motorgliders as towplanes
Old March 18th 09, 10:29 PM posted to rec.aviation.soaring
The Real Doctor
Default Aerodynamics of Towing
On 17 Mar, 23:45, Nyal Williams wrote:
Jim White had it right, way back several weeks ago. *What makes it work is
MAGIC. *
I'm convinced that helicopters don'tactually fly: they just induce
hallucinations in people so they think flying is occuring. Some
stroboscopic effect, probably.
Ian
  #172
Old March 18th 09, 10:34 PM posted to rec.aviation.soaring
Jim Logajan
The Real Doctor wrote:
On 18 Mar, 01:38, Darryl Ramm wrote:
As I explained, Gravity provides the energy...
Then you will need to explain how gravity provides the energy when the
glider is climbing.
Just curious, but are you being pedantic?
  #173
Old March 18th 09, 10:59 PM posted to rec.aviation.soaring
Darryl Ramm
glider is climbing.
Just an extreme case of rasterbation. If he keeps it up he will go
blind.
Darryl.
  #174
Old March 19th 09, 12:03 AM posted to rec.aviation.soaring
KevinFinke
Ian, "The Real Doctor" Out of curiosity, what exactly do you have a
doctorate in?
Aside from that.... In order to seek clarity in all of these
discussions I suspect that we have a mis-understanding because we are
trying to discuss these using two different reference frames. If
that's the case, then that would explain a lot.
I hope that we are all in agreement about the three forces acting on a
glider. For simplicity they are lift(L), drag(D) and weight(W=mg). As
has been corrected by Darryl, I agree that it is correct that lift, by
definition, is perpendicular to the airflow. However, for a glider in
steady state gliding flight, airflow and direction of motion are
parallel. Any body have any problems so far? I'm hoping this will get
me out of the hen house...
If we align the axis system such that weight is vertical and the
descent angle is theta. The equilibrium equations a
Vert. Axis 0 = L*cos(theta) + D*sin(theta) - W
Horz. Axis 0 = L*sin(theta) - D*cos(theta)
I'm guessing this is the source of the Lift providing the horizontal
motion argument. Clearly there is no gravity term in that component.
But the motion isn't strictly horizontal or vertical with these
equations. It is both, and therefore I would advocate a simplified set
where the direction of motion is the basis for the axis system.
Therefore....
If the axis system is aligned along the lift vector the equations
simplify to: (For the sliding block this tends to be the convention
that most books I own present) Replace L with N for Normal.
Lift Axis 0 = L - W*cos(theta)
Drag Axis 0 = D - W*sin(theta)
Any objections so far? I sure hope not. I can't imagine how....
The nice thing about convention 2 is that the lift and drag vectors
are isolated variables in the equation, and the weight is already
known so it's easy to solve the other values.
L = W*cos(theta) and D=W*sin(theta)
I can even rearrange the equations in set 1 and get the same
relationships. So, what in the world am I missing when I say Lift =
Weight * cos (glide angle)? Ian, you are the real doctor. I'll confess
my ignorance. I don't want to guess, cause I just don't know what
answer you're looking for, but what did I forget?
The other advantage of using convention 2 is in describing the motion
of the system. The object is constrained to the plane, and therefore
you can get rid of the "vertical" axis in this example and look at the
equation with one dimension. Because the lift force or normal force
constrains the object to the plane, you'll have no accelerations or
displacements in this direction, for a steady state example. In this
case that would be it's glide path. The only equation left is D = W*sin
(theta) So again I argue, Lift, because it is perpendicular to the
direction of motion, can not provide the motive force! The motive
force is governed by a balance between gravity, drag, and the glide
angle. Don't get me wrong, I'm not saying lift isn't important. It is
very important to making the glider stay on a glide path. Maybe this
is just a chicken before the egg argument. I can see the circularity
of the discussion. Why do those chickens keep coming up....
This would be a whole lot easier to explain with pictures. So I'll
cite a reference...If anybody has a copy of the BGA Manual: "Gliding:
Theory of Flight", please reference the discussion of forces on flight
in Chapter 4. The book goes through a very good explanation of how
gravity provides the motive force for gliding. It's an excellent book
and I highly recommend it. If only it had a discussion of forces on
tow....
-Kevin
PS I think we need some good flying weather so that we all get out of
the house and away from the computer....
  #175
Old March 19th 09, 01:15 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
A glider in steady free flight is always descending through the air in
which it is flying. If you can fly in air that is going up as fast or
faster than the sink rate of the glider, then you can gain potential
height energy. Isn't that what soaring flight is all about?
Derek Copeland
(Qualified gliding instructor with Gold C and 3 Diamonds BTW)
At 22:07 18 March 2009, The Real Doctor wrote:
On 17 Mar, 19:04, Darryl Ramm wrote:
Say what? Gravitational potential energy *increases* not decreases as
the glider climbs.
Sorry, typo.
And that "store" is the transfer mechanism that allows the glider to
glide.
No it's not. The gravity force is necessary, but it's perfectly
possible to soar for extended periods and distances without adding to
or drawing from the potential energy store. It happens any time we fly
level - along a wavebar, running a ridge, following a cloud street.
There is no other mechanism. With no gravity, even with an
atmosphere (which would be difficult to arrange), your glider could
not glide.
You miss, as so many people do, the point. Because the force of
gravity is necessary for a glider to work, people assume that gravity
somehow "powers" the flight. Which it does not.
Guy's this has wandered into junior-high school level physics.
No, it has wandered into junior high school level misconceptions about
physics!
Here's another one for you. Does a glider turn (normally) by (a)
rolling (b) pitching (c) yawing or (d) other?
Ian
  #176
Old March 19th 09, 07:45 AM posted to rec.aviation.soaring
Jim White[_2_]
Having read all 170 posts in this thread I am still happily ignorant of the
theory of flight!
  #177
Old March 19th 09, 08:17 AM posted to rec.aviation.soaring
The Real Doctor
glider is climbing.
No, I'm being serious in a usenet-is-not-reallife sort of way. I
introduced this, you see, as a common misconception in the gliding
world. Lots of people think that gliders are "powered by gravity", and
they aren't!
Ian
  #178
Old March 19th 09, 08:18 AM posted to rec.aviation.soaring
The Real Doctor
glider is climbing.
blind.
Go on then. Explain how "gravity provides the energy" when a glider is
climbing ...
Ian
  #179
Old March 19th 09, 08:22 AM posted to rec.aviation.soaring
The Real Doctor
On 19 Mar, 00:03, KevinFinke wrote:
Ian, "The Real Doctor" *Out of curiosity, what exactly do you have a
doctorate in?
Numerical solution of non-linear diffusion problems.Which is actually
a lot more interesting than it sounds.
*Smacks head*
Sorry, it was late. I misread, and thought you'd done the old W = L cos
(theta) mistake (W, of course, = L cos(theta) + D sin(theta).
My apologies.
Ian
  #180
Old March 19th 09, 08:24 AM posted to rec.aviation.soaring
The Real Doctor
theory of flight!
Aircraft stay up because they're afraid of the ground.
That said, you might find it interesting to get hold of the TV
programme and video which the Open University made on gliding
mathematics some years ago. The course in question, "MST207 Applied
Mathematics" is defunct, but a fair number of copies of the AV
material lurk around gliding clubs.
Ian
Seeking towplanes for Region 9 [email protected] Soaring 0 May 17th 06 12:03 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
