#171
Peter Dohm wrote:
wrote in message ... Peter Dohm wrote: wrote in message ... What else are you going to run your refrigerator, TV, airconditioning, lighting, vacuum cleaner, computer, and lights on, natural gas? -- Jim Pennino No, although some smaller refrigerators can be operated that way. I am just not sold on making transportation fully dependent on electric power plants as well. The energy density of electric storage devices are more than an order of magnitude inadequate for that to happen and there are no potential breakthroughs of even an order of magnitude on the horizon. -- Jim Pennino I believe that we are really in basic agreement. Electric energy storage is more than an order of magnetude inadiquate to run our transporation system on batteries, and the rest of the electric infrastructure seems equally short of being able to work around that problem. Therefore, we will continue to do as we have done for the foreseeable future. Well, not quite. Electric transportation will require a major breakthrough in battery technology which may or may not ever happen, as well as increased grid infrastructure. Production of synthetic petroleum products from raw stock other than crude oil requires that electricity production costs drop, which could well happen if you are talking about on the ground facilities, and the electric production facility need not be tied into the grid or anything else other than the synthesis facility. -- Jim Pennino Remove .spam.sux to reply. |
#172
Peter Dohm wrote:
wrote in message ... Morgans wrote: "Peter Dohm" wrote No, although some smaller refrigerators can be operated that way. I am just not sold on making transportation fully dependent on electric power plants as well. They used to make natural gas (only) full sized refrigerators, and still may. They are still made for niche applications; you won't find one at Home Depot. Also, don't expect to make a lot of ice cubes with one of them as they don't work all that well which is but one of the reasons you won't find them in general use. A buddy had a place that did not have electricity to it, except for a small generator, run only when absolutely necessary. When he got it, (used) the guy he bought it from said that if it did not start cooling soon after he lit it off, that he needed to shut it down, and turn it upside-down for 30 minutes or so, then turn it over and light it off. Damned if it needed it, and damned if that didn't fix it! I worked off of an ammonia coolant cycle, as I recall. Another reason you won't find them in general use. -- Jim Pennino Actually, I think that I heard they only might need to be tilted, but you had to know which direction, and you are correct that ammonia was the refrigerant. In any case, there is a variant which can be operated on propane or electric, and possibly a gas or electric version as well, that is sold for the recretonal vehicle market. The full size gas only models were normally sold by or through the loack gase companies, and may still be offered in that manner as I have heard that they were very innexpensive to operate. Yep, but when running on gas, they don't make ice cubes worth a damn; they can't move heat fast enough. -- Jim Pennino Remove .spam.sux to reply. |
#173
B A R R Y wrote:
On Tue, 15 Apr 2008 23:35:03 GMT, wrote: California has a bigger county than some European countries. California is also the world's 8th largest economy. Yep, and also has electric trains for moving people along most of the coast. But it is diesel-electrics moving bulk cargo across the Mojave and points east. -- Jim Pennino Remove .spam.sux to reply. |
#174
![]() "Jennifer Howland" wrote On some train systems, at least some of this braking energy can be diverted back into the catenary to power other trains. I believe even the Acela can do this. Of course, you know that you are talking two totally different kinds of train systems. Diesel electric trains run on tracks with NO electrical pickups on wires above, or on a third rail. That was the type being discussed, though. I do wonder on systems that feed electricity back onto the line, since most are AC, I believe, how do they match phases with the current already on the line? That would be necessary. -- Jim in NC |
#175
![]() "Some Other Guy" wrote It's just a hell of a clever plumbing arrangement. Add heat at one part (by burning gas, whatever), and another part gets cold: http://www.gasrefrigerators.com/howitworks.htm If that isn't the best explanation I have ever seen.... Good pictures, too. ;-) I guess that turning the thing upside down got the hydrogen back up (down) in the reservoir, so that it could keep in the evaporation side once the heat got things moving. That makes sense, now. At the time, with no internet in '83, it seemed a bit like magic, to me! g -- Jim in NC |
#176
![]() "Some Other Guy" wrote It's just a hell of a clever plumbing arrangement. Add heat at one part (by burning gas, whatever), and another part gets cold: http://www.gasrefrigerators.com/howitworks.htm Ever wonder why they never became popular? |
#177
Morgans wrote:
"Jennifer Howland" wrote On some train systems, at least some of this braking energy can be diverted back into the catenary to power other trains. I believe even the Acela can do this. Of course, you know that you are talking two totally different kinds of train systems. Diesel electric trains run on tracks with NO electrical pickups on wires above, or on a third rail. That was the type being discussed, though. I do wonder on systems that feed electricity back onto the line, since most are AC, I believe, how do they match phases with the current already on the line? That would be necessary. Well, since frequency and phase out of a mechanical generator is RPM dependent, you would either have to have an infinite ratio transmission or a DC generator followed by a controllable inverter. -- Jim Pennino Remove .spam.sux to reply. |
#178
#179
#180
"Matt W. Barrow" wrote in message
... "Some Other Guy" wrote It's just a hell of a clever plumbing arrangement. Add heat at one part (by burning gas, whatever), and another part gets cold: http://www.gasrefrigerators.com/howitworks.htm Ever wonder why they never became popular? Nope. My grandfolks said the gas refrigerators were a lot more convenient than carrying 50 pound blocks of ice up the stairs. Peter |
A GA pilot's worst nightmare? | Kingfish | Piloting | 49 | February 1st 07 02:51 PM |
Our Worst Nightmare? | alank | Piloting | 56 | January 10th 07 10:10 AM |
Nightmare (long story) | JJS | Owning | 7 | April 2nd 06 11:34 PM |
Eurofighter is turning into German nightmare | Chad Irby | Military Aviation | 45 | October 4th 03 03:18 AM |
(long) WxWorx arrived... | Tom S. | Piloting | 0 | September 9th 03 04:54 PM |
