A Call to Arms from Richard VanGrunsven
Old March 25th 08, 06:18 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Larry Dighera
Default A Call to Arms from Richard VanGrunsven
On Tue, 25 Mar 2008 17:19:42 -0000, Jim Logajan
Gig 601XL Builder wrote:
Nobody said the FAA was going to properly correct the problem but that
is what the aim of the action is. The better way to correct the
problem would be to just have someone in OKC look through the
magazines and search the internet, find those operations that are in
violation, refuse the AW certificates of the next 3 aircraft that roll
out of their hanger and very publicly announce the action.
Ouch. Unless I'm missing something, that appears to advocate arbitrary and
capricious use of authority.
It's just another of Mr. G's well considered proposals. :-(
If all these alleged rich scoundrels are already skirting the law, there is
no need to change them, right? Do you really think it is wise to promote
and encourage changes to the laws that suddenly makes a victimless activity
a criminal activity?
Hey it works for the religious right. :-)
What if it were an activity you engaged in and someone else was trying to
make it illegal?
I see this issue as a two fold _opportunity_. By virtue of its
existence, there is obviously an opportunity to legitimize this sort
of commerce, and the FAA is apparently in the mood to change its
dogma, err.. regulations. If the regulations could be changed from
prohibitive to enabling, that would be a win for all involved, IMO.
But those small minded homebuilders, who can only see the status of
their not insignificant accomplishments being eroded, impede the
potential for further FAA concessions to market forces and reduced
aircraft costs.
  #172
Old March 25th 08, 07:12 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Gig 601XL Builder[_2_]
a criminal activity? What if it were an activity you engaged in and someone
else was trying to make it illegal?
Excuse me? I specifically wrote that the better way was to enforce the
law as it is already written. And to pick out companies or individuals
for enforcement action who are advertising a violation of the law is
hardly arbitrary or capricious.
  #173
Old March 25th 08, 07:14 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Wow, enforce the law that is already on the books instead of creating a
new law. What a novel idea.
  #174
Old March 25th 08, 08:20 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Jim Logajan
that is what the aim of the action is. The better way to correct the
roll out of their hanger and very publicly announce the action.
arbitrary and capricious use of authority.
there is no need to change them, right? Do you really think it is
wise to promote and encourage changes to the laws that suddenly makes
a victimless activity a criminal activity? What if it were an
activity you engaged in and someone else was trying to make it
illegal?
Okay - my misread. Sorry.
  #175
Old March 25th 08, 08:57 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Larry Dighera
On Tue, 25 Mar 2008 14:12:52 -0500, Gig 601XL Builder
I don't see where you wrote that at all. You said: "... find those
operations that are in violation, refuse the AW certificates of the
next 3 aircraft that roll out of their hanger..."
Are you able to provide the specific language of any of "those
operations that are in violation" and publicly advertise such? The
implication in your comment is, that regardless of the aircrafts'
airworthiness, the FAA should reject them to make a point.
And to pick out companies or individuals for enforcement action who
are advertising a violation of the law is hardly arbitrary or capricious.
It's hardly likely that any companies or individuals are doing that
also.
  #176
Old March 25th 08, 09:31 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
What part of "operations that are in violation" don't you understand Larry?
The phrase in the regulations is "for recreation and education." The
spirit of the law is that aircraft certified under the EXP-HB
classification are to be built in a not for profit setting and not as a
way to get around the certification requirements in place for aircraft
manufacturers.
And it is not regardless of the aircrafts airworthiness. It is
specifically because of the aircrafts airworthiness. The power that the
FAA has to issue the certificate comes from the law that also sets the
rules under which an EXP-HB certificate can be issued. If the aircraft
isn't build under those rules it is not airworthy at least as far as
those rules are concerned.
also.
You really are a moron. For somebody that seems to have no skill other
than cutting and pasting to USENET it amazes me that you don't realize
that it is specifically this practice that is causing the FAA to look at
changing the regulations.
I know of at least two places where I could of have my kit delivered to
and shown up for a few days and watched while it was being built doing
as much or as little work (including none at all) as I desired. I would
have been able to pose for some photos with the plane under construction
and been able to show that to the DAR along with some bogus paperwork
and I not only would have been able to get the EXP-HB AW certificate I
would be able to get the repairman's certificate as well.
  #177
Old March 26th 08, 02:46 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Steve Hix
And the left.
No need to get excessively picky amongst statists of any stripe.
  #178
Old March 26th 08, 06:50 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
WJRFlyBoy
On Mon, 24 Mar 2008 08:11:03 -0500, Gig 601XL Builder wrote:
WJRFlyBoy wrote:
On Fri, 21 Mar 2008 20:53:20 +0000 (UTC), Bertie the Bunyip wrote:
I don't see any real change at all. they're going back to the original
spirit of the rule.
They are significantly re-writing the rules of the market in favor of
the production aircrafters. or they are not.
Which is it?
They are not. They are looking at the problem that has developed
regarding those that are currently violating the rules that have been in
place for years.
Huh?
http://doc.vansaircraft.com/RVator/2...008-RVator.pdf
"On Feb. 15th, in the FAA .... report were indications that procedural
changes would include changes to the criteria for determining
eligibility for airworthiness in the E-AB category. *In other words,
re-defining the level of prefabrication and assembly permissible for
kits.*"
Who benefits from these re-writings, increased cost and complexity? The
kit sellers? Or Cessna?
  #179
Old March 26th 08, 02:17 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Peter Dohm
"WJRFlyBoy" wrote in message
spirit of the rule.
Which is it?
place for years.
Huh?
kits.*"
From my point of view, only two things are certain:
1) This won't address the alleged "problem" of "hired guns" and
2) It will increase the build time.
The most probable side effect will be fewer aircraft built and flown and the
secondary side effect, especially for some of the composites, will be
improper bonding due to slower assembly at critical stages--in other words
DECREASED safety.
So, in the grand scheme of things; we'll be looking at fewer kits
successfully completed, less airport utilization, and eventually less sales
of type certified factory completed aircraft as well. Another genuine
"lose-lose" proposition!
Peter
  #180
Old March 26th 08, 09:32 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
WJRFlyBoy
Which is it?
place for years.
Huh?
kits.*"
DECREASED safety.
Peter
Why do you think there will be less type certifieds sold, question not a
challenge.
Flew home and boy are my arms tired! Steve Schneider Owning 11 September 5th 07 12:16 AM
ASW-19 Moment Arms jcarlyle Soaring 9 January 30th 06 10:52 PM
[!] Russian Arms software sale Naval Aviation 0 December 18th 04 05:51 PM
Dick VanGrunsven commutes to aviation Fitzair4 Home Built 2 August 12th 04 11:19 PM
Small arms locker questions Red Naval Aviation 4 July 30th 03 02:10 PM
