#161
Bob F. wrote:
Amazing. When you think of airplanes, it's quite natural to think of them as though they are punched out on a production line with a cookie cutter with every nut and bolt exactly the same. It's hard to think of things that complicated as highly individual products each with it's own materials reflecting the hands of the specific people who built it. I'm sure you have noticed this as well through the years; that every airplane has a "personality" all it's own. Some are a pleasure to fly, and another of the same type will have a completely different "feel" to it. Even pilots are this way. Ever notice when you're flying with someone else who has all the guges nailed in to within a fraction of an inch and they hand the airplane over to you to fly for awhile the first thing you always do is retrim the thing because it "just doesn't feel right to you?" :-))) -- Dudley Henriques |
#162
Bertie the Bunyip wrote:
Dudley Henriques wrote in : Bertie the Bunyip wrote: Dudley Henriques wrote in news:vb- : Bertie the Bunyip wrote: Dudley Henriques wrote in : Bertie the Bunyip wrote: "Blueskies" wrote in . net: LeVier did a lot of the high mach number dive tests in the 38, and there definitely was a compressibility problem, mach tuck; the whole works. I know they added speed brakes but not sure at exactly what stage. The engine rotation switch was early on in the program according to Ethell; I believe in the YP38 stage before the first production run. If I'm not mistaken, the high mach dives came after the switch but I'm not at all certain of that. -- Dudley Henriques All the -38s sold to England had same rotation direction engines on both sides all the way through. Just another odd thing... Are you sure about that? Bertie I heard the same thing. The Brits raised hell about what they considered a high degree of possibility for unnecessary maintainence due to the handed engines. On the practical side, the Brits had ordered a ton of P40's which used the V1710 Allison with a right handed prop. The word we got was that the brits wanted the Allison's on the 38's to be interchangeable with the P40 to cut down on cost. Found some info on that in an old book I have. Apparently there were a handful of unblown 38s delivered to the RAF with both engines RH but they had a lot of problems and the remainder all had contra rotating engines. Bertie That's right on the Turbo Chargers. The Brits believed they wouldn't be fighting at the altitudes where the Turbos were an advantage. According to the ariticle on the website they were inherited from a French order and the French wanted them without to avoid delays in deliveries. Bertie That one's new to me, but highly likely :-)) Don't know a whole lot about WW2 aviation. just peripheral stuff, really. You'd be a lifetime at figuring out the whole mess. Bertie I agree. The history stuff is interesting but highly speculative to say the least. Sorting it out can try your patience for sure. I remember Bader telling me about one "historian" who cornered him one evening and proceeded to TELL him about an air battle he had been in personally. When Bader tried to correct the man on a certain detail he personally had experienced, the "historian" argued with him that he (Bader) was wrong! :-)) -- Dudley Henriques |
#164
#165
On Sun, 16 Mar 2008 10:46:27 -0700 (PDT), Dan
wrote: On Mar 16, 1:39 pm, Bertie the Bunyip wrote: That's not dragging it in. 1.3 VSo is standard approach speed for all airplanes. Bertie Right. But if you only target 1.3 Vso, and are 5 mile final in a 152, your angle of approach will be very shallow and you will need lots of power to make it to the touchdown point. So it'd be time for some remedial training. 5 miles out the 150 should still be in level cruise. Flying a long, or straight in final is difficult compared to flying a pattern and not something for a student or pilot who is used to only flying stabilized patterns. It's even more difficult to do a short field landing from far out. Instead of turning final at 500 AGL and nearly 1.3 Vso you have to calculate how far out to start the descent, speed, and angle. So here you are at cruise. You don't have to fly the whole final at 1.3 Vso, but should be stabilized at it as soon as necessary. One key is knowing what the runway environment looks like when turning a normal base to final. It should look the same (angle) from pattern altitude when coming straight in. If it does then you'll pass through the same spot and speed you'd normally see when flying a normal pattern. Of course it's easier to do if you slow up before starting down hill. It makes the energy management so much easier. 1.3 Vso in a 150 with no flaps and full flaps is a whole different ball game. 1.3 Vso, flap requirements, angle of descent and when to stabilize are different for regular and short field landings. I can maintain 1.3 Vso, for either type of landing with full flaps but the stabilization point, will be different. I can do that in a 150, Cherokee 180, or the Deb although "for me" the Deb is the easiest for power/energy management and can come down the steepest. The Cherokee is not far behind, but even at idle, 1.3 Vso, and full flaps I don't think I could call the angle of descent in a 150 steep. (Everything is relative) For those that think a Cherokee glides like a brick, try 1.3 Vso, and full flaps in a Bo. :-)) That's why we carry so much power. Without it we don't have enough energy to flare. Now as to really dragging it in, a Farmer friend has a 1200 foot strip off the end of a bean field. He'd bring his Cherokee in about three feet over the beans and cop the power at the end of the strip. His landings and roll our seldom took more than 200 to 300 feet. Of course if the engine quite he'd just get a plane painted green all over the front. That is unless they were white/navy beans. Those vines (when green) would make a good arresting cable. Not something you'd want tied around the nose gear. So it's 1.3 Vso PLUS the optimal descent angle, where weight complements thrust. Dan Mc Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#166
