve
control pressures.
You are being realistic and practical in your interpretation.
He is being a pendantic, semantic game playing, asshole in he's interpretation.
Strictly, he is correct.
Autopilots are designed to control aircraft.
Jim Pennino
Remove .spam.sux to reply.
  #135
Old April 15th 07, 12:41 AM posted to rec.aviation.piloting,rec.aviation.student
Just go look it up!
control pressures.
Ah. Yes, he does have the propensity to do that doesn't he. And he
changes the pedantry context even within the thread he's ruining. Like
in this one, yea, autopilots control aircraft but his statement that
"no autopilot is designed to relieve control pressures" in the context
of the subthread could be parsed as "no autopilot is designed (with a
mechanism) to relieve control pressures", rather than the ultimate
design goal of an autopilot system, and he switches back and forth to
suit whichever asinine argument he's proffering at the moment.....
  #136
Old April 15th 07, 02:47 AM posted to rec.aviation.piloting,rec.aviation.student
ManhattanMan
And everybody sucks it up like a sponge, responding to the troll just like
he wants....
  #137
Old April 15th 07, 08:21 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Just go look it up! writes:
control pressures.
Relieving control pressure is still not the purpose of the autopilot, though.
It merely uses that as a means to an end.
If autopilots were really intended to relieve control pressures, then they
would not hold altitude or heading. Instead, they would act to keep the
controls in whatever position you last put them in, irrespective of altitude
or heading. I don't know of any autopilot that does that. The closest
approach is the control-wheel steering feature of some AFDS systems on large
transport aircraft, but apparently pilots don't use those features very often,
and it's still based on maintaining something other than control pressures.
  #138
Old April 18th 07, 12:45 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Snowbird writes:
Autopilots certainly want to trim out control pressure. Think about
what would otherwise happen when you disconnect the autopilot. Duh.
It actually _does_ happen when you disconnect the autopilot, in some
aircraft. The purpose of the autopilot is not to relieve control
pressure, it is to fly the aircraft. In aircraft that use trim for
the autopilot, the aircraft may be stable when you turn the autopilot
off. However, in aircraft that directly manipulate the controls with
the autopilot, the aircraft may suddenly change attitude when the AP
is shut off, if the AP has been compensating for something (such as an
engine failure) while it has been operating. This has caused
accidents.
You have no idea what you're talking about, fjukktard.
Bertie
  #139
Old April 18th 07, 12:47 AM posted to rec.aviation.piloting
Mxsmanic wrote in
writes:
All real aircraft have elevator trim.
Not true. Some move the stabilizer instead.
That's stil trim, you moron.
Berti e
Methods of launch Jim Culp Soaring 0 November 20th 06 07:39 AM
Methods of Launch Nigel Baker Soaring 3 November 17th 06 04:35 PM
methods of lauch Robert Gaines Soaring 0 November 16th 06 01:17 AM
Vector altitude for ILS below GS intercept altitude? M Instrument Flight Rules 23 May 20th 06 07:41 PM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
