#151
On Thu, 18 Sep 2003 20:15:39 +0100, Keith Willshaw wrote:
[regarding compiling open source software] All of which negates the point of open source which is to be able to make changes. The point of open source isn't so much that *you* can make changes, but that *everyone else* can as well. Which means, for a popular open source program, the changes you want have perhaps already been made... Frankly all Joe Blow wants is to be able to pop his CD in the drive and hit the OK Button when its asks if he wants to install it. Yes, and you can do that with Linux. typically using Java's JAR format: you just put the .jar file in the relevant directory. Java is however horribly resource intense It can be, but it is also an appropriate solution to many problems. The world's most populous country is going for Linux in a big way. How much market share will open-soruce apps have in 2010? That depends on whether or not they software writers ever get paid for their work, that market is notorious for piracy. Piracy is irrelevant consideration to open source software. It is relevant to proprietary software, where it can reduce revenues, which is likely to cause open source to predominate over time. I don't see govmts going bust, that's not really a consideration for them. Governments arent the main customers for software. For operating systems and office suites, they are. In the UK, the main customer for these sorts of software is the state. The same in most other countries. -- A: top posting Q: what's the most annoying thing about Usenet? |
#152
On Thu, 18 Sep 2003 20:09:18 GMT, Chad Irby wrote:
But with the number of missiles around Baghdad in GWI and II, it easily qualifies. Don't understand you. Lots of missiles and radar = "heavily defended." But weren't a lot of them old and obsolescent? And since you're claiming that stealth isn't that important, I don't recall ever making that claim -- perhaps you could vremind me where I did. By trying to show that it's not that effective, I'm not trying to show it isn't effective, I'm trying to find out how effective or otherwise it might be. and imagining odd ways of detecting a plane with non-radar techniques that won't work. You seem to have already decided they won't work. I'm sorry you seem to have a closed mind on this issue. With pure visual, planes are pretty hard to find at anything like a safe distance. What do you mean by "safe distance"? Far enough away so they won't kill you. If you are manning a passive sensor, the planes won't know where you are unless they are virtually on top of you, say a few hundred meters away. By which time the planes are already dead. If you're in a plane, you're not going to be using image magnification to find the other guy, unless you know right where he's coming from in the first place. I more had in mind an observer on the ground. "Hey, a plane just flew over!" "Great, where is it?" "Uhhh... it went west..." Er, no. An observer with modern IR and visual electron systems, linked to a computer network. If we are using visual sensors, we could have several point towards it and use parallax to get the exact position. Each of which would then have to find the very tiny object. That's covered below. Once the first has, the second knows approximately where to look. You also lose them for 1/2 of the day (pure optical sensors are not too good at night), on cloudy days, if there's smoke in the way, if the sun's behind the target... and you need a *lot* of them. With the curvature of the Earth in the equation, you're going to need a linked ground observer station every 20 miles or so - at *best*. I was assuming they'd be closer than that. Once the position is got, the defenses can fire a missile to intercept, using ground-controlled mid-course guidance, and active radar (or IR) terminal homing. All of which are vulnerable to spoofing or jamming. Oops. How would it be vulnerable to spoofing, given that the missile and ground station could use modern cryptographic techniques to verify each others identity? Identifying is fairly easy. Either use IFF or the known positions of friendly aircraft to know whether it's hostile. If you know it's hostile, use the size of sensor returns to guess more or less what it is (cruise missile/ small fighter/ big fighter/ AEW), though the precise nature isn't very important, since in all cases the response would be the same. So the other guys pop up a plane or two and get you to actively ID them, or you target them with a long-range radar (that doesn't work because they're too stealthy), because some guy saw something the couldn't really identify... and then they kill you between reloads, because the other "Wild Weasel" plane is at 50,000 feet, above the clouds, unseen by your ground observers, watching where the missiles came from. Later that night, they kill your launchers. What if each launcher only contains one missile? Or the launchers are mobile, and move after every launch? Note that there's no need for the launchers, radars, and other sensors to be particularly close to each other. I imagine also that there's no need for the radar transmitters and receivers to be located together either -- perhaps people with more knowledge than me can verify this. Also, radio astronomers use multiple dishes to creatre the effect of one big dish -- I wonder if this would work with networked radars. Narrowing down the field of view enough to make visual ID makes for a lot less coverage per sweep. If you know where the target is, it gets fairly easy, but you have to look in the right direction first, and hope there's no clouds or haze in the way. Yes. ...and *that's* why people don't use visual acquisition and targeting. A system with a useful "uptime" of a couple of hours a day is a loser in so many respects... People *do* use visual acquisition and tracking. The British army for example. -- A: top posting Q: what's the most annoying thing about Usenet? |
