#141
On Mon, 5 May 2008 23:54:37 -0700 (PDT), WingFlaps
wrote: On May 6, 3:36*pm, Bertie the Bunyip wrote: WingFlaps wrote : OK, then if the AOA of the stabilator is constant, and the elevator angle is constant, why does the lift reduce when the trim tab is deflected in the opposite direction? because the elevator angle isnt bloody constant. what is constant is the stick force which you maintain at the same pressure by unconsciously moving the stick as you change the trim tab position. It's as I said, the effect is as if the _effective_ area is reduced. no it bloody isnt. the area remains the same the lift force is what varies and guess what, that's why the tailfeathers have the hinges in the middle. You could say that CL is altered but then it gets more messy as you have to consider different CL's and areas for each section of the stabilator. It's much simpler to just subtract the area taken by the trim from the calculation and that will give a very good first order approximation for longitudinal stability calculations. you have basically started out with a faulty understanding and for the last 100 posts have misinterpreted everything written because you keep relating the information to the original faulty premise. Stealth Pilot |
#142
On May 7, 12:49*am, Stealth Pilot
wrote: On Mon, 5 May 2008 16:55:37 -0700 (PDT), WingFlaps wrote: On May 6, 10:52*am, wrote: On May 5, 1:38 pm, WingFlaps wrote: Does the elevator lift force and *stall angle reflect trim setting at all? Cheers this may surprise you but an elevator is never stalled in flight. Incorrect, any flying surface can be stalled. Cheers |
#143
wrote: On Mon, 5 May 2008 16:55:37 -0700 (PDT), WingFlaps wrote: On May 6, 10:52*am, wrote: On May 5, 1:38 pm, WingFlaps wrote: Does the elevator lift force and *stall angle reflect trim setting at all? Cheers absolutely not! Sorry you are wrong and let me try to explain why. Let's say you've trimmed nose up, the elevator is deflected up but the trim surface is deflected down. Where is the chord line of the tail? The chordline where the trim tab is absent has a negative AOA so the tail lift is downward. In the region of the trim tab, the angle made by the chordline (and therefore AOA) is _reduced_ and the lift is reduced also. -sketch it on paper and you will see it (remember the chord runs from the trailing edge to the leading edge). Now imagine the pilot wants to go into a fast dive. Now the elevator points down and in this case the AOA in the region of the trim tab is increased over that of the rest of the elevator. In this case, the trim has increased tail effectiveness (albeit at a higher stick force) by increasing local camber and that was correctly seen by Bertie. I hope you can see it now. Cheers |
#144
On May 7, 12:56*am, Stealth Pilot
wrote: On Mon, 5 May 2008 23:54:37 -0700 (PDT), WingFlaps wrote: On May 6, 3:36*pm, Bertie the Bunyip wrote: WingFlaps wrote : OK, then if the AOA of the stabilator is constant, and the elevator angle is constant, why does the lift reduce when the trim tab is deflected in the opposite direction? because the elevator angle isnt bloody constant. what is constant is the stick force which you maintain at the same pressure by unconsciously moving the stick as you change the trim tab position. It's as I said, the effect is as if the _effective_ area is reduced. no it bloody isnt. the area remains the same the lift force is what varies and guess what, that's why the tailfeathers have the hinges in the middle. You could say that CL is altered but then it gets more messy as you have to consider different CL's and areas for each section of the stabilator. It's much simpler to just subtract the area taken by the trim from the calculation and that will give a very good first order approximation for longitudinal stability calculations. you have basically started out with a faulty understanding and for the last 100 posts have misinterpreted everything written because you keep relating the information to the original faulty premise. Nope. I understand it perfectly. As defined in any good book on aeronautical design, stabilator effectiveness is _defined_ by the horizontal tail volume coefficient which is the product of tail moment and area divided by the wing area and it's mean chord. From the style of you reply I can see you will have a hard time understanding this this it really is correct -look it up. Cheers |
#145
On May 7, 12:45*am, Stealth Pilot
wrote: On Mon, 5 May 2008 08:59:36 -0700 (PDT), WingFlaps wrote: On May 6, 2:18*am, Stealth Pilot wrote: for heavens sake "wingflaps" as a nom de plume????? real pilots have nome de plumes like "bertie the bunyip" or my all time favourite "buster hyman". wingflaps is the monika of a rank novice. I guess that makes me an unreal pilot? *Oh, I'm sorry was that an adhominem? LOL Cheers you cannot possibly be a pilot. you may have some ultralight experience but you certainly arent a pilot. how can I say this? easy. pilots learn or get taught a subject called 'basic aeronautical knowledge' which they pass an exam on. you do not have sufficient understanding to get even a third of the pass mark required. if you had studied and passed the BAK you wouldnt be so perpetually stupid regarding the questions you ask. Perhaps it is you who does not understand the depth of the questions I ask? But I'm sure you must be right, I can't possibly have any understanding of the interplay of trim and trimmed surface with the airflow over them because I'm not a pilot in your world. Cheers. |
