Why airplanes taxi
Old February 12th 08, 09:44 PM posted to rec.aviation.piloting
Mxsmanic
Default Why airplanes taxi
writes:
A large one as is obvious from the NTSB data.
So you don't know.
  #142
Old February 12th 08, 09:55 PM posted to rec.aviation.piloting
John[_13_]
No we are just not willing to tell you
"Mxsmanic" wrote in message
writes:
So you don't know.
  #144
Old February 13th 08, 12:55 AM posted to rec.aviation.piloting
On Feb 11, 7:35 pm, Mxsmanic wrote:
writes:
My mistake. It was -20°C on the ground and +18°C at 3000' agl.
A 38° difference. A difference in the "wrong" direction.
So the pressure must have been much higher at 3000 feet, according to the
reasoning given in your previous post.
You either do not understand or are unteachable. Perhaps this
is why you are limited to simming. I talked about inversions. I talked
about temperature and pressure for a *given* air mass. All you can do
is diss everything anyone says in a futile attempt to protect your
credibility.
Dan
  #149
Old February 14th 08, 01:20 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Benjamin Dover wrote in
Bertie the Bunyip wrote in
Mxsmanic wrote in
WingFlaps writes:
So how do you explain the rather well known lapse rate?
It depends on which lapse rate you have in mind.
The one which states that as the temperature rises, the two molecules
in your head take a siesta.
Bertie
When did his intelligence double to two molecules?
Same way he reproduces. Mytosis.
Bertie
  #150
Old February 14th 08, 12:37 PM posted to rec.aviation.piloting
Mxsmanic wrote in
terry writes:
Now Mxs before you take off in your simulated Baron,
do you check the takeoff performance figures in the simulated flight
manual versus the lenght of runway at your simulated departure
airport?
No. According to the POH (the sim version and the real version are
the same), 4500 feet is enough for any situation, so as long as I have
at least 4500 feet, I'm fine.
4500 feet of what, pixtels?
Do you know how to work out what your density altitude is?
I have a calculator and an E6-B to work things out should that really
become necessary.
What, in case you run out of tv screen?
Real pilots do this if there is any doubt they might
not have enough distance to clear the runway or any obstacles, and
since you are so obsessed with manufacturing pretended reality I am
sure you would want to be doing this also.
I stay close enough to the center of the envelope that this is never a
factor. It's a lot easier than pushing the envelope and having to do a
truckload of calculations before every flight just to see if I can
squeak by.
moron
Bertie
yrb-49-taxi.jpg [email protected] Aviation Photos 2 September 25th 07 09:50 PM
Hanoi Taxi john smith Piloting 0 April 27th 06 03:48 AM
License To Taxi? SteveT Piloting 29 October 16th 05 04:57 PM
Leaning for taxi Jim Rosinski Piloting 28 September 12th 04 03:53 AM
taxi in reverse? [email protected] Owning 20 February 21st 04 12:26 AM