#154
"phil hunt" wrote in message . .. On Thu, 18 Sep 2003 20:15:39 +0100, Keith Willshaw wrote: [regarding compiling open source software] Piracy is irrelevant consideration to open source software. It is relevant to proprietary software, where it can reduce revenues, which is likely to cause open source to predominate over time. Its highly relevant when software costs a shedload of money to develop. Developing software that does complex tasks like process simulation costs a LOT of money and contrary to popular belief many software companies walk a line awfully close to bankruptcy. Finding that your software can be bought for $2 a time in Beijing is mighty disheartening I don't see govmts going bust, that's not really a consideration for them. Governments arent the main customers for software. For operating systems and office suites, they are. In the UK, the main customer for these sorts of software is the state. The same in most other countries. Cite please. I seriously doubt the UK Government owns the majority of PC's in this country Keith |
#155
[snip, save space]
http://www.washington-report.org/bac...91/9104034.htm Even Begin agreed that both the 56 and 67 wars were "wars of choice" on Israel's part, and that it initiated the combat: "It was 12 years ago when Prime Minister Menachem Begin admitted in public that Israel had fought three wars in which it had a "choice," meaning Israel started the wars. Begin's admission came in a speech delivered on Aug. 8, 1982, before the Israeli National Defense College. His purpose was to defuse mounting criticism of Israel's invasion of Lebanon, which had begun two months earlier on June 5 and was clearly one of Israel's wars of "choice." The others were in 1956 and 1967...[Begin Begin quote] "Our other wars were not without an alternative. In November 1956 we had a choice. The reason for going to war then was the need to destroy the fedayeen, who did not represent a danger to the existence of the state...In June 1967, we again had a choice. The Egyptian army concentrations in the Sinai approaches do not prove that Nasser was really about to attack us. We must be honest with ourselves. We decided to attack him. This was a war of self-defense in the noblest sense of the term. The Government of National Unity then established decided unanimously: we will take the initiative and attack the enemy, drive him back, and thus assure the security of Israel and the future of the nation." http://www.washington-report.org/bac...94/9407073.htm Unfortunately, conventional wisdom, as exhibited by continual Israeli pronouncements and the meager coverage provided by a main-line media that prefers to stick with the original "Israel was forced into war" concept, means that many today still cling to the old notion that Israel had no choice in its wars with its neighbors that have netted them the land originally mandated to the Palestinians, along with a chunk of Syrian territory. Brooks Google search reveals that your quotes appears only in the Palestinian "washington-report". Why do you post the EXACT same response twice to different posts? Sighhh...well, here it is again: General Yitshak Rabin, Chief of Staff, Israeli Defence Forces: a.. "I do not believe that Nasser wanted war. The two divisions which he sent into Sinai on May 14 would not have been enough to unleash an offensive against Israel. He knew it and we knew it." (Le Monde, February 28, 1968 ) Menachem Begin, Minister without Portfoli: a.. "In June l967, we had a choice. The Egyptian Army concentrations in the Sinai approaches do not prove that Nasser was really about to attack us. We must be honest with ourselves. We decided to attack him." (New York Times, August 21, 1982) Again, are you now gonna claim that the NYT and Le Monde are "Palestinian" fronts? LOL! Brooks I looked for it again and didn't find it in any reliable site on the net. I tried searching with google, copernic and on Hebrew. One only needs to enter their main page in order to realize that their reliability is not bigger that that of the former Iraqi information minister (Sahaf). http://www.wrmea.com Why the quotes you brought doesn't appear not even in one reliable neutral or Israeli source acroos the net? Also, debating with you in the past, when I proved something to you, you just snipped it and few posts later repeated your unproven claims that I just disproved. So don't bother... I'm not persisting on this issue in order to "win the debate". If you were right and I was wrong then I learned something new. But it's important for me to fix the false impression (on my opinion) that you created, saying that Israel was the aggressor on 1967 and the Arab were not the aggressors. Look, don't get me wrong, but this argumentation reminds me what