#141
Mike Rapoport wrote:
"John Gilmer" wrote in message ... "Mike Rapoport" wrote in message rthlink.net... "Ralph Nesbitt" wrote in message odigy.com... At altitude A/C cabins are like a pressure vessel. A/C cabins are pressurized to maintain ~ 12 PSI Gauge, ~ the same as normal atmospheric pressure @ 11,000' ASL, in the cabin irrespective of altitude above 11,000' ASL. Ralph Nesbitt Professional FD/CFR/ARFF Type No, the cabin is not at a constant preasure above 11,000' (and the number that you are looking for is 8,000') unless the rate controller is set to a rate greater than the climb rate of the aircraft (which is never done). If what you say were true then the cabin altitude would not climb with the airplane above 11,000' (8,000') which it clearly does. If you doubt this, go buy an altimeter watch and see for yourself. Or you could buy a pressurized airplane. OK, I'll bite. Just how does the psia in the cabin track the psia "ambient." What are you asking? Mike The comment was made that the pressure inside the cabin is not necessarily constant above a certain altitude, unless certain cabin rate settings were made, possibly leading to confusion over cabin altitude vs. actual aircraft altitude. It is a simplification to say that cabin altitude is constant above a given aircraft altitude. In fact, the cabin altitude will move toward a certain altitude (8,000' in most cases, it seems) as set by the cabin pressurization controller (or any of its several other names), IF the outside pressure altitude is higher than the cabin altitude. That is to say that if you take off from sea level and climb to 10,000', the cabin altitude will steadily climb, at a rate set by the cabin pressure controller, toward 8,000'. If you were to level off at 5,000' and stay there long enough for the cabin pressure to catch up, it will maintain 5,000' until the aircraft begins to climb again, at which it will again climb at the set rate until it reaches either the set cabin altitude or the actual ambient pressure altitude. So the cabin pressure can be below 8,000' (or whatever the set altitude is) at actual altitudes above the set altitude, but will be moving toward the set altitude in that case. Note that cabin altitude cannot be maintained ABOVE the actual pressure altitude, as air is continually pumped into the cabin by the bleed air system, and is let out (or leaks out) to maintain the set altitude or rate of change. If you descend quickly enough, you may temporarily get a cabin altitude above ambient, but air will not exit the aircraft (outside pressure would prevent any air from leaving through the outflow valve, and in some cases a safety valve may automatically open to allow air to flow INTO the aircraft, relieving the negative pressure differential) and air flowing into the cabin will tend to increase pressure rapidly until equilibrium is reached. Having attained the pressure set by the controller, the system will typically attempt to maintain that pressure altitude until it is reset to another altitude, although it may not always be able to. Descents with low engine power may result in not airflow into the cabin to match the outflow, due either to the controller not closing the outflow valve fast or far enough, or due to leaks in the airframe letting more air out than the system can pump in. Also, the cabin controller will typically not allow a pressure differential above a certain limit- too much pressure differential stresses the fuselage. The controller will open the outflow valve to maintain that maximum differential, so at that point, if the aircraft climbs then the cabin altitude will increase as well. Prior to or during the descent, the cabin pressure controller would normally be set to the field pressure altitude (which is normally below the cabin altitude during cruise, but this may not always be the case). The controller will then begin to decrease the cabin altitude, again at the set rate. This prevents rapid pressure changes as the aircraft descends through the cruise cabin altitude and is more easier on the passengers and crew. Long and convoluted enough for you? Mike EC-130H Compass Call "In Jam, no one can hear you scream" |
#142
"Ron Natalie" wrote in message om...
"C J Campbell" wrote in message ... We do not really know any such thing. If the passenger is bigger than the window he simply cannot be pulled through it any more than he can sucked up through a vacuum cleaner hose. Passengers are pretty flexible. Some might plug up the hole, others will go through holes that looked like they ought not to fit through. a midget will |
#143
#144
"Bob Gardner" wrote in message news:QODIb.85072$VB2.187788@attbi_s51... No way. You start off at sea level, of course, and they pump the chamber pressure down to 25000 feet with masks on...then they do some experiments with a few of the pilots taking their masks off, just to show how severely their abilities are affected. Then comes the explosive decompression, which takes the chamber from 25K back down to sea level in a second or two. SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? EMWTK "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances (eg medevac operations where pressurization is a factor) |
#145
Michael Williamson wrote in message ...
