#151
running with scissors wrote in
message om... "John Gilmer" wrote in message ... "Bob Gardner" wrote in message news:QODIb.85072$VB2.187788@attbi_s51... No way. You start off at sea level, of course, and they pump the chamber pressure down to 25000 feet with masks on...then they do some experiments with a few of the pilots taking their masks off, just to show how severely their abilities are affected. Then comes the explosive decompression, which takes the chamber from 25K back down to sea level in a second or two. SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? EMWTK "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances (eg medevac operations where pressurization is a factor) Sec. 25.1 Applicability. (a) This part prescribes airworthiness standards for the issue of type certificates, and changes to those certificates, for transport category airplanes. http://www.astech-engineering.com/sy...apart25d.html# Pressurization Sec. 25.841 Pressurized cabins. "(a) Pressurized cabins and compartments to be occupied must be equipped to provide a cabin pressure altitude of not more than 8,000 feet at the maximum operating altitude of the airplane under normal operating conditions." Transport category: * All jets with 10 or more seats or greater than 12,500lb Maximum Takeoff Weight. * All propeller driven airplanes with greater than 19 seats or greater than 19,000lb Maximum Takeoff Weight. Obviously the rule would not normlly apply to Medivac operations. HTH, Paul Nixon |
#152
![]() "running with scissors" wrote in message m... "C J Campbell" wrote in message ... "Ron Natalie" wrote in message m... | | "C J Campbell" wrote in message ... | | We do not really know any such thing. If the passenger is bigger than the | window he simply cannot be pulled through it any more than he can sucked up | through a vacuum cleaner hose. | | Passengers are pretty flexible. Some might plug up the hole, others will | go through holes that looked like they ought not to fit through. | The windows are surprisingly large, too. I have no doubt that a small person could get through one, especially if his seatbelt is not properly fastened. However, you are not going to lose a whole planeload of passengers this way. Given a choice, I would shoot a hijacker with the off chance of killing an innocent bystander rather than allow the hijacker to drive the plane into a crowded building. ok.. interesting scenario. but what would be the option if the hijacker was a midget ?? Shoot him with a .22? |
#153
![]() "running with scissors" wrote in message FAR 91.211 Supplemental oxygen. ???? |
#154
m... "Gary Mishler" wrote in message news:eBoKb.745162$HS4.5776347@attbi_s01... "running with scissors" wrote in message om... "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances Actually, it depends on the aircraft. Aircraft are certified to certain "differential pressures" which is the difference between in the inside cabin pressure and the outside ambient air pressure. We were talking about transport aircraft. US certificated transport aircraft must keep the cabin altitude below 8000'. Yup, I know. The Lear 60 is a transport category aircraft, certified under Part 25, and it's cabin is normally around +/- 6,500ft. Previous poster said cabin pressure is normally *at* 8,000 and I was just pointing out that it depends on the aircraft. Manufactures of transport category corporate jets seem to take pride in pointing out to potential customers that their jet can maintain a lower cabin altitude at cruise than the competitors, which all depends on the certificated max psid. |
#155
Yup, but the butterfly is not necessarily all the way open at cruise
altitude... Anyway, us ga airplane folks generally don't appreciate how much air flow the compressors can deliver to the cabin, especially if you by pass the cooler - any idea what the cabin temperature go up to if direct feed off the compressor was delivered to the cabin?... Might be a good behavior modification tool... Denny "Jack Davis" wrote That would not be a good guess! ![]() much larger than that. |
#156
"running with scissors" wrote in message om... "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances Actually, it depends on the aircraft. uh huh. i know it does. though if i posted an exact figure for a specific aircraft type, then a whole flood of posts saying i am wrong because "xx" type is pressurized to "yy" Aircraft are certified to certain "differential pressures" which is the difference between in the inside cabin pressure and the outside ambient air pressure. An airframe must be designed to handle the differential pressure required to maintain acceptable cabin altitude up to the max flight level the aircraft is certified to. As an example, the King Air I fly has a normal differential pressure of 6.6 psid. This provides for a cabin altitude of 2,700 up to 20,000 cruise altitude, an 8,700 foot cabin altitude at 31,000 cruise altitude, and a 10,200 foot cabin altitude at 35,000 cruise altitude. In contrast, the Lear 60 I fly has a normal psid of 9.5 (9.7 max) which typically results in a cabin altitudes of around aprox 6,500 up in the 40,000 ish cruise altitudes. |
#157
Michael Williamson wrote in message ...