some people use to explain why Hitler invaded the USSR in 1941: "sooner or later the Soviets would attack; they were preparing, so it was better to strike first". In addition to what I said above, let me add that I do consider the party that initiates the fighting as aggressor. Unless the shots were fired everything else is possible: once the fighting starts the situation changes considerably. There was certainly a threat for Israel in 1967, but it was Israel who attacked first. Pre-emptive or not, starting a war and conquering enemy territory, and then holding it for decades to come, is an aggressive movement in my opinion beyond any doubt. I disagree with you, but for now it will be enough for me to show that the only aggressors in 1967 were the Arabs. If it was the Arabs "alone", then why is Israel still holding the Golan? Why was the West Bank annected? Why have the Israelis built settlements there? If Israel was not an aggressor and there was no intention to conquer, they why were all these things done? Perhaps I'm oversimplifying: feel free to acuse me for this. But, as long as nothing changes in this regards you can't expect me to consider Israel anything but an aggressor in 1967. If it's important to you, then we could check specifically war after war, incident after incident. Maybe then and when looking on the wider picture we could find arguments we both agree upon. I rather think this is important for you: I doubt you can change my mind in this regards. It is you who brought the 1967 matter into this thread, not me. For me it's just important to correct your false claim (on my opinion) regarding that war. Err, I draw several general conclusions. You jumped on the part about the Six Day War. So, sorry, but there must be a misunderstanding of a sort here if you still instist I brought the issue of 1967 to this thread. If, then I brought not only the issue of 1967, but also all the other Arab-Israeli wars of the last 55 years on this thread. This, however, is needed for such like you in order to understand the situation in the context of the answer to the question: would Saudi EF-2000s be a threat for Israel or not. The answer to this question, namely, is negative: no, they would not be a threat, but Israel is a threat for its neighbours. Why? See bellow. 1. If you try to insinuate that the blockade of the Tiran straits wasn't a proper casus belly, or that the six days war wasn't a no choice war for Israel, then look at what I wrote above. I saw it and this is not going to change my opinion. 2. If you are honestly trying to find out whether the "talk about the Saudis eventually buying EF-2000s" will prompt Israel to open a war, then the answer is no. To be honest, I'm not so sure. Perhaps not an outright war, but the Israeli political (or, should I actually say "military", as Israel is meanwhile largely lead by former military officers) leadership is meanwhile so paranoid that one can really expect everything from it. 3. Saudi-British negotiations are not an existential threat for Israel. Given the reactions of the Israeli media, and the Israeli lobby in the USA every time the Arabs buy something, apparently they almost are. When the Egyptians buy 20 AGM-84 Harpoons, one can read everywhere about "new threats" for Israel. When the Iranians test their IRBMs, that's also a threat. When the Saudis talk about buying EF-2000 there is also similar screaming (see this thread) etc. No, these are no "existantial threats" at all, but your people make them look as such. When Israel is buying 60 (more) F-16, developing and producing nuclear and other WMDs, not caring at all for international conventions and regulations, that's - "of course" - for "defence purposes"... So, it's this biased campaign which is so disturbing for me. At earlier times I was pro-Israel. I'm not any mo I'm getting sick of such and similar propaganda. To make it clear again: I'm not saying that Arabs are any better either, but what Israel is doing meanwhile, and what its politicians and representatives do and how they act is simply too much. 4. I don't have the capability to do an exact assessment of the threat to Israel in case that Saudia or Egypt will buy Eurofighters. And this is why I started this thread. To get more information. Well, just keep it simple: how many wars the Saudis have started against Israel? How many times have their troops REALLY AND ACTIVELLY participated in fighting against Israel? Let's be honest: the answer is actually 0. Yes, "technically", they're still at war with Israel. But, practically? It was token support the Saudis were providing to other Arabs in 1948 and in 1973, nothing really more. Last year it was exactly the Saudis who were offering a recognition of Israel and peace - under specific conditions: something "unthinkable" for most of the other Arabs. These reasons alone should actually be enough for you not to have to expect the Saudi EF-2000 to be any kind of a serious threat for Israel either. And, there are still plenty of additional reasons which indicate the same. Tom Cooper Co-Author: Iran-Iraq War in the Air, 1980-1988: http://www.acig.org/pg1/content.php and, Iranian F-4 Phantom II Units in Combat: http://www.osprey-publishing.co.uk/t...hp/title=S6585 |
#156
On Fri, 19 Sep 2003 04:40:40 GMT, Chad Irby wrote:
In article , (phil hunt) wrote: If you are manning a passive sensor, the planes won't know where you are unless they are virtually on top of you, say a few hundred meters away. By which time the planes are already dead. A few hundred meters. Except that in a high/high/high precision strike mission, the closest the planes get to you is nine miles straight up. And how are planes going to detect a camoflaged passive sensor at 9 miles? It's a lot harder that a guy on the ground detecting a plane 9 miles up -- the contrast with the sky is obvious. Er, no. An observer with modern IR and visual electron systems, linked to a computer network. As Phil busily reinvents the WWII Ground Observer Corps... Once the first has, the second knows approximately where to look. And by the time they figure that out, Ever heard of electronics? Electronic messages are transmitted very quickly, and computers can process billions of instructions per second. the first guy's lost it. The best you could hope for is a whole string of guys saying "I saw a plane a minute or so back." Are you stupid, or are you deliberately not understanding? Run a half-dozen planes through at a time, and suddenly half of your planes get through with no effective ID. You also lose them for 1/2 of the day (pure optical sensors are not too good at night), on cloudy days, if there's smoke in the way, if the sun's behind the target... and you need a *lot* of them. With the curvature of the Earth in the equation, you're going to need a linked ground observer station every 20 miles or so - at *best*. I was assuming they'd be closer than that. So, for a country the size of, say, Iraq, In Iraq, a lot of the country is unpopulated desert. This is true of most countries. Obviously some areas would be more heavily defended than others -- around the national capital, for example. you'd need an observer every ten miles (each being responsible for about 30 square miles - you have to have some overlap), linked together with a modern computer/comm network. You'd have 6000 observer stations, I've no idea where you get this number from. each with at least four observers on duty at all times, hoping for clear weather. And only working in daylight. IR works at night. Manpower alone would take up about 24,000 people on duty... with support crews, tech, extra coverage, you're looking at 30,000 to 50,000 people. For a system that only works part of the time, at best. Say 50,000. Using Iraq as an example, again, the population of that country is roughly 25 million, so we're talking about 0.2% of them, most of who would be reservists. By way of contrast, during WW2 the UK with roughly twice that population employed 1 million in the RAF. What if each launcher only contains one missile? Or the launchers are mobile, and move after every launch? You keep putting restrictions on the usefulness of your system... Placing each launcher separately does not restrict the usefulness of the system; it enhances it by making it more survivable. Note that there's no need for the launchers, radars, and other sensors to be particularly close to each other. No, you pretty much killed the whole thing with the manpower requirements for the optical part. People *do* use visual acquisition and tracking. The British army for example. Everyone does, sorta. Nobody *relies* on it any more, though, because it's really not that effective for anything other than "hey, look, a plane," or "did you hear something?" You are wrong. The British army uses it to shoot down aircraft, not just to spot them. Google Starstreak if you don't beleive me. Other missile systems that use some of the ideas I'vre been discussing are the Swedish RBS 23 BAMSE, which can use IR sensors, the US Avenger, the French Mistral, and indeed all IR missiles. -- A: top posting Q: what's the most annoying thing about Usenet? |
#157
On Fri, 19 Sep 2003 10:06:30 +0100, Keith Willshaw wrote:
"phil hunt" wrote in message ... On Thu, 18 Sep 2003 20:15:39 +0100, Keith Willshaw wrote: [regarding compiling open source software] Piracy is irrelevant consideration to open source software. It is relevant to proprietary software, where it can reduce revenues, which is likely to cause open source to predominate over time. Its highly relevant when software costs a shedload of money to develop. Developing software that does complex tasks like process simulation costs a LOT of money and contrary to popular belief many software companies walk a line awfully close to bankruptcy. Finding that your software can be bought for $2 a time in Beijing is mighty disheartening Then perhaps the proprietary software model is outdated, at least for some application areas. Had a typical Linux distribution been made by traditional proprietary techniques, it would cost $ 2 billion to develop. Yet it was developed anyway, without being able to recoup revenue by sale of copies. I don't know how many people use process simulation software, so it may not be a good example. But I'll use it anyway -- you can imagine I'm talking about a different application area if you like. Someone writes a simple program to to process simulation. it isn't very sophisticated, but it does the job for the needs of that one user. He releases it as open source. Someone else finds it *almost* fulfills their needs, and extends it, giving their changes back to the first person. A third person works for a largish company and realises that with a bit of effort this package could be useful to them -- so they add to the code and can use it. Eventually, the package gets more and more features applied to it, and can do everything the proprietary packages can do. As I said, I don't know much about process simulation, but there are open source packages that have been extended in just that way. For operating systems and office suites, they are. In the UK, the main customer for these sorts of software is the state. The same in most other countries. Cite please. I seriously doubt the UK Government owns the majority of PC's in this country I never said it, did, only that it owns more than anyone else. -- A: top posting Q: what's the most annoying thing about Usenet? |