John Gilmer wrote: SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? Typically, they start at whatever the local pressure altitude happens to be (which of course may or may not be sea level, depending on where you happen to have the chamber). Also, I've never experienced in any altitude chamber ride a rapid REcompression down to sea level- it strikes me as a good way to have sinus or ear problems. Mike nope. when the doors on an aircraft are shut the pressure is ambient. thats it. when bleed air pressures the cabin its noramlly to about 8000ft. |
#146
... Note that cabin altitude cannot be maintained ABOVE the actual pressure altitude, as air is continually pumped into the cabin by the bleed air system, and is let out (or leaks out) to maintain the set altitude or rate of change. If you descend quickly enough, you may temporarily get a cabin altitude above ambient, but air will not exit the aircraft (outside pressure would prevent any air from leaving through the outflow valve, and in some cases a safety valve may automatically open to allow air to flow INTO the aircraft, relieving the negative pressure differential) and air flowing into the cabin will tend to increase pressure rapidly until equilibrium is reached. http://www.b737.org.uk/pressurisation.htm has some good information. Paul Nixon |
#147
"running with scissors" wrote in
message om... "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances Actually, it depends on the aircraft. Aircraft are certified to certain "differential pressures" which is the difference between in the inside cabin pressure and the outside ambient air pressure. An airframe must be designed to handle the differential pressure required to maintain acceptable cabin altitude up to the max flight level the aircraft is certified to. As an example, the King Air I fly has a normal differential pressure of 6.6 psid. This provides for a cabin altitude of 2,700 up to 20,000 cruise altitude, an 8,700 foot cabin altitude at 31,000 cruise altitude, and a 10,200 foot cabin altitude at 35,000 cruise altitude. In contrast, the Lear 60 I fly has a normal psid of 9.5 (9.7 max) which typically results in a cabin altitudes of around aprox 6,500 up in the 40,000 ish cruise altitudes. |
#148
On Tue, 30 Dec 2003 22:12:24 GMT, "Bob Gardner"
wrote: I have no direct knowledge of how big an airliner outflow valve is, but I am going to guess three inches in diameter That would not be a good guess! ![]() much larger than that. -J -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
#149
running with scissors wrote:
Michael Williamson wrote in message ... John Gilmer wrote: SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? Typically, they start at whatever the local pressure altitude happens to be (which of course may or may not be sea level, depending on where you happen to have the chamber). Also, I've never experienced in any altitude chamber ride a rapid REcompression down to sea level- it strikes me as a good way to have sinus or ear problems. Mike nope. when the doors on an aircraft are shut the pressure is ambient. thats it. when bleed air pressures the cabin its noramlly to about 8000ft. While the final (steady state) pressure of the aircraft (as determined by the cabin pressurization controller) will end up at its cruise setting, the aircraft is pressurized from takeoff and the cabin altitude will typically climb slowly toward its set value (about 8,000' in this case) rather than follow ambient- the pressurization system is indeed pressurizing the aircraft its initial field elevation up to the cruise pressurization setting. In addition, my above response was poorly worded and I actually was commenting on the pressurization of the altitude chamber- which begins at whatever the ambient pressure happens to be. My bad for not reading the question closely enough. Mike |
#150
![]() "Gary Mishler" wrote in message news:eBoKb.745162$HS4.5776347@attbi_s01... "running with scissors" wrote in message om... "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances Actually, it depends on the aircraft. Aircraft are certified to certain "differential pressures" which is the difference between in the inside cabin pressure and the outside ambient air pressure. We were talking about transport aircraft. US certificated transport aircraft must keep the cabin altitude below 8000'. |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 05:26 PM |
Invest small Earn Large ($20 000+) | promethean | General Aviation | 0 | October 3rd 03 06:08 AM |
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 04:00 PM |
