Gasohol
Old June 9th 07, 12:58 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Bob Noel
Default Gasohol
"Blueskies" wrote:
If this special clean gas w/o alcohol is brought to the airport and kept
there, doesn't it pretty much miss the point of
the autogas STC? The whole idea was to be able to use normal autogas in these
old low compression engines.
I thought one objective was to avoid using the 100LL in engines that were prune
to lead fouling.
Bob Noel
(goodness, please trim replies!!!)
  #172
Old June 9th 07, 02:18 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
David Lesher
Default Gasohol
Bob Noel writes:
to lead fouling.
I thought that autogas was popular for several reasons:
a) lead
b) price
Gas bought by a FBO or club should be free of highway taxes but
I suspect will instead incur aviation fuel taxes...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
  #173
Old June 9th 07, 04:02 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
RST Engineering
Default Gasohol
And if you thought lead was bad, those prunes REALLY gum up the works.
"Work like you don't need the money, love like you've never been hurt, and
dance like no one is watching."
--Satchel Paige
"Bob Noel" wrote in message
prune
to lead fouling.
Bob Noel
  #174
Old June 9th 07, 04:49 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Denny
Default Gasohol
to lead fouling.
Yeah, we are into the summer time haul the grandkids routine where I
burn oodles of avcrap because I am fueling faster than I can haul it
and I am fueling at strange airports and some are really strange...
Fat Albert's engines are already grumping at me about it...
denny
  #175
Old June 9th 07, 04:59 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Bob Noel
Default Gasohol
aw ... nuts. :-(
Bob Noel
  #176
Old June 9th 07, 10:10 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
clare at snyder.on.ca
Default Gasohol
On Sat, 09 Jun 2007 11:46:29 GMT, "Blueskies"
"David Lesher" wrote in message ...
"Peter Dohm" writes:
Given the issue with alcohol, and the fact it is injected at the
last stage - truck loading -- why aren't the STA owners such as EAA
running campaigns to set up procedures for FBO's to procure untainted
autogas?
I really doubt that the terminal operators are so ignorant as to make that a
problem.
Ha!
OTOH, there are some real problems for the FBO to overcome. One FBO owner,
who I know, stopped selling gasolene several years ago--saying that he
sometimes suspected that he lost more to evaporation than he pumped.
That's a "selling autogas" problem;
vice "finding un-Ethenol'ed autogas to sell" one.
Agreed the first may be an issue..
BUT if you have a gaggle of STA'ed aircraft owners based there and
you but not evry EatHerAndGetGas sells what they want and need....
If this special clean gas w/o alcohol is brought to the airport and kept there, doesn't it pretty much miss the point of
the autogas STC? The whole idea was to be able to use normal autogas in these old low compression engines.
No, the point was to be able to use gasoline with less lead than the
currently available 100LL AvGas whick gives many older engines
"morning sickness" due to lead deposits making valves sluggish.
Posted via a free Usenet account from http://www.teranews.com
  #177
Old June 10th 07, 01:29 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Matt Barrow[_4_]
Default Gasohol
these
prune
to lead fouling.
Wouldn't prunes give them gas?
  #178
Old June 10th 07, 04:26 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Ernest Christley
Default Gasohol
Nope. He was talking about an old engine. It needs the prunes to keep
the works from gumming up. I think most of the guys here know that. 8*)
  #179
Old June 10th 07, 06:04 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Morgans[_2_]
Default Gasohol
I wonder if prunes work on old engines, like they work on me?
It would give the engine exhaust a certain.....
Aroma! ggg
  #180
Old June 10th 07, 12:08 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Blueskies
Default Gasohol
"Morgans" wrote in message news
Nope. He was talking about an old engine. It needs the prunes to keep the works from gumming up. I think most of
Aroma! ggg
Free up the lifters?
Gasohol Blueskies Piloting 240 July 6th 07 12:42 AM
How scary is gasohol? Charles Talleyrand Owning 27 March 1st 04 11:39 AM
