#161
On 2007-06-11 19:00:00 -0400, "Maxwell" said:
"Dudley Henriques" wrote in message news:2007061116042375249-dhenriques@rcncom... On 2007-06-11 12:39:10 -0400, "Maxwell" said: No. Barrel rolls do NOT go negative generally. If you went negative you would change the roll arc and destroy the roll. You can unload to 0 g through the top however without destroying the roll arc, but if you do, you have to reapply positive g almost immediately as you pass through inverted to regain the roll arc. As I said, you can do a barrel roll at any positive g; as tight or as little as the flight envelope for the aircraft will allow up to 90 degrees of flight path direction change at the roll apex. Generally the roll profile will be the application of positive g above +1 from the roll initiation (either from level flight or from a slight dive offset to gain energy if needed) followed by coordinated roll and back pressure into the roll arc maintaining positive g with varying back pressure to maintain the roll arc through the roll and through the recovery back to the entry heading. You can NOT at any time during a barrel roll, allow the g to go negative as doing so will instantly destroy the arc of the roll. Dudley Henriques No it won't, and yes you can. I'm sorry, but you are totally incorrect. Dudley Henriques |
#162
Maxwell wrote:
You're ****ting us! Really! An airplane leans in to the turns. Well hell yes... When you want to turn an airplane, don't you just lean over and it mysteriously goes there? Conversely, when you want to turn your motorcycle at speed, don't you give the handlebars a good tweek in the desired direction? What could be easier to understand? Unless you're a narcissistic, arrogant, conceited, pious, prick.......... |
#163
"ManhattanMan" wrote in
: Maxwell wrote: You're ****ting us! Really! An airplane leans in to the turns. Well hell yes... When you want to turn an airplane, don't you just lean over and it mysteriously goes there? Conversely, when you want to turn your motorcycle at speed, don't you give the handlebars a good tweek in the desired direction? Actually, when you want to go quickly in one direction or other on a bike, you tweak the handlebars in the opposite direction to that of the turn. bertie |
#164
Bertie the Bunyip wrote:
"ManhattanMan" wrote in : Maxwell wrote: You're ****ting us! Really! An airplane leans in to the turns. Well hell yes... When you want to turn an airplane, don't you just lean over and it mysteriously goes there? Conversely, when you want to turn your motorcycle at speed, don't you give the handlebars a good tweek in the desired direction? Actually, when you want to go quickly in one direction or other on a bike, you tweak the handlebars in the opposite direction to that of the turn. Now you spoiled Mx's x-spurt answer....... durn......... |
#165
"ManhattanMan" wrote in news:6zmbi.559096
: Bertie the Bunyip wrote: "ManhattanMan" wrote in : Maxwell wrote: You're ****ting us! Really! An airplane leans in to the turns. Well hell yes... When you want to turn an airplane, don't you just lean over and it mysteriously goes there? Conversely, when you want to turn your motorcycle at speed, don't you give the handlebars a good tweek in the desired direction? Actually, when you want to go quickly in one direction or other on a bike, you tweak the handlebars in the opposite direction to that of the turn. Now you spoiled Mx's x-spurt answer....... durn......... Trick is you have to go faster than about 20 mph for that. Think he has? Bertie |
#166
: Bertie the Bunyip wrote: "ManhattanMan" wrote in : Maxwell wrote: You're ****ting us! Really! An airplane leans in to the turns. Well hell yes... When you want to turn an airplane, don't you just lean over and it mysteriously goes there? Conversely, when you want to turn your motorcycle at speed, don't you give the handlebars a good tweek in the desired direction? Actually, when you want to go quickly in one direction or other on a bike, you tweak the handlebars in the opposite direction to that of the turn. Now you spoiled Mx's x-spurt answer....... durn......... Sorry, BTW, I should have known you were trolling him. Bertie |
#167
On 2007-06-10 22:41:49 -0400, "Maxwell" said:
wrote in message ups.com... There was a thread a while ago about how not only could one stay with the force into the seat, but actually maintain 1 G straight into the seat through a roll. If one is flying coordinated, keeping normal to the airplane makes sense. Those how fly aerobatics have a different set of criteria. For what it's worth, watching the in cockpit cameras of some moderatedly skilled pilots, like the Blue Angels, shows them "upright" with respect to the airplane except when G forces sling their heads around, but they do fly coordinated most of the time. But what do they know? That is either untrue, or real misleading. The Blues fly with a different purpose, keep the aircraft on trajectory. When they are flying a knife edge, they are hardly coordinated, as with many other maneuvers. A 1g barrel roll can be done, but the required trajectory of the aircraft is not going to be one that is necessarily eye pleasing for ground demonstration purposes. Actually, when the Blues or anyone else is in knife edge, they are indeed in coordinated flight. You hold the aircraft in knife edge with top rudder and forward neutral stick; this control pressure combination has to be perfectly coordinated to maintain knife edge. You are confusing coordinated with meaning the control pressures must be complementary which is a common mistake often made. The first lesson we teach in aerobatics is that "coordinated" has absolutely nothing whatsoever to do with the controls not being crossed. Actually, any good flight instructor will teach this to a new primary student during the first hour of dual :-) Dudley Henriques |
#168
"ManhattanMan" wrote in news:6zmbi.559096 : Bertie the Bunyip wrote: "ManhattanMan" wrote in : Maxwell wrote: You're ****ting us! Really! An airplane leans in to the turns. Well hell yes... When you want to turn an airplane, don't you just lean over and it mysteriously goes there? Conversely, when you want to turn your motorcycle at speed, don't you give the handlebars a good tweek in the desired direction? Actually, when you want to go quickly in one direction or other on a bike, you tweak the handlebars in the opposite direction to that of the turn. Now you spoiled Mx's x-spurt answer....... durn......... Sorry, BTW, I should have known you were trolling him. No loss! Any answer would have been devoid of reality anyway - can't imagine Mx doing more than 20mph on a moped, on the back seat, eyes shut, tears forming, never mind............ ![]() |
#169
: Bertie the Bunyip wrote: "ManhattanMan" wrote in news:6zmbi.559096 : Bertie the Bunyip wrote: "ManhattanMan" wrote in : Maxwell wrote: You're ****ting us! Really! An airplane leans in to the turns. Well hell yes... When you want to turn an airplane, don't you just lean over and it mysteriously goes there? Conversely, when you want to turn your motorcycle at speed, don't you give the handlebars a good tweek in the desired direction? Actually, when you want to go quickly in one direction or other on a bike, you tweak the handlebars in the opposite direction to that of the turn. Now you spoiled Mx's x-spurt answer....... durn......... Sorry, BTW, I should have known you were trolling him. No loss! Any answer would have been devoid of reality anyway - can't imagine Mx doing more than 20mph on a moped, on the back seat, eyes shut, tears forming, never mind............ ![]() True, true. Maybe in reality, he's actualy Jerry Lewis.. Bertie |
#170
Jim Logajan wrote in
: Bertie the Bunyip wrote: Nope. the only thing you can do at 1 G is straight and level flight. Nope. I haven't worked out the vector math to see how many solutions exist for other scenarios, but there are an infinite number of solutions where the flight is straight but the aircraft is climbing (or descending) at a constant velocity. So there is no requirment that the flight be level. OK, few excetions, but that's transient. A useful experiment is to check your weight on an elevator - once it reaches constant speed. (Obviously there are accelerations at the beginning and end of the ride where the perception of force is different than 1 G.) Yeah yeah. You can keep positive G around a barrel roll, but not 1 G It's more complicated than that. What you say is true for circular barrel rolls in level flight, but consider this scenario that also yields 1 G and definitely not straight or level: First, consider an aircraft in freefall. Then that's not a barrel roll. Bertie |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
CAP Orientation Pilot? | Robert M. Gary | Piloting | 7 | August 3rd 05 02:22 AM |
ADV: AVIATION T-SHIRTS & HEAD GEAR | Kates Saloon and Knife Emporium | General Aviation | 0 | December 30th 03 11:37 AM |
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR | Kates Saloon and Knife Emporium | Aviation Marketplace | 0 | December 30th 03 11:36 AM |
sounds of aviation navigation equipment as head on a scanner radio | Dan Jacobson | Instrument Flight Rules | 5 | December 4th 03 07:27 PM |
