#151
("Stefan" wrote)
It's a pretty bad book. You calculated what it takes that one particular glider hits one particular jet. But this isn't of any interest. The relevant question is what it takes that in a sky full of gliders and other aircraft, there will be a collision between any two of them. ....a collision possibility that will pass (in the case of the Hawker) in two tenths of a second, or less. One tenth to enter (and fill) the box, one tenth to exit (or clear) the box. Montblack |
#152
In rec.aviation.soaring Asbjorn Hojmark wrote:
You want the powered aircraft to use it also? And you know that FLARM actually works at those speeds? It's true that it hasn't been tested much in practice, but FLARM is definitely designed to work in powered aircraft as well. Actually, it is already installed in many SEP aircraft in Europe, especially in those susceptible to operate in the vicinity of glider crowded areas. 250kts at a range of 2-3 km still gives you 15s of reaction time. Of course, neither FLARM nor any anti-collision system is a replacement for SEE AND AVOID which should be the highest priority of good airmanship. Regards -Gerhard -- Gerhard Wesp / Holderenweg 2 / CH-8134 Adliswil +41 (0)76 505 1149 (mobile) / +41 (0)44 668 1878 (office) +41 (0)44 668 1818 (fax) http://gwesp.tx0.org/ |
Midair near Minden | Fred | Soaring | 52 | September 1st 06 11:41 AM |
Cloud Flying | Shawn Knickerbocker | Soaring | 48 | August 30th 06 07:21 AM |
Refinish a Glider in Europe | Jim Culp | Soaring | 0 | November 18th 05 04:00 PM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
Newbie seeking glider purchase advice | Ted Wagner | Soaring | 19 | January 2nd 04 07:00 PM |
