The Swedish Model: How to build a jet fighter.
Old May 30th 08, 06:51 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
JR Weiss
Default The Swedish Model: How to build a jet fighter.
"Dave Kearton" wrote...
Maybe he can mop up all enemy resistance.
Maybe he's really thinking of a fighter "sweep"?
Hmmmm, how long before someone pans that ?
Pan Pan! Imminent pun failure!
  #132
Old May 30th 08, 07:00 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
JR Weiss
"WaltBJ" wrote...
Roll rate: 720 degrees per second - what a head-bouncer! We could get
the Zipper to roll a but faster by stomping on teh rudder to yaw it -
the A-model's manual rudder took a good hard stomp, though.
When I was an A-4 instructor, I was amazed at the number of pilots who thought
full stick deflection in the A-4 gave you that 720 deg/sec rate (I suspect it
was more like 3/4 that). Many of them were even MORE amazed when I showed them
what happened when you stomp the rudder as well to get the REAL max rate...
  #133
Old May 30th 08, 07:17 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
JR Weiss
"Douglas Eagleson" wrote:
A spiral or corkscrew as a maneuver allows an escape. You need elevator
deflection, while entering the simple aileron roll, as a rule to cause the
high angle of attack necessary to slow the aircraft and corkscrew breakoff to
the anywhere direction.
Hmmm... Sounds REMOTELY like a high-G barrel roll that can be used ONLY as a
last-ditch maneuver against a close-in gun attack... OTOH, if the bullets
aren't already flying, you haven't escaped ANYTHING -- you've just ****ed away
your energy and allowed the attacker to shoot you when you stop maneuvering
(which you WILL do, else you'll soon hit the ground out of control).
There is nothing about this maneuver, BTW, that favors a canard airplane...
High angle of attack roll rate is critical to either following the target or
breaking off.
So is timing... Again, the maneuver you describe has limited use in ONE
situation.
Matching the target is advised and it is as follows.
"Matching the target"?!? If you are doing anything like that, you ARE the
target!!! If you are NOT the target at the start, you certainly will be at the
end!
1. elevator deflect and roll positive g.
2. As 180 degree roll is passed a person needs to do a single elevator
motion. And if you get it wrong the maneuver turns into a dive.
3. SO push on the elevator to mAKE THE FORWARD CORCKSCREW POSSIBLE.
Now you make it sound like a Lomcevak(sp?) (except you forgot the rudder input),
which is NOT a useful tactical maneuver!
So it is a hard thing to get the hang of and it has negative gs.
A special modification was to aerodynamics. What can be changed. A dive as
arule is always sort of expected. SO a vertical exit from the corkscrew
appear the false exit. A fake exit is possible aerodynamically. A simple
vertical followed by a return to the corkscrew really making it impossible to
follow.
Indeed, a dive is always "expected" after a pilot ****es away all his kinetic
energy...
An attacker would not WANT to follow such a ridiculous maneuver! As pointed out
by another REAL pilot, the attacker only needs to lag up high and keep sight,
and shoot you when you emerge from the folly!
ALWAYS lossing the trailing aircraft.
More like "never" than "ALWAYS"!
  #134
Old May 30th 08, 07:20 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
JR Weiss
A basic thing to remember a.
A simple test again who knows the answer?
What maneuver can attach to the wing of the trailing opponent and deflect the
ailerons?
The question is nonsense, so it is unanswerable.
A certain supesonic maneuver will generate a class of wake that will always
attack the trailing aircrafts ability to maintian control.
ANY time a trailing aircraft crosses the wake vortex, full control will
momentarily be overridden by the vortex! Nothing new here, and nothing
unrecoverable!
A canard aircraft will always appear to fall out of the sky, btw. It will
stall the front first. Flying into a sonic front as a rule was always to worry
the pilot because some people can intentionally form a special wake front for
you.
More utter nonsense!
  #135
Old May 30th 08, 08:38 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Dan[_12_]
It's too fine a May day for such things.
Dan, U.S. Air Force, retired
  #136
Old May 30th 08, 08:43 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Ed Rasimus[_1_]
On Fri, 30 May 2008 11:17:12 -0700, "JR Weiss"
Been there, done that, in front of a MiG-17 who WAS firing from about
500 feet behind me. In an F-105D, at the western end of Phantom Ridge
where it spills out into the Red River Delta, starting the maneuver at
about 800 feet AGL. Worked as advertized, but wouldn't like to have
been there more than once in a lifetime! Wasted way too many
heartbeats.
All was as you say, Sensei.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
"Palace Cobra"
www.thunderchief.org
  #137
Old May 30th 08, 11:37 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Richard Casady
On Fri, 30 May 2008 19:43:04 GMT, Ed Rasimus
heartbeats.
It is my understanding that the thud was the fastest plane in the
world at low altitude, while the 104 was faster at high altitude. Nice
if you plan to run away, although there is never enough fuel to do the
supersonic bit for long.
Casady
  #138
Old May 31st 08, 04:42 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
JR Weiss
"Ed Rasimus" wrote...
heartbeats.
I'm honored!
  #139
Old May 31st 08, 03:53 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Ed Rasimus[_1_]
On Fri, 30 May 2008 22:37:46 GMT, (Richard
heartbeats.
Casady
Your understanding was correct. It didn't really take A/B to get going
really quickly on the deck. We often came down the last fifty miles to
a target at 540 indicated with a full load of eight 750 pound bombs
and did nuclear deliveries on the range with a 600 KIAS run-in, all
without burner. You could get supersonic quite easily with a short
blast of burner and it didn't take long to get clear of anything.
Ed Rasimus
"Palace Cobra"
  #140
Old May 31st 08, 08:00 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Ron
heartbeats.
Casady
Ed Rasimus
"Palace Cobra"www.thunderchief.org
Just imagine though what life would have been like though for the Navy
Spad pilots tasked with throwing some instant sunshine over their
shoulder.
LETS BUILD A MODEL PLANE adelsonsl Aviation Photos 1 May 16th 07 11:10 PM
Swedish! Owning 3 March 3rd 06 12:44 AM
The end of the Saab Viggen - The legendary Swedish jet fighter Iwan Bogels Simulators 0 April 19th 05 07:22 PM
The Very Last Operational New German Fighter Model Of WW2 Garrison Hilliard Military Aviation 13 January 13th 04 03:31 PM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
