A-4 / A-7 Question
Old October 8th 03, 05:02 AM
Thomas Schoene
"Tank Fixer" wrote in message
k.net
says...
It almost sounds like the 30mm Caseless Pods that can be mounted
under Fighters making even an A-4 into a tank killer. That died
when the A-7 did. Too bad. The A-7E was a superior AC to the A-10
when armed with the 30mm caseless chain gun. To upgrade the A-7 to
an AC with the F/A-18 perfomance would have cost appr. 3.5 million
per copy. versus how much for an A-10 that requires constant
TopCap? Another Congressional Boondoggle.
Anyone know what he is talking about ?
I've not heard of any system like this before.
I'm guessing he's takling about a couple two things.
First is the GPU-5 (aka Pave Claw) gun pod, which holds a four-barrel
version of the GAU-8 called GAU-13. (Definitely neither caseless nor a
chain gun, though). It was supposed to give conventional fighters almost the
same gun power as the A-10. But it really didn't work very well. The New
York Air Natioanl Guard had one F-16 unit that went to the Gulf with the
GPU-5 in 1991 (the "Boys from Syracuse"/174th Fighter Wing). They took the
pods off the planes early in the proceedings and never flew them again.
http://www.f-16.net/reference/versions/f16_fa.html
Second, for a time, there was discussion of using a modified A-7 with
afterbrning engnie as a CAS bird instead of the A-10. But that was Air
Force, not Navy. And as much a I like the A-7, I have to admit that this
was probably a dead end idea. Even with extensive mods, the A-7 was never
going to be a turning fighter or radar missile shooter like the Hornet.
http://www.vought.com/heritage/products/html/ya-7f.html
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old October 8th 03, 08:28 AM
Tank Fixer
In article et,
lid says...
k.net
says...
Thanks, I had heard of the F16 experiment but never one on the A-4 or A-7
When dealing with propaganda terminology one sometimes always speaks in
variable absolutes. This is not to be mistaken for an unbiased slant.
Old October 8th 03, 08:47 AM
MLenoch
Where are/is the YA-7F airframes today?
Thx,
VL
Old October 8th 03, 02:03 PM
C Knowles
At least one is at the Edwards AFB museum.
Curt
"MLenoch" wrote in message
Thx,
VL
Old October 8th 03, 05:06 PM
GregD
I believe one is at WPABF - USAF Museum, and the other is at the Hill
AFB museum in Utah.
GregD
(MLenoch) wrote in message ...
Old October 8th 03, 08:31 PM
Ed Rasimus
On Wed, 08 Oct 2003 19:06:11 +0100, Greg Hennessy
On that note, anyone got any idea of how much did the A7s long long legs
reduce by when fitted with the bigger blower ?
I seem to remember Mr Rasimus mentioning something about having worked
alongside A7Ds in the past, if you dont mind me asking Ed, what apart from
adding more grunt, would the F100 have made all that much a difference
given what the A7s were tasked with ?
I have no idea what the F100 fit would have done. I seem to recall
that the airframe was aerodynamically limited as far as max speed.
The real strength of the A-7D was the endurance. While it couldn't go
quite as fast as AF types would have preferred, it carried a
significant load for a long time. The true significance was
demonstrated during Linebacker when they A-7Ds of the 354th TFW out of
Korat would takeoff and fly unrefueled to Route Pack V or VI and
return. The F-4 and supporting F-105G Weasels departed Korat
afterward, tapped an inbound tanker and arrived on target at
approximately the same time. The F-4/F-105Gs then returned to a
post-strike tanker and arrived at Korat shortly before the returning
A-7s.
At issue (from an AF point of view, but not apparently from the USN
operator's perspective) was the ability to recover energy quickly when
placed on the defensive. A SAM break that took you down to very low
altitude, usually with high-G, would squander both kinetic and
potential energy. With AB you could regain both fairly rapidly.
Without AB you were in a precarious situation. The extra thrust of a
more efficient engine might have improved that aspect of A-7 ops.
Old October 8th 03, 11:38 PM
Greg Hennessy
That goes with being nicknamed a 'SLUF' I suppose.
return.
Interesting, obviously something with equivalent legs which can fly 100+kts
quicker to/over/from the target is going to be more than just a minor
improvement. One is talking about serious potential in two seat variants
for wild weasel etc.
Obviously something to consider if the balloon ever went up in europe.
europe.
Its an interesting consideration of the road not travelled. Another would
be thinking about if the AF had procured single seat F16-Es 1 for 1 instead
of 'C's during the 80s. They would have made an interesting compliment to
the attack options available during Desert storm and elsewhere.
greg
$ReplyAddress =~ s#\@.*$##; # Delete everything after the '@'
The Following is a true story.....
Only the names have been changed to protect the guilty.
Old October 8th 03, 09:46 PM
Guy Alcala
Greg Hennessy wrote:
Thx,
The A-7F, Corasair III, Strikefighter, etc. all included an airframe stretch
and extra fuel in addition to an F100 or F110. The airframe stretch was to
allow the a/c to be supersonic (Mach 1.4 level IIRR), and the extra fuel was
to keep the range/endurance in the same ballpark.
For instance, here's the proposed Corsair III changes, which was designed to
use rebuilt A-7A/A-7B airframes from the Boneyard, although A-7D/Es would be
easier to convert: An F110-GE-100, 16,700 lb. mil and 27,600 lb. A/B; A
constant-section plug of 29.5" to extend the fuselage around the wing root
area; another plug of 7.5" to the aft fuselage to tailor the airframe to the
F110 and its remote accessory gearbox. Rear fuselage canted upwards 5 degrees
to provide ground clearance for the longer tailpipe. A more sharply-pointed
nose cone (see F-8); the original was made blunter to reduce length on
carriers. Internal configuration changed to increase fuel capacity.
The "Strikefighter" was an upgraded A-7D with an F100 vice F110, and was the
design entered in a CAS/BAI contest against the F-16, AV-8B and F-20.
All data above from Dorr's Osprey book "Vought A-7 Corsair II." There are also
various issues of Air International from the '80s which describe the various
proposals in slightly more detail, but I'm too lazy to hunt them up.
Guy
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 05:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 06:07 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
