Fatal crash Arizona
Old June 17th 14, 07:46 AM posted to rec.aviation.soaring
Andrew[_13_]
Default Fatal crash Arizona
In the event of a launch failure (or a bounce on landing) I was
taught to 'adopt the attitude that you would be at that height
during a normal approach', which I think is a clear and good
description of the 'appropriate attitude' that Don recommends. I
completely agree with Don's advice about then checking speed,
and landing ahead as the first choice.
I was worried by writers in this thread who have mentioned
aerotowing at sites where a straight ahead landing from a low PT3
could not be safely made. Single-engine power pilots often accept
catastrophic risks (e.g. from engine failures) but we glider pilots
don't have to. If the PT3 danger is only to the glider, I guess that's
ok, if the owners and their insurance company have no objection.
But if personal injury is risked by PT3, I hope everyone agrees that
such sites should not be used for aerotowing gliders.
At 22:14 15 June 2014, Don Johnstone wrote:
No, what I was taught and what I teach applies to ALL launch
failures,
winch, auto tow, and aerotow as detailed above. The first action
is to
select the appropriate attitude, at least approach attitude and
make sure
that you have a minimum of approach speed. Then ask the
question, "Can I
land ahead" If and ONLY if the answer is NO or NOT SURE should
any other
action be considered.
  #142
Old June 17th 14, 10:17 AM posted to rec.aviation.soaring
Bruce Hoult
I disagree.
Options in the event of a tow failure include:
1) land ahead
2) land cross wind
3) do a (approx) 180 and land downwind
4) do a (approx) 180, enter an abbreviated downwind leg, land crosswind
5) do a (approx) 180, enter an abbreviated downwind leg, land upwind
6) do a (approx) 180, do a normal downwind leg, land upwind
As long as at least *one* of those options is available at all times the site is fine.
Which ones are appropriate does change according to conditions. For example 3) is likely to be a bad idea in all but the lightest winds. But as the wind strength picks up the opportunities for the others increases quickly.
  #143
Old June 17th 14, 03:58 PM posted to rec.aviation.soaring
Bill D
I disagree.
1) land ahead
2) land cross wind
I agree with Bruce. However, all those actions require the pilot to have at least basic airmanship abilities which is clearly missing in some posts to this thread.
When applied to flight training, I find terms like "KISS" and "lowest common denominator" to be infuriating. Aviation is not simple and never will be.
When I read "KISS, I'm reminded of Forrest Gump: "Stupid is as stupid does". Rather than aiming to accommodate the "lowest common denominator" in students, demand excellence.
  #144
Old June 18th 14, 01:47 AM posted to rec.aviation.soaring
CindyB[_2_]
On Monday, June 16, 2014 12:15:07 AM UTC-7, Jim White wrote:
May I offer a practical tip? Talk to yourself all the way up the launch to
a safe height (perhaps 500ft), deciding where you will go at every moment
should the rope / tug break. Should it then happen you already have the
decision made and only have to execute it well.
If you, or your trainee, start to do this every launch you will be amazed
at what poor decisions you would make to begin with. These get better with
the doing of it.
Delightful. Since it was about a hundred posts ago I offered the same concept, may I say, "Thank you."
I am heartened to know that there are others out there who prefer to be prepared and updating their situational awareness during launch, rather than becoming off-launch and then begin 'assessing' the choices.
If the assessment is ongoing, the execution of the 'best choice' becomes pretty relaxed. And if we fly to the landing, it is so much more likely to be survivable than falling to an impact.
Thanks, Jim.
Cindy B
  #145
Old June 18th 14, 02:18 AM posted to rec.aviation.soaring
Bruce Hoult
It would never have occurred to me that this was not assumed by all in the conversation.
Here in NZ, students are frequently asked "where would you go now?"
  #146
Old June 18th 14, 05:51 AM posted to rec.aviation.soaring
Andrew[_13_]
now?"
Hi Bruce, can you tell us what the teaching is in NZ is about this? Do
you teach 180 degree turns at 200ft?
  #147
Old June 18th 14, 08:38 AM posted to rec.aviation.soaring
Bruce Hoult
now?"
The Gliding NZ training syllabus requires the instructor demonstrating a low level launch failure. It doesn't require the student flying one. (the same applies to fully developed spins, by the way ... the student only has to demonstrate incipient spin, recognition, recovery).
I don't think there is mention of any particular height. Our students are doing 180 and 360 degree turns 200 ft above ridges all the time, and constantly have "safe speed near the ground" drummed into them.
250 ft is the common simulated launch failure height, with an expectation that you'll be able to turn onto a downwind and then evaluate whether to land crosswind (probably) or into wind.
