poor lateral control on a slow tow?
Old December 31st 10, 11:40 AM posted to rec.aviation.soaring
Doug[_5_]
Default poor lateral control on a slow tow?
As an aerodynamicist/flight dynamicist recently re-soloed after 25 years
off, people keep asking me hard questions. One that has come up recently is
why a heavy glider on tow feels horrible, but thermalling in the same glider
at lower speeds is fine? (see also Mike Fox's article on aerotowing in the
October issue of S&G).
I did some calculations, and I reckon it's probably due to the tug wing wake
(tip vortices generating a downwash inboard, upwash outboard) changing the
lift distribution on the glider wing - with an increased angle of attack out
at the tips reducing aileron effectiveness. There's possibly an interesting
academic research project here, but it's always best to get a reality check
first ...
Is poor handling at low speed on tow a common experience? I'd appreciate
any thoughts/comments/war stories ... particularly bad tug/glider/speed
combinations, incidents of wing drop during a tow etc etc?
Doug Greenwell
Old December 31st 10, 02:03 PM posted to rec.aviation.soaring
wladkummer76
off, people keep asking me hard questions. *One that has come up recently is
at the tips reducing aileron effectiveness. *There's possibly an interesting
first ...
Is poor handling at low speed on tow a common experience? *I'd appreciate
Doug Greenwell
Sure, even more with flaps equipped ships! But yaw control seems to be
more affected than roll. Can we explain that?
Just a little faster please is what doctor ordered here...usually 5
mph more is enough to a more pleasant tow.
Old December 31st 10, 02:59 PM posted to rec.aviation.soaring
Doug[_5_]
"wladkummer76" wrote in message
is
glider
wake
out
interesting
check
first ...
Doug Greenwell
Good question ... the only thing I can think of at the moment is that the
tug tip vortices would also generate an inwards 'sidewash' flow above the
wake, which would be stronger the heavier and slower the tug was. If you
are then for some reason off to one side of the tug the sidewash at the fin
from the nearer vortex would tend to yaw you 'nose-out', in the wrong
direction.
Doug
Old December 31st 10, 04:35 PM posted to rec.aviation.soaring
sisu1a
I'm going to assume your flying with a nosehook, in which case the big
tether is resisting motion in the yaw axis... whereas for roll the
towrope runs directly down the longitudinal axis, leaving airspeed/AoA
as the dominant external forces affecting roll.
The rope also holds the glider at unnatural attitudes for given
airspeeds, which I think contributes a lot to the lack of perceived
(less than usual for that particular airspeed) aileron authority,
contributing greatly to making the glider feel horrible on tow,
despite being well within it's stall speed.
Not as an endorsement for or against this arrangement but from an
aerodynamic prospective rather, a CG hook leaves the yaw axis pretty
free to swivel accordingly and likely reduces the rope induced AoA
affecting aileron authority as well *once in a steady climb. (*not to
be confused with the up pitching tendency these hooks are famous for
during the initial acceleration of a launch...)
-Paul
Old December 31st 10, 05:21 PM posted to rec.aviation.soaring
Andy[_1_]
-Paul
Since the possible influence of hook position has been introduced,
I'll have to add that all my tows in the 28 have been on the CG hook
as were all my tows in the 19 I had before that.
One factor that has not been mentioned yet is the fact that a
ballasted glider has much higher roll inertia that a dry one. This
will require larger aileron inputs to get the same roll response and I
suppose could lead to an aileron stall.
I don't remember ever having loss of control authority on an
unballasted tow and maybe there is more to that than just the
difference in stall speeds.
Andy
Old December 31st 10, 05:19 PM posted to rec.aviation.soaring
Doug Greenwell
good point - a nose hook would tend to improve yaw and pitch stability on
tow, but have little effect on roll, so it's difficult to split out the
effects of aerodynamics and tow cable dynamics. I did some work years ago
on towed bodies (aerial targets and sonar fish) and the coupling effects
between cable and body motion get really complicated.
yes - I'm sure there must be a pyschological element as well
-Paul
I think the rope effects on stability with a nose hook are generally
favourable - its the aerodynamic effects of the tug wake that cause the
problems
Old December 31st 10, 02:44 PM posted to rec.aviation.soaring
Andy[_1_]
Well not for me, but only because I don't often get towed slow. For
my ballasted ASW-28, 65kts indicated in the glider is as slow as I'd
like to be. On the few tows that the speed has dropped to 60kts it's
barely possible to stay in control in any sort of turbulence. Both
pitch and roll control are greatly reduced, I never noticed a problem
with yaw control.
