#161
On Sat, 22 Mar 2008 05:10:15 +0000 (UTC), Bertie the Bunyip
wrote: Dudley Henriques wrote in : Bob F. wrote: I had an interesting event years ago with an owner of a light twin who took off from FXE to go to PMP, just after lift off, reach down to pull the gear up, stopped and said, "you know what, It's only 7 miles to PMP, I'm just going to leave the gear down". Ok, sounds ok to me. There was a quick call to PMP, two turns later and we are downwind. He does a GUMPS check and RETRACTS the gear. I said to myself, this is going to be interesting. He's trying to slow the airplane down but hasn't put it together that he just got rid of a lot of drag. He turns final, still over speed, and I ask him to do another GUMP check and he misses it again. Halfway down final I tell him to call the tower and tell him we are going around. He does, initiates a go around procedure and this time, on climb out, realizes the gear is already up. What a surprise look on his face. So after we got on the ground and started talking about this, we wondered what it was that he was actually training himself to do. He was not correlating gear up - take off, gear down -landing. Nor was he correlating "three green - gear down". All he was training himself to do was to "flip the switch into the other position". We talked about using rituals in order to reduce accidents, like when you take off, bring the gear up, no matter how close the next landing will be. I also have never heard of one of my students land gear up since I teach 3 checks. 1 full check list before pattern, 2 enter pattern GUMPS list, and 3 short final say "three green". I do the same, and did so for years while instructing. Many gear up accidents are caused by the go around scenario where the gear cycle gets reversed. I've always taught that a go around means a complete clean up of the airplane, then a recheck of the prelanding checklist. I also agree on the triple check. I suggest a final GUMPS check performed by a verbal touch, identify, and verify method immediately after the base to final turn. There's nothing better to keep you in good health in the aviation business than a good solid no changes allowed habit pattern!! Hmm. My own view of it is that at any given moment, you're screwing somethng up. If there's a mistake to be made, you're going to make it. That means looking around for the error and double checking double checking and double checking again. Assuming that your habits will protect you just never worked for me. I'm not saying you shouldn't have them, far from it, I'm just saying the best safety net I've discovered for myself is that of a heft suspicion that ATC, the company, Boeing, the FO and myself especially, are all conspiring to kill me. I know for a fact ATC has tried a number of times on me:-)) First, I use a verbal checklist, do it, then verify against a written. Even then, if we do it enough times we will see what we expect and particularly when pressed for time. In addition I have a 100 foot gear check. Bertie Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#162
: Remember, we're talking professional display flying here. Some of these guys and gals are unrestricted. That's level 1 flying and vertical recoveries with these guys are made right on the deck. This means extreme accuracy through their top gates where airspeed and altitude have to be exactly right. Too slow and you lose altitude through the float. Too fast and the recovery line is extended. Too low and you have Chris Stricklin's Thunderbird F16 at Mountain Home, and "that ain't good" :-)) Oh I know. No more for me, thanks. Not with what I know now. Bertie |
#163
Roger wrote in
: I know for a fact ATC has tried a number of times on me:-)) First, I use a verbal checklist, do it, then verify against a written. Even then, if we do it enough times we will see what we expect and particularly when pressed for time. Yeah, very good point. The mind often ses what it wants to. One of my earliest instructors repeatedly warned me about this and taught me to touch everything I was checking in a deliberate manner. The theory being that the hand is not so easily fooled as the eye. I especially like you ucing the checklist as a checklist rather than a do list.. In addition I have a 100 foot gear check. Hey, I'd send my kids up with you Bertie |
#164
On Sat, 22 Mar 2008 12:53:25 -0400, Dudley Henriques wrote:
Each pilot should and will develop his/her own method of dealing with the flying environment. The "tools" we ingrain from the beginning will just be integrated and used to reflect this individual platform. The main thing is that we all have to learn to use some form of structure within a solid habit pattern scenario. -- Dudley Henriques The mark of a great instructor (in any field IMO) is the ability to do exactly that. Structure the teaching, make room for the student to absorb it then deliver performance within his own "way", personality, mechanics.....two extreme examples of low and high performances are pitching a baseball/hitting a baseball and hop skotch. You can teach only certain number of principles in the first two, at release or impact, both players will, essentially, be close to the same (within certain tolerances that can be measured). Prior to release or impact, a great deal of variance is not only acceptable but arguably mandatory. This is the personalization of the task, the "way" or mechanics. Hop skotch can be taught the same way to nearly everyone. |
#165
On Fri, 21 Mar 2008 12:18:06 -0400, Roger wrote:
What puzzles me is not the decision to take off, but rather the low climb rate and the decision to use runway 27. If the weather resembled what was reported nearby at OKV, runway 9 would have had a negligible tailwind component. Probably the same reason after all these years of using tools I stuck my thumb in a table saw a little over a month ago. Up 16 hours, something on his mind, decision making capabilities gone out the window. Not making excuses but doctors (for one of many professions) are like this. They are forced to have to deal with fatigue and high level decision making, it usually is someone else's life. Familiarity breeds contempt (of life possibly ITC) |
