#151
cjcampbell writes:
The reason we use jet engines is that they are inherently more powerful and they can operate at high altitudes where the efficiency penalty compared to piston engines is less. At high speeds, drag is a more important factor in fuel economy than engine efficiency, so jet airliners get their best fuel economy at high altitude. But for short hauls where it would just be a waste of fuel to climb to high altitude and descend again, a turboprop will deliver more power than a piston engine with greater fuel economy than a jet. There are still the questions of simplicity and reliability, which I thought were both higher for gas turbines. They are certainly more reliable; and I should think they'd be simpler, too. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#152
cjcampbell writes:
A lot of the time it just gets down to people having more money than sense. There wouldn't be any trace of sour grapes in this, would there? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#153
Follow on...
http://aeroweb.brooklyn.cuny.edu/spe...ocomm/u-4b.htm "Gentlemen: Regarding the U4-B neither the Air Force or any military branch utilized the Shrike. The U4-B was a 560-A model Commander by the time it was picked up by the military. These particular "commanders" utilized the Lycoming GO-480 engines of (275h.p.) later models had 295h.p. The Aero Commander 680E was the last of the "bath-tub" nacelle versions used by them.. By 1959 Aero Design of Bethany, Oklahoma had cleaned up the airframe to include the new "speed-nacelles" found in all current "Shrikes".. President Dwight D. Eisenhower flew in one because he was so impressed with it's safety record, in particular, it's single-engine safety margins. The prototype flew from Bethany,OK to Washington D.C. with the left propeller removed and stored in the baggage compartment. Ted Smith and Gordon Israel had fabricated one of the nicest Business Twins of the period. All Commanders exhibit fantastic flying qualities, rock-solid and stable ideal for IFR operations. Blue Skies, International Helio Assoc. 06/30/2005 @ 15:06" "Jim Macklin" wrote in message news:BVYWg.2133$XX2.1727@dukeread04... | Back in the early 1950s, AeroCommander flew a 500, piston | powered light twin from OKC to Washington, DC with the right | prop in the baggage area. Ike had one on the list of | approved executive travel planes. Ike was a pilot. | | | | "cjcampbell" wrote in | message | ups.com... || || karl gruber wrote: || Some can, easily. || || Karl || || || Hasn't Bob Hooover demonstrated that in the Shrike? || || "Sylvain" wrote in message || t... || by the way, that's one of the things that MS FS gets || wrong with the light twins: with a long enough runway | you || can takeoff with only one engine... || || --Sylvain || | | |
#154
Mxsmanic wrote:
by the way, that's one of the things that MS FS gets wrong with the light twins: with a long enough runway you can takeoff with only one engine... Why can't you do this in real life? for one thing you won't be able to taxi, except in circles; then even if you could line up with the runway, you won't be able to keep the thing straight, because the wheels will be able to counteract the aymetry, and the control surfaces won't be producing enough aerodynamic force to keep the thing straight; even if you do loose the engine once already going, you won't be able to control the aircraft if you are below Vmc; and even if you go that fast, you will be unlikely to be able to climb (which helps when the intent is to get airborne); the Baron in MS FS has none of these problems, and is thus not very realistic... --Sylvain |
#155
Mxsmanic wrote:
Nobody can do things that are physically impossible. except Bob Hoover --Sylvain do you know the meaning of the expression 'tongue in cheek'? |
#156
I hastily wrote:
because the wheels will be able to counteract I meant to write: will NOT be able to counteract --Sylvain |
#157
Jim Macklin wrote:
All internal combustion engines work the same. A turbine just does it as a series of continuous events in different sections of the engine and a piston engine does one at a time so power is produced only 1/4 of the time in a 4 cycle and 1/2 the time in a two cycle. I'm going to print some T-shirts... "SUCK SQUEEZE BANK and BLOW Is there a reason you continually post information that I already know in my direction? |
#158
Jim Macklin wrote:
E90 King Air, F90 King Air 200 King Air. The 300/350 is a transport over 12,500 pounds and has to do it. King Air's are not light twins. |
#159
Sylvain writes:
except Bob Hoover Even he would deny that. And he points out that pilots who attempt the impossible end up dead. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#160
Jim Macklin wrote:
E90 King Air, F90 King Air 200 King Air. The 300/350 is a transport over 12,500 pounds and has to do it. You call those light twins? I call them turboprops. To me a light twin is one where you can't walk down an aisle inside... ie, smaller than cabin class. That means airplanes such as the Duchess, Seminole, Aztec, Seneca, C-310, etc. Compared to airliners, sure, I can see where you might consider a King Air a light twin. But very few of us get to start in one and yet I do have a bit of twin time, mostly in light twins and maybe a third of it in cabin class. I doubt any of them could get out of their own way on takeoff with only one fan turning. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Home Built Aircraft - Alternative Engines - Geo/Suzuki | OtisWinslow | Home Built | 1 | October 12th 05 02:55 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines | Otis Willie | Military Aviation | 0 | October 29th 03 03:31 AM |