Further information:
One of Gliding NZ's A certificate oral questions and model answer:
Q: What is the pilot's first priority immediately following a launch failure on a winch launch and an aerotow launch?
A: Winch launch: Lower the nose to attain "Safe Speed Near The Ground".
Aerotow launch at low level: Raise the nose to convert excess speed to height but never fly slower than "Safe Speed Near The Ground".
For winch launching, the instructor's manual recommends landing ahead if you are less than half way down the strip and with less height than 1/10th of the total strip length. It recommends 400 ft as the minimum for doing a full circuit and normal landing. (it also recommends 4000 ft as the minimum length for winch launching, so that is internally consistent)
If you will always deliberately release if you find yourself halfway down the strip at less than 400 ft then there can never be a situation where you'd want to turn 180 and land downwind. At least, on a strip where the entire length is landable. I've flown from sites with a 5000 or 6000 feet run for the winch cable, but only a few hundred yards of landable area ... different guidelines will apply.
For aerotow launching, no specific advice is given as to heights. It does say "Unlike winch launching, aerotowing often involves entering the non-manoeuvring area." and "Beware the low-level turnback--if in doubt, land out", but without any definition of what is low level.
Certainly at our site -- a commercial airport with scheduled Dash 8 flights, surrounded by dense housing on all sides -- any off field landing is going to have very severe consequences. The seal is 1500m, but the grass we use is only about 600m. In one direction, we have the option of stepping sideways onto the main runway and landing ahead. In the other direction, grass and seal hit the fence at essentially the same point, but there is an old X'd tarsealed runway parallel and close to the fence that will serve in an emergency with only a 90º turn if 180º doesn't seem advisable.
  #148
Old June 18th 14, 12:06 PM posted to rec.aviation.soaring
Jim White[_2_]
launch
to
moment
conversation.
Bruce, one would hope that this is how most people do it, but my experience
is different. I am not a full instructor but do coach xc soaring to people
who have already got their wings. When I suggest this to the people I fly
with I usually get "that's a good idea, I never thought of that" so I
presume it is not generally taught.
Asking 'where would you go' does not demonstarte that your pupil is doing
this, he may just be good enough to come up with a sensible answer on the
fly, that time. Asking him to tell you where he would go all the way up to
a safe height would tell you, the instructor, very much more about what his
thought processes are and how well he could handle an emergency.
Just my penny's worth.
  #150
Old July 18th 14, 05:10 AM posted to rec.aviation.soaring
flgliderpilot[_2_]
On Tuesday, May 6, 2014 4:41:23 PM UTC-4, Don Johnstone wrote:
While in no way do I wish to speculate on the cause of this accident or
indeed suggest that my comments in any way address the cause of this
accident.
I feel that comment is needed on some of the things said here. We have a
rule here in the UK, launch failure on aerotow below 300ft a landing should
be made ahead, or slightly to one side. No attempt should be made to turn
back below this height.
The reason is simple, a controlled crash into difficult terrain is likely
to result in a better outcome than an uncontrolled arrival on the airfield.
The important bit to keep intact is the bit you are sitting in, the rest of
the glider does not really matter too much. The best chance of achieving
that is flying to the ground with the wings level. It has only happened to
me once, there was a field ahead but it was full of the Tiger Moth tug that
had landed in the middle. I discovered that there was just enough space for
a Skylark 2 as well. I have no doubt that a turn back would have resulted
in an accident. I was at 250ft agl max.
If there really is nowhere to land ahead you should really ask the
question, "should I be taking a launch".
Frankly I would be horrified to be required to conduct a turn back at
200ft, I would suggest that this is one of those occasions where the danger
of practice is to great to justify.
Sometimes it's hard to face the fact that the glider must be destroyed to survive. Trying to save the device could be a deadly decision.
Again, I don't know what actually happened, best guess, inadvertent unintentional release. Whether he tried to turn back, or just plain didn't get the nose down quick enough during a 90 degree or lesser turn, who knows.
The only way to practice rope breaks at 100' is on a simulator (condor).
Parowan Fatal Crash ContestID67[_2_] Soaring 30 July 3rd 09 03:43 AM
Rare fatal CH-801 crash Jim Logajan Home Built 8 June 22nd 09 03:24 AM
Fatal crash in NW Washington Rich S.[_1_] Home Built 1 February 17th 08 02:38 AM
Fatal Crash Monty General Aviation 1 December 12th 07 09:06 PM
Fatal Crash in Fittstown, OK GeorgeC Piloting 3 March 7th 06 05:03 AM