#146
On May 6, 7:16 am, WingFlaps wrote:
On May 7, 12:49 am, Stealth Pilot wrote: this may surprise you but an elevator is never stalled in flight. Incorrect, any flying surface can be stalled. Cheers Can be, but can't be under normal conditions. Ice will do it, as could unlimited aerobatics, but the average FAR 23 airplane is certified for neither. The key here involves what the airplane is certified for, and the FAR 23 airplane meets the requirements of that Part. You can postulate endlessly about decreased effectiveness of the elevator with the tab deflected, but believe me, the engineers (and some of the others lurking here) are way ahead of you on this and any other item you care to mention. If those engineers didn't take this stuff into account the airplane simply wouldn't get certified and you would never get a chance to fly it. Rather than arguing from ignorance, you should find some good books on aeronautical engineering and bone up on some basics first. Dan |
#147
On May 7, 2:52*am, wrote:
On May 6, 7:16 am, WingFlaps wrote: On May 7, 12:49 am, Stealth Pilot wrote: this may surprise you but an elevator is never stalled in flight. Incorrect, any flying surface can be stalled. Cheers * *Can be, but can't be under normal conditions. Ice will do it, as could unlimited aerobatics, but the average FAR 23 airplane is certified for neither. The key here involves what the airplane is certified for, and the FAR 23 airplane meets the requirements of that Part. You can postulate endlessly about decreased effectiveness of the elevator with the tab deflected, but believe me, the engineers (and some of the others lurking here) are way ahead of you on this and any other item you care to mention. Yes they lurk well. If those engineers didn't take this stuff into account the airplane simply wouldn't get certified and you would never get a chance to fly it. This has nothing to do with certification. * * Rather than arguing from ignorance, you should find some good books on aeronautical engineering and bone up on some basics first. LOL!!!! Been there done that. What about you? I've only detected deep insight in Bertie so far , but I'm comforted by the deep knowlege that your lurkers must have. Cheers |
#148
On May 6, 7:16 am, WingFlaps wrote: On May 7, 12:49 am, Stealth Pilot wrote: this may surprise you but an elevator is never stalled in flight. Incorrect, any flying surface can be stalled. Cheers * *Can be, but can't be under normal conditions. Ice will do it, as could unlimited aerobatics, but the average FAR 23 airplane is certified for neither. As you agreed earlier COG out of limits can lead to it too. The key here is that the statement "never" is incorrect. Any plane can have it's elevator stalled, I agree that may be bad thing to happen but it can happen none the less. I would not put much faith in FARs preventing such things if I were you :-P Cheers |
#149
On May 6, 9:13 am, WingFlaps wrote:
If those engineers didn't take this stuff into account the airplane simply wouldn't get certified and you would never get a chance to fly it. This has nothing to do with certification. Oh, it doesn't? Then, tell me, what items DO have to do with certification, if elevator effectiveness at any trim tab position isn't one of them? Find and quote the references to support your claim. Dan |
#150
On May 7, 3:28*am, wrote:
On May 6, 9:13 am, WingFlaps wrote: If those engineers didn't take this stuff into account the airplane simply wouldn't get certified and you would never get a chance to fly it. This has nothing to do with certification. * * * * *Oh, it doesn't? Then, tell me, what items DO have to do with certification, if elevator effectiveness at any trim tab position isn't one of them? Find and quote the references to support your claim. Dan, you keep trying to pick up the wrong end of the stick. I'm not talking about certification. For example, in the FARs does it describe how the stabilator chord changes with trim positions? Certification results from practical demonstrations of plane handling and flying not theoretical aeronautical discussions -or is that not so? Cheers |
The Sky is Their Limit | [email protected] | Soaring | 7 | November 13th 06 02:44 AM |
speed limit in class B | Andrey Serbinenko | Piloting | 0 | July 23rd 06 04:05 AM |
Pegasus life limit | Mark628CA | Soaring | 2 | March 30th 06 10:37 PM |
Aft CG limit(s) | Andy Durbin | Soaring | 13 | November 26th 03 05:10 AM |
Pushing the limit | Dan Shackelford | Military Aviation | 20 | September 14th 03 10:27 PM |