#166
Bertie the Bunyip wrote:
Dudley Henriques wrote in : Remember, we're talking professional display flying here. Some of these guys and gals are unrestricted. That's level 1 flying and vertical recoveries with these guys are made right on the deck. This means extreme accuracy through their top gates where airspeed and altitude have to be exactly right. Too slow and you lose altitude through the float. Too fast and the recovery line is extended. Too low and you have Chris Stricklin's Thunderbird F16 at Mountain Home, and "that ain't good" :-)) Oh I know. No more for me, thanks. Not with what I know now. Bertie Well don't feel lonely. My "glory days" are long gone as well. I still get a word or two in once in a while, and I'd like to think that my experience helps them a bit, but this new batch of youngsters are some of the best I've ever seen, and they are doing things with airplanes that you and I only dreamed of doing. Patty Wagstaff and I are email buddies. She demonstrates at up to +10g's and -5'gs routinely. It's a whole new world up there :-)) -- Dudley Henriques |
#167
: Bertie the Bunyip wrote: Dudley Henriques wrote in : Remember, we're talking professional display flying here. Some of these guys and gals are unrestricted. That's level 1 flying and vertical recoveries with these guys are made right on the deck. This means extreme accuracy through their top gates where airspeed and altitude have to be exactly right. Too slow and you lose altitude through the float. Too fast and the recovery line is extended. Too low and you have Chris Stricklin's Thunderbird F16 at Mountain Home, and "that ain't good" :-)) Oh I know. No more for me, thanks. Not with what I know now. Bertie Well don't feel lonely. My "glory days" are long gone as well. I still get a word or two in once in a while, and I'd like to think that my experience helps them a bit, but this new batch of youngsters are some of the best I've ever seen, and they are doing things with airplanes that you and I only dreamed of doing. Patty Wagstaff and I are email buddies. She demonstrates at up to +10g's and -5'gs routinely. It's a whole new world up there :-)) Jesus wept. I've been a bit over five Gs and that was extremely punishing. Even that was only in the corners of a square loop and momentary. i can't imagine how bad that would feel to me now. Of course the seating was more upright.. Bertie |
#168
Dudley Henriques wrote in : Bertie the Bunyip wrote: Dudley Henriques wrote in : Remember, we're talking professional display flying here. Some of these guys and gals are unrestricted. That's level 1 flying and vertical recoveries with these guys are made right on the deck. This means extreme accuracy through their top gates where airspeed and altitude have to be exactly right. Too slow and you lose altitude through the float. Too fast and the recovery line is extended. Too low and you have Chris Stricklin's Thunderbird F16 at Mountain Home, and "that ain't good" :-)) Oh I know. No more for me, thanks. Not with what I know now. Bertie Well don't feel lonely. My "glory days" are long gone as well. I still get a word or two in once in a while, and I'd like to think that my experience helps them a bit, but this new batch of youngsters are some of the best I've ever seen, and they are doing things with airplanes that you and I only dreamed of doing. Patty Wagstaff and I are email buddies. She demonstrates at up to +10g's and -5'gs routinely. It's a whole new world up there :-)) Jesus wept. I've been a bit over five Gs and that was extremely punishing. Even that was only in the corners of a square loop and momentary. i can't imagine how bad that would feel to me now. Of course the seating was more upright.. Bertie Patty of course flies a bevy of mounts. Her personal plane is an Extra 300S. It's got a Lycoming modified to 350hp and a roll rate of 420 degrees/sec. Patty works out constantly and is probably in the same shape as an Olympic athlete. She's also flying Jim Beasley's Mustangs. ....and she's pretty too!!! :-)) -- Dudley Henriques |
#169
: Patty of course flies a bevy of mounts. Her personal plane is an Extra 300S. It's got a Lycoming modified to 350hp and a roll rate of 420 degrees/sec. Patty works out constantly and is probably in the same shape as an Olympic athlete. She's also flying Jim Beasley's Mustangs. ...and she's pretty too!!! :-)) You'd have to be in good shape for that. I've been doing a bit in anticipation of the arrival of the Citabria (now pushed back yet another month because of the crap Wx in PA) Just watching those red bull guys gives me a hedache. Bertie |
#170
Dudley Henriques wrote in : Patty of course flies a bevy of mounts. Her personal plane is an Extra 300S. It's got a Lycoming modified to 350hp and a roll rate of 420 degrees/sec. Patty works out constantly and is probably in the same shape as an Olympic athlete. She's also flying Jim Beasley's Mustangs. ...and she's pretty too!!! :-)) You'd have to be in good shape for that. I've been doing a bit in anticipation of the arrival of the Citabria (now pushed back yet another month because of the crap Wx in PA) Just watching those red bull guys gives me a hedache. Bertie We have several Red Bull Pilots in the workgroup. I'm with you. These guys are redefining flying as we knew it. What are they doing to the Citabria..fabric or engine work or both? The weather's beginning to break in Pa. if that helps any. -- Dudley Henriques |
Oshkosh 2004-T-Tailed Pusher Aircraft | Jesse Zufall | Home Built | 3 | February 13th 05 03:12 PM |
The Doctor Says: Flying and Homebuilding Are Privileges, NOT Rights | jls | Home Built | 3 | August 23rd 04 04:49 AM |
For F-5 fans - Iran reveals new F-5 based twin-tailed Azarakhsh fighter | TJ | Military Aviation | 1 | July 11th 04 09:40 PM |
Looking for Cessna 206 or 310 nose wheel fork | mikem | Aviation Marketplace | 0 | October 27th 03 04:33 PM |
Tarver's Doctor??? | CJS | Military Aviation | 0 | July 22nd 03 01:55 AM |