Slow tows only seem to be a problem for me when I go to an site that
uses tow pilots that have no high performance glider experience but
they still know better than the glider pilot what speeds are needed.
Fortunately there are not too many of those.
The worse possible case is the tow pilot that refuses to follow the
simple instruction to stay in ground effect until a safe tow speed is
reached.
Some glider pilots don't realize how hopelessly inaccurate the tug
airspeed indicator may be on tow and they ask for the speed they'd
like to see in the glider. Bad idea. Far better to ask for a speed x
kts or mph higher than they use for the gliders they tow everyday.
Andy
Old December 31st 10, 03:05 PM posted to rec.aviation.soaring
John Cochrane[_2_]
Well not for me, but only because I don't often get towed slow. *For
like to be. *On the few tows that the speed has dropped to 60kts it's
barely possible to stay in control in any sort of turbulence. *Both
with yaw control.
This is precisely the aerodynamic puzzle. The same standard class
glider stalls in the low 40s and is perfectly happy thermaling at
45-50. So why does 60 feel so awful on tow?
This does seem a lot worse in standard class than 15 meter, another
hint for the puzzle.
If it were downwash, one would think that just flying higher would
solve it. But that's the best theory I've heard so far.
I have seen quite a few contests with tow pilots who had little
experience with fully ballasted gliders. It's really important to get
the word out to them 1) yes, we really want to tow that fast. 2) get
up to speed in ground effect, then start climbing.
I distinctly remember that helpless feeling sitting in a tanked up
discus, crossing the end of the runway, as the towplane departed what
looked like straight up at about 50 knots.
On another occasion, every single tow by one pilot was accompanied by
a chorus of demands for more speed on the radio. Eventually he piped
up "what do y'all want to fly so fast for anyway?'' I guess the 2-33
never wanted to go 70 on tow.
John Cochrane
Old December 31st 10, 03:31 PM posted to rec.aviation.soaring
Doug Greenwell
=A0For
like to be. =A0On the few tows that the speed has dropped to 60kts
it's
barely possible to stay in control in any sort of turbulence. =A0Both
with yaw control.
John Cochrane
In the normal tow position I don't think you can get high enough to get
away from the wing wake without tipping the tug on its nose. On the other
hand, my simple modelling suggests that a typical low tow position should
be a lot better.
15m vs standard class ... Forgive my ignorance (I've never flown a
flapped glider), but presumably a 15m glider is towed with the flaps
deflected, which would tend to unload the tips and hence maintain aileron
authority at high incidence. Would the ailerons typically be drooped at
this flap setting?
Doug
Old December 31st 10, 04:07 PM posted to rec.aviation.soaring
Andy[_1_]
On Dec 31, 8:05*am, John Cochrane
The same standard class glider stalls in the low 40s and is perfectly happy
thermaling at 45-50.
Not mine, at least not when ballasted. Most of my flying is done
where the thermals are small cored and often rowdy. 50kts would only
work in a very smooth thermal that was big enough to use a low bank
angle.
However, the D2 which does seem to climb well at low speeds seems to
be really sensitive to being towed slow, at least that I understand
from one of the local pilots. Maybe D2 owners could comment on that?
Andy
another poor man's car engine conversion jan olieslagers[_2_] Home Built 19 February 22nd 09 03:49 PM
Poor readability Kees Mies Owning 2 August 14th 04 04:22 AM
Poor Guy Bob Chilcoat Owning 6 July 17th 04 06:45 PM
I'm grateful for poor people who are willing to murder & die Krztalizer Military Aviation 0 April 20th 04 11:11 PM
Concorde in FS2002: No lateral views A. Bomanns Simulators 3 July 19th 03 11:33 AM