#167
Dudley Henriques wrote in : Bertie the Bunyip wrote: Dudley Henriques wrote in : Bertie the Bunyip wrote: Dudley Henriques wrote in : Bertie the Bunyip wrote: "Blueskies" wrote in . net: LeVier did a lot of the high mach number dive tests in the 38, and there definitely was a compressibility problem, mach tuck; the whole works. I know they added speed brakes but not sure at exactly what stage. The engine rotation switch was early on in the program according to Ethell; I believe in the YP38 stage before the first production run. If I'm not mistaken, the high mach dives came after the switch but I'm not at all certain of that. -- Dudley Henriques All the -38s sold to England had same rotation direction engines on both sides all the way through. Just another odd thing... Are you sure about that? Bertie I heard the same thing. The Brits raised hell about what they considered a high degree of possibility for unnecessary maintainence due to the handed engines. On the practical side, the Brits had ordered a ton of P40's which used the V1710 Allison with a right handed prop. The word we got was that the brits wanted the Allison's on the 38's to be interchangeable with the P40 to cut down on cost. Well, that's reasonable. Never heard that before. Could be an urban legend based on one photo of an airplane field kitted with two RH engines. A bit like the Fokker DR1 that got an odd aileron and started a legend that they all had one smaller than the other to compensate for torque. Bertie Possible?? Torque correction IS in roll and not yaw as is the common belief :-) Oh the things had torque issues alright, but some nerd of an historian has proven that there was only one DR1 with mismatched ailerons. The eraly ones had one size and the later ones had another and a field repair resulted in the one with two odd ailerons. Since it was a good pictiure showing them clearly and someone did a detailed drawing basd on it, it got lodged in folklore. There were airplanes that had larger wings n the left for this purpose however. Ansaldo, for one. Bertie I guess the WW1 practical test for German AI's missed "aileron mismatch" :-)) Wouldn't be the first or last time! I had two very different wings on a Luscombe with two completely different aileron hinge arrangements. It was a very early 1939 airplane and it must have damaged a wing and one was put on from a later machine. There's a famous pic of a DC-3 that was dmamged and flown for a time with a DC 2 wing, which was considerably smaller.. Early days of WW2 in China, I beleive. Bertie I think I remember that DC3 shot. Lots of spare parts birds out there. Many civvy Mustangs were retrofitted with P63 brakes if that counts :-)) -- Dudley Henriques |
#168
On Mar 16, 2:08 pm, Dan wrote:
On Mar 16, 5:51 pm, "Ken S. Tucker" wrote: .... My 3.1416 cents. Ferrying A/C across the Pacific, I read, the fella's would experiment with lean ratio's and speed. The idea was to max the fuel burn efficiency and minimize the induced wing drag. Of course that needs to consider the parasitic drag of the fuselage, tail and so on. From the standpoint of aerodynamic engineering, experience is the answer. Ken I'm a bit confused by what the point is... But a JPI + GAMInjectors makes leaning lean of peak feasible and productive. Well the discussion is about maxing endurance which is a similiar problem to maxing range. Two a/c of nearly equal weight, say a Flying wing and B-52, have different numbers, of course. Ken |
#169
Dudley Henriques wrote in news:6sWdne4- : Chuck used to feather one engine and do a roll into it. I believe he did some dead stick as well. Oh he did. Definitely. At least i think it was him. It definitely wasn't hoover, anyway. Did he beat the odds? Last I heard, Chuck was alive and well and still flying. -- Dudley Henriques |
#170
On Sun, 16 Mar 2008 09:25:24 -0400, Peter Clark
wrote: On Sat, 15 Mar 2008 19:39:13 -0400, Dudley Henriques wrote: I believe you are repeating wht I have said. I said that "dragging it in" generally refers to flying the approach in the area of reverse command or if you will behind the power curve. This is absolutely Well, time to try again. I had this ready to go and the computer ate it. When flying a Debonair, F-33, and A36 Bo by the POH all landings are done well below the max endurance speed, but not to the point where they don't have enough reserve power to arrest or even change the descent into a climb. They are however in the area where power controls rate of descent and pitch controls speed. correct. Coffin corner is the area behind the curve where sink rate can't be stopped with power but requires reduction in angle of attack. For a perfect example of an aircraft in coffin corner, see the Edwards AFB accident involving a young AF pilot who got his F100 so deep into coffin corner behind the curve he couldn't recover the airplane; not I saw the video and he did one whale of a job balancing on the thrust/tail until he lost it. He just needed a few thousand pounds more thrust. enough air under him to reduce the angle of attack. He applied full burner but couldn't fly it out on power alone. Reduction of angle of attack was what he needed and he didn't have the room. THIS is the definition of coffin corner and it most certainly IS in the area of reverse command. I saw a clip of a 104 that was skidding sideways and then flipped over on its top. I believe the engine seized on that one. any thought? I thought coffin corner was the point where if you go slower you stall and if you go faster you hit critical mach number? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Thinking about stalls | WingFlaps | Piloting | 43 | April 12th 08 09:35 PM |
Stalls?? | Ol Shy & Bashful | Piloting | 155 | February 22nd 08 03:24 PM |
why my plane stalls | Grandss | Piloting | 22 | August 14th 05 07:48 AM |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