#158
"phil hunt" wrote in message . .. On Fri, 19 Sep 2003 10:06:30 +0100, Keith Willshaw wrote: "phil hunt" wrote in message ... On Thu, 18 Sep 2003 20:15:39 +0100, Keith Willshaw wrote: [regarding compiling open source software] Piracy is irrelevant consideration to open source software. It is relevant to proprietary software, where it can reduce revenues, which is likely to cause open source to predominate over time. Its highly relevant when software costs a shedload of money to develop. Developing software that does complex tasks like process simulation costs a LOT of money and contrary to popular belief many software companies walk a line awfully close to bankruptcy. Finding that your software can be bought for $2 a time in Beijing is mighty disheartening Then perhaps the proprietary software model is outdated, at least for some application areas. Had a typical Linux distribution been made by traditional proprietary techniques, it would cost $ 2 billion to develop. Yet it was developed anyway, without being able to recoup revenue by sale of copies. I don't know how many people use process simulation software, so it may not be a good example. But I'll use it anyway -- you can imagine I'm talking about a different application area if you like. Someone writes a simple program to to process simulation. it isn't very sophisticated, but it does the job for the needs of that one user. He releases it as open source. Someone else finds it *almost* fulfills their needs, and extends it, giving their changes back to the first person. A third person works for a largish company and realises that with a bit of effort this package could be useful to them -- so they add to the code and can use it. Eventually, the package gets more and more features applied to it, and can do everything the proprietary packages can do. I'm aware of how open source works and for some applications its great. I have used GNU emacs for may years for example. As I said, I don't know much about process simulation, but there are open source packages that have been extended in just that way. Process simulation is VERY different. For one thing the knowledge base is often proprietary and we spend a lot of money licensing that technology but more important a process simulator is a massive piece of software developed by teams in multiple locations around the world. The other issue is that the output is safety critical, getting it wrong at best results in a millions or billions of dollars being spent on failed designs and at worst you kill a bunch of people. For this reason the testing, QC and vaildation process is long and involved. A new release typically takes between 50 and 200 man years of development and testing time. For operating systems and office suites, they are. In the UK, the main customer for these sorts of software is the state. The same in most other countries. Cite please. I seriously doubt the UK Government owns the majority of PC's in this country I never said it, did, only that it owns more than anyone else. Then by definition they arent the majority purchaser, just another large customer. Keith |
#159
On Tue, 16 Sep 2003 22:30:53 +0100, "Paul J. Adam"
wrote: In message , Alan Minyard writes On Sun, 14 Sep 2003 19:02:28 +0100, "Paul J. Adam" wrote: Have you seen the plots, Al, or just LockMart propaganda? What aspect and frequency are we discussing? No, I have not seen the plots, but looking at, for instance the forward aspect, the inlets and turbine blades are going to light up a radar at quite a range. You mean before or after the redesign to eliminate just that hotspot? What "redesign"? (not being sarky here, I would really like to know :-)) Equivalent value, the Raptor is outnumbered: it's better but not _that_ much better. On current trends the RAF will get more Typhoons than the USAF will Raptors... They will need them. Why? Are we expecting to fight F-22s? No, that would be suicidal. But you will need at least five Typhoons to equal one F-22. Al Minyard |
#160
On Wed, 17 Sep 2003 21:04:36 +0900, Gernot Hassenpflug
wrote: Well, the Japanese had no choice either in 1941, they were in much the same position as Israel, and yet people seem to still think Japan waged an aggressive war.... Gee! The japanese had every choice. All they had to do was stop the war of aggression that they had been waging since 1937. Their despicable attack on Pearl Harbor was an extension of that war. They were incredibly stupid in attacking the US. Al Minyard |
| Thread Tools | |
| Display Modes | |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
