Myth: 1 G barrel rolls are impossible.
Old June 11th 07, 07:09 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Logajan
Default Myth: 1 G barrel rolls are impossible.
Myth:
It is impossible to perform a barrel roll such that the pilot feels exactly
1 gee of force perpendicular to the floor of the cockpit. (Barrel roll is
defined here as the maneuver depicted by the definitions and diagrams on
these website:
http://en.wikipedia.org/wiki/Barrel_roll
http://www.flightsimbooks.com/jfs/page74.php
http://home.comcast.net/~john.schnei...arrel_roll.jpg )
Fact:
The aspect that I think appears to mislead people is the presence of a
gravitational field and an implied requirement that the axis of the helix
must remain straight and parallel with the (flat) ground. But the latter
requirement can be dispensed with and still yield a recognizable helical
flight path - and that is enough to make a 1 gee barrel roll possible. The
"trick" is accomplished by superimposing two equations of motion:
(1) Start with a "zero gee" parabolic trajectory. So basically the plane
travels laterally over the ground while first traveling up (and then down)
such that the pilot would feel weightless absent any other motions. The arc
is a classic parabola.
(2) Superimpose by vector addition the centrifugal force of the plane
"flying" a circle around (and along) the moving center established by the
parabolic trajectory in (1).
(3) Set the radius and angular speed of the circle in (2) to yield one gee
equivalent force and rotate plane's attitude to keep the centrifugal force
vector perpendicular to the floor. End of procedure.
A reasonable nit pick is that the axis of the helix of the barrel roll
doesn't remain "straight and level." But none of the definitions explicitly
state that requirement. And in any case, it is possible to end the 1 G
barrel roll at the same altitude at which it began.
So there. :-)
(If there is a demand (and I can find more time) I can work out and post
the complete set of equations of motion.)
Old June 11th 07, 07:22 PM posted to rec.aviation.piloting,rec.aviation.student
Robert M. Gary
On Jun 11, 11:09 am, Jim Logajan wrote:
Myth:
these website:http://en.wikipedia.org/wiki/Barrel_...arrel_roll.jpg)
Fact:
So there. :-)
Did I miss some context? Was there a debate about this? There are
videos on youtube of people doing barrel rolls with a cup of coffee in
their lap.
-robert
Old June 11th 07, 07:37 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Logajan
their lap.
Most everyone agrees that keeping the coffee in the cup is possible. What
some people don't seem to believe is possible is that the force felt by the
pilot (or tea/coffee) can be 1 gee during the entire roll. They believe it
has to vary during the roll. I'm hesitant to name names. ;-)
So yeah, I think there is some need to clear the air.
Old June 11th 07, 08:54 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Jim Logajan writes:
It has to vary during the roll, because the constant 1 G acceleration due to
gravity does not change. The net acceleration of the aircraft must always be
at least one G in consequence, and if the aircraft begins a climb or ends a
descent, it _must_ be greater than +1.0 G.
Old June 11th 07, 10:00 PM posted to rec.aviation.piloting,rec.aviation.student
On Jun 11, 1:54 pm, Mxsmanic wrote:
Jim Logajan writes:
Bertie! He's doing it again!!!!
Old June 11th 07, 10:08 PM posted to rec.aviation.piloting,rec.aviation.student
george
Jim Logajan writes:
Well you have to admit where he does his 'aerobatics' he is under 1g
constantly
ROTFL
Where we do aerobatics its somewhat different as we do them in
aeroplanes...
Old June 11th 07, 11:16 PM posted to rec.aviation.piloting,rec.aviation.student
Erik
Mxsmanic wrote:
Jim Logajan writes:
With any luck your monitor will fall on you.
Old June 11th 07, 11:24 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Logajan
Mxsmanic wrote:
Jim Logajan writes:
What some people don't seem to believe is possible is that the force
felt by the pilot (or tea/coffee) can be 1 gee during the entire
roll. They believe it has to vary during the roll. I'm hesitant to
name names. ;-)
due to gravity does not change. The net acceleration of the aircraft
must always be at least one G in consequence, and if the aircraft
begins a climb or ends a descent, it _must_ be greater than +1.0 G.
Sigh. Yes, the force that is felt is greater then one g-force at the
beginning and end of the maneuver. But that is not the case "during the
roll" itself. Again, as in the other post of yours I responded to, you
appear to be confusing force and acceleration.
Old June 11th 07, 11:41 PM posted to rec.aviation.piloting,rec.aviation.student
mike regish
The few that I've done, and it is only a few, the g forces were noticeably
less at the top of the roll. I was still pressing into the seat, but not as
much. Just as in a loop, the g forces are lower at the top of the loop.
mike
"Jim Logajan" wrote in message
Mxsmanic wrote:
Jim Logajan writes:
name names. ;-)
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 05:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 11th 04 11:45 PM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 04:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 09:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