running with scissors wrote: Michael Williamson wrote in message ... John Gilmer wrote: SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? Typically, they start at whatever the local pressure altitude happens to be (which of course may or may not be sea level, depending on where you happen to have the chamber). Also, I've never experienced in any altitude chamber ride a rapid REcompression down to sea level- it strikes me as a good way to have sinus or ear problems. Mike nope. when the doors on an aircraft are shut the pressure is ambient. thats it. when bleed air pressures the cabin its noramlly to about 8000ft. While the final (steady state) pressure of the aircraft (as determined by the cabin pressurization controller) will end up at its cruise setting, the aircraft is pressurized from takeoff and the cabin altitude will typically climb slowly toward its set value (about 8,000' in this case) rather than follow ambient- the pressurization system is indeed pressurizing the aircraft its initial field elevation up to the cruise pressurization setting. In addition, my above response was poorly worded and I actually was commenting on the pressurization of the altitude chamber- which begins at whatever the ambient pressure happens to be. My bad for not reading the question closely enough. Mike ditto, my bad for not reading closely. although you used the words cabin pressurization, you did use the word chamber too ! |
#158
"khobar" wrote in message news:W_qKb.17919$7D3.14891@fed1read02...
running with scissors wrote in message om... "John Gilmer" wrote in message ... "Bob Gardner" wrote in message news:QODIb.85072$VB2.187788@attbi_s51... No way. You start off at sea level, of course, and they pump the chamber pressure down to 25000 feet with masks on...then they do some experiments with a few of the pilots taking their masks off, just to show how severely their abilities are affected. Then comes the explosive decompression, which takes the chamber from 25K back down to sea level in a second or two. SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? EMWTK "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances (eg medevac operations where pressurization is a factor) Sec. 25.1 Applicability. (a) This part prescribes airworthiness standards for the issue of type certificates, and changes to those certificates, for transport category airplanes. http://www.astech-engineering.com/sy...apart25d.html# Pressurization Sec. 25.841 Pressurized cabins. "(a) Pressurized cabins and compartments to be occupied must be equipped to provide a cabin pressure altitude of not more than 8,000 feet at the maximum operating altitude of the airplane under normal operating conditions." Transport category: * All jets with 10 or more seats or greater than 12,500lb Maximum Takeoff Weight. * All propeller driven airplanes with greater than 19 seats or greater than 19,000lb Maximum Takeoff Weight. Obviously the rule would not normlly apply to Medivac operations. HTH, Paul Nixon medevac ops are not exempt. though under certain medical conditions the cabin my not be pressurized or pressurized to a lower altitude. nitrogen narcosis is one condition that springs to mind. |
#159
"Tom Sixkiller" wrote in message ...
"running with scissors" wrote in message m... "C J Campbell" wrote in message ... "Ron Natalie" wrote in message m... | | "C J Campbell" wrote in message ... | | We do not really know any such thing. If the passenger is bigger than the | window he simply cannot be pulled through it any more than he can sucked up | through a vacuum cleaner hose. | | Passengers are pretty flexible. Some might plug up the hole, others will | go through holes that looked like they ought not to fit through. | The windows are surprisingly large, too. I have no doubt that a small person could get through one, especially if his seatbelt is not properly fastened. However, you are not going to lose a whole planeload of passengers this way. Given a choice, I would shoot a hijacker with the off chance of killing an innocent bystander rather than allow the hijacker to drive the plane into a crowded building. ok.. interesting scenario. but what would be the option if the hijacker was a midget ?? Shoot him with a .22? lol |
#160
message om... "khobar" wrote in message news:W_qKb.17919$7D3.14891@fed1read02... running with scissors wrote in message om... "John Gilmer" wrote in message ... "Bob Gardner" wrote in message news:QODIb.85072$VB2.187788@attbi_s51... No way. You start off at sea level, of course, and they pump the chamber pressure down to 25000 feet with masks on...then they do some experiments with a few of the pilots taking their masks off, just to show how severely their abilities are affected. Then comes the explosive decompression, which takes the chamber from 25K back down to sea level in a second or two. SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? EMWTK "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances (eg medevac operations where pressurization is a factor) Sec. 25.1 Applicability. (a) This part prescribes airworthiness standards for the issue of type certificates, and changes to those certificates, for transport category airplanes. http://www.astech-engineering.com/sy...apart25d.html# Pressurization Sec. 25.841 Pressurized cabins. "(a) Pressurized cabins and compartments to be occupied must be equipped to provide a cabin pressure altitude of not more than 8,000 feet at the maximum operating altitude of the airplane under normal operating conditions." Transport category: * All jets with 10 or more seats or greater than 12,500lb Maximum Takeoff Weight. * All propeller driven airplanes with greater than 19 seats or greater than 19,000lb Maximum Takeoff Weight. Obviously the rule would not normlly apply to Medivac operations. HTH, Paul Nixon medevac ops are not exempt. though under certain medical conditions the cabin my not be pressurized or pressurized to a lower altitude. nitrogen narcosis is one condition that springs to mind. I was thinking about medivac helicopters. Dunno why since medivac goes beyond helicopter operations. Oh well... Paul Nixon |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 05:26 PM |
Invest small Earn Large ($20 000+) | promethean | General Aviation | 0 | October 3rd 03 06:08 AM |
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 04:00 PM |
