limit of trim = limit of travel?
Old April 26th 08, 11:02 AM posted to rec.aviation.piloting
Mxsmanic
Default limit of trim = limit of travel?
Are the limits of control surface movements produced by setting trim to its
extremes also usually the absolute limits of travel for those surfaces, or is
it usually possible to move them further with movement of the yoke? Or does
this vary significantly from one aircraft design to another?
Old April 26th 08, 12:22 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Sat, 26 Apr 2008 12:02:37 +0200, Mxsmanic
you are plain and simple a clueless ****wit.
if you had any intelligence you would have gone out in the real world
and looked at an aeroplane.
trim has nothing to do with the movement limits on control surfaces.
control surfaces are limited by things called "stops". essentially
they are adjustable bolts. it is usual for them never to be changed
once the aircraft is initially set up for flight. they are designed to
positively stop further movement of the surface.
here is a question you can research.
what aerodynamic consideration is in the mind of the designer when
they set up the maximum movement of a control surface?
your inability to find an acceptable answer by your own non-internet
research will confirm to you that you are a retard.
oxygen is a valuable resource. please stop wasting it.
Stealth Pilot
Old April 26th 08, 07:09 PM posted to rec.aviation.piloting
Scott Skylane
Stealth Pilot wrote:
/snip/
/snip/
Stealth,
This is not universally true. On the Douglas DC-6, for instance,
elevator "up" travel is limited by the elevator trim position. Dialing
in the last 5 degrees of nose up trim allows an extra 3 degrees of
elevator "up" travel. This was done to limit elevator "up" movement
with aft CG loading conditions.
Happy Flying!
Scott Skylane
Old April 28th 08, 04:29 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Sat, 26 Apr 2008 10:09:16 -0800, Scott Skylane
/snip/
/snip/
Stealth,
Happy Flying!
Scott Skylane
ok you successfully cite the one instance possibly :-) I defer to your
knowledge of the obscure.
stops of the type I mentioned are a mandated requirement in my country
for the environment I play in.
Stealth Pilot
Old April 28th 08, 04:43 PM posted to rec.aviation.piloting
Peter Dohm
"Stealth Pilot" wrote in message
/snip/
/snip/
Stealth,
Happy Flying!
Scott Skylane
Stealth Pilot
Not nearly so obscure as you sugest. Aircraft with a fully trimming
stabilizer have a result result of adding to the effective elevator
authority--examples are the Piper Cub and all of the "straight tail"
Mooneys.
Peter
Old April 29th 08, 01:24 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Mon, 28 Apr 2008 11:43:49 -0400, "Peter Dohm"
/snip/
/snip/
Stealth,
Happy Flying!
Scott Skylane
Stealth Pilot
Mooneys.
Peter
ermmmm. trim has nothing to do with the control surface stops. they
are fixed to the airframe and work as their name suggests.
Stealth Pilot
Old April 26th 08, 03:06 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
I don't have any actual figures handy, but my answer would be no. You
should have movement on the major control surface available beyond the
max trim limits.
Dudley Henriques
The Sky is Their Limit [email protected] Soaring 7 November 13th 06 02:44 AM
speed limit in class B Andrey Serbinenko Piloting 0 July 23rd 06 04:05 AM
Pegasus life limit Mark628CA Soaring 2 March 30th 06 10:37 PM
Aft CG limit(s) Andy Durbin Soaring 13 November 26th 03 05:10 AM
Pushing the limit Dan Shackelford Military Aviation 20 September 14th 03 10:27 PM
