#161
![]() "Tarver Engineering" wrote in message ... "Scet" wrote in message ... snip Sorry Jim, but it does work. Sorry Scat, but it does work and is how the J-52, J57 and J-75 engines were instrumented. What is it you do, little troll? I said it works Tarver, can't you read? Scet |
#162
Tarver Engineering wrote: "Jonathan Stone" wrote in message ... In article , Tarver Engineering wrote: "Jonathan Stone" wrote in message ... In article , Tarver Engineering wrote: No, no, no. The Hercules engine is (as is well-known) a 14-cylinder sleeve-valve radial. (Lets see what Tarver makes of that.) That is a lot of sparkplugs. No, its completely true. Read carefully. I see, but you are misusing the term radial WRT turbojets, as the term radial refers to compressor flow. (ie T-33) Yes, I worked on T-33 motors. The Hercules engine is 14-a cylinder, sleeve-valve radial reciprocator. Put down the Sterno and read for comprehension. :-/. [...] |
#163
![]() "Tarver Engineering" wrote in message ... "Scet" wrote in message ... No it isn't John and you know it from the discussion we had on this subject last time....you were wrong then and you are wrong now. I am still correct, the only difference is that I proved it in this thread. You are making a fool of yourself, Scat. The only thing you proved Tarver is that you resort to childish name calling when you are wrong. Scet |
#164
![]() "Scet" wrote in message ... "Tarver Engineering" wrote in message ... "Scet" wrote in message ... snip Sorry Jim, but it does work. Sorry Scat, but it does work and is how the J-52, J57 and J-75 engines were instrumented. What is it you do, little troll? I said it works Tarver, can't you read? Do you get what "total" means yet, little troll? Scet |
#165
![]() "Scet" wrote in message ... "Tarver Engineering" wrote in message ... "Scet" wrote in message ... snip Yep, an averaged TIT signal on a T56. Nope, only an idiot would devide the Total. To devide would only increase the complexity and reduce reliability. Are you a janitor, by any chance, Scat? If you had any research skills at all Tarver you would quite easily find out how wrong you are and how stupid you look. Tell us Scat, how an "average" would be more useful than a "total" Surely you understand that such foolishness is useful only in reducing: reliability, simplicity and is a complete departure from the naming conventions for turbo jet engines. Surely you understand, Scet, that any idiot can put up a URL. Perhaps you have a URL, Scet. I am certain that if you are an actual participant in the aerospace industry, that the competent would be interested in avoiding your employeer. |
#166
![]() "Gord Beaman" wrote in message ... (B2431) wrote: It's OAT. Air speed measured with just pitot and static pressure is referred to as indicated airspeed, IAS. If you temperature compensate it becomes true air speed, TAS. Well, it's been many years but ISTR that there's another step here. Yep, Dan is incompetent again. Isn't there such a thing as RAS? CAS, or computed airspeed. , maybe Rectified Air Speed?...IAS corrected for temp? (or maybe CAS?). I thought TAS was IAS corrected for altitude? You got it Gord, I knew you would remember. Man!...it was something like 27 years since I last stepped down that six foot ladder under the tail of an Argus...and about 50 years since the F/E course where I learned this stuff (so cut me some slack guys!). Dan and you can work out the pressure and temperature compensation. |
#167
#168
![]() "Tarver Engineering" wrote in message ... "Scet" wrote in message ... "Tarver Engineering" wrote in message ... "Scet" wrote in message ... snip Yep, an averaged TIT signal on a T56. Nope, only an idiot would devide the Total. To devide would only increase the complexity and reduce reliability. Are you a janitor, by any chance, Scat? If you had any research skills at all Tarver you would quite easily find out how wrong you are and how stupid you look. Tell us Scat, how an "average" would be more useful than a "total" Surely you understand that such foolishness is useful only in reducing: reliability, simplicity and is a complete departure from the naming conventions for turbo jet engines. Surely you understand, Scet, that any idiot can put up a URL. Perhaps you have a URL, Scet. I am certain that if you are an actual participant in the aerospace industry, that the competent would be interested in avoiding your employeer. Ok, one more time for our SPECIAL friends. On T56 engines the thermocouples are connected in parallel and pick up TIT, the signal is then averaged. They are averaged due to the non-uniform temperatures that occur at the turbine inlet due to the short time of spraying fuel from the nozzle, to fuel ignition, to introducing the hot gasses at high velocity to the turbine inlet. The hot gases are not completely mixed and so there are some stratifications of hotter and cooler areas at the turbine inlet. The temperature averaging function of the parallel thermocouple circuits compensates for these non-uniform temperatures. So humour me Tarver, how is it that you are right and EVERYONE else including Allison is wrong????? When I said do some research Tarver I didn't just mean on the internet. If you had half the contacts that you claim to have you'd be able to find out within 10 minutes that you are wrong, but that's not what you want is it Tarver? You are the only troll around here, the only fact you have established is that you are an imbicile and are unable to be educated. You have a learning disability don't you Tarver? I am amazed by the fact that you try to have some semblance of credibility by stating engineering details and when proven wrong resort to name calling...I mean Scat????....there is no evidence provided by you to back up your claims and if anyone else provides a link you have the notion that people are going to go out of their way and actually create a website to prove you wrong???? How bizarre is that???? What's going on with that twisted thought process?? That's just not normal.....you have serious issues that need to be addressed. Scet |
#169
![]() "Scet" wrote in message ... On T56 engines the thermocouples are connected in parallel and pick up TIT, the signal is then averaged. Nope, the signals are sent to a totalizer and totaled; similar to every other turbo jet engine. A devide circuit serves absolutely no purpose in the processing of TIT data. So, Scet, who pays you to be this incompetent? |
#170
![]() "Jim Yanik" wrote in message ... (B2431) wrote in : Jim Yanik wrote: "Well,then it violates basic physics.If you have two voltage sources of slightly different voltages,currents DO flow between them.That's a basic principle. And bimetal TCs are simply millivolt voltage sources." Just picking a nit here. All thermocouples are bimetallic by definition so the term "bimetal thermocouple" is redundant. It's kind of like saying "8 am in the morning." Dan, U.S. Air Force, retired Well,I note you didn't have any argument with the first part of that post. I apologize for my redundant statement. BTW,how many of these TCs are paralleled together in one engine? -- Jim Yanik jyanik-at-kua.net Jim, why don't you visit some of the links provided? Try this one http://www.fas.org/man/dod-101/sys/a.../c-130-bar.htm There is a lot more info out their........or are you trying to be mates with Tarver? Scet |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Hercules Engines | Tarver Engineering | Home Built | 0 | January 19th 04 11:05 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
