Airplane Pilot's As Physicists
Old October 9th 07, 09:08 PM posted to sci.physics,rec.aviation.piloting
Le Chaud Lapin
Default Airplane Pilot's As Physicists
Hi All,
There is a long discussion ongoing in rec.aviation.piloting about what
causes lift on a plane. You can read from the link below. Please
note that about 80% of the post are mostly ad hominem attacks and
should be ignored. There are some small bits of real discussion.
http://groups.google.com/group/rec.a...11fa289cd7864a
I am an electrical engineer with experience in analag design and
software, with math and physics background that you would expect of an
electrical engineer.
There are many points made in the discussion, but I would like to
focus on one in particular for the sake of progress.
There are people in the pilot's group, who think that lift on a wing
is analyzed as such:
1. There is air on outside of top of wing that is pushing down, but
reduced because of aerodynamics.
2. The *inside* of the wing contains air pushing up against the
underside of top of wing .
3. Let us ignore that the same air inside the wing pushes down on the
overside of bottom part of wing.
3. The difference in pressure against the underside of the top wing on
the inside of wing and top of wing on outside, is what gives plane
lift.
Note that they ignore the pressure inside the wing that pushes
downward on the wing.
I am trying to convince them that, if there is air on the inside of
the wing, it pushes against all sides of the inside of the wing,
including both top underside and bottom overside, and thereby
nullifying any effect it would have on the wing. Lift is caused by a
difference in pressure between the underside of the bottom of the
wing, and the overside of the top of the wing.
I count 8-9 people in the group who are utterly convinced that I am
inept at physics, mathematics, etc.
Note that some of these people have been flying aircraft for years,
even decades, while I am still a student pilot.
Comments from anyone who knows physics welcome.
-Le Chaud Lapin-
Pilot's Assistant V1.6.7 released AirToob Simulators 2 July 7th 07 10:43 AM
A GA pilot's worst nightmare? Kingfish Piloting 49 February 1st 07 02:51 PM
Pilot's Political Orientation Chicken Bone Piloting 533 June 29th 04 12:47 AM
Update on pilot's condition? Stewart Kissel Soaring 11 April 13th 04 09:25 PM
Pilot's Funeral/Memorial TEW Piloting 6 March 17th 04 03:12 AM
