#181
![]() "puttster" wrote in message om... "John Keeney" wrote in message ... "Guy Alcala" wrote in message . .. John Keeney wrote: "puttster" wrote in message om... "John Carrier" wrote in message ... Now if you want to argue that the F-35B is an aircraft designed as a Carrier Aircraft, I know some Marines that would like to chat with you. The B will be replacing AV-8B's and land based F-18's. Sure, it can land on a carrier but it is not being built to trap aboard CV/N's using arresting gear or Cat launches. True in a sense, but as a VSTOL and STOVL design, it's fully carrier suitable w/o the need for catapult gear (I suspect it does have a tailhook). I'd also be much surprised if its CNI suite didn't include ACLS and SPN-41 in their latest incarnations. R / John With an excellent V/STOL capability in the F-35B, why does the Navy still demand those giant carriers? Seems like something can be done there to make the whole system more efficient. Why design a plane (the F-35C) to fit their ships? Because the F-35C flies farther with a bigger load than the F-35B. As always, the question is how much do you need that extra range, and should the navy a/c do that mission when it is needed? Kind of depends how you define the I want to see the carriers able to hit Afganistan from the Indian Ocean and a few other places that might be a tad less accessible. Call it the "anywhere in the second country in from the beach" rule. Here is the math fails. If the Marine F-35B's have a range of 450 miles and the Navy's F-35C's have a range of 700 miles, how are the marines going to set up at points inaccessible by the Navy? Besides, how will they get resupplied? By air, like they did in Afghanistan, *before* major airfields were available for use IIRC. Unless Afghanistan has been moved to where it *is* accessable by the Navy? Brooks Brooks |
#182
"Keith Willshaw" wrote in message ...
"puttster" wrote in message om... Chad Irby wrote in message . com... In article , (puttster) wrote: Then let me ask why the Marines need the V/Stol capability. I cannot get a good picture of a mission where the marines would need 400+ of them with all the support for them but still not have a decent runway! Why are you limiting the situation to needing 400+ at once? The situation is more like "we need a dozen for this small brushfire war in a place where there are no good airstrips," or we need to put a small landing force in at this area, and the bad guys have a few planes, so we need a little fighter cover from the LHDs." If there are no good airstrips how would the marines get their gas, bombs, food, and all the other support? By ship , C-130 or other battlefield airlift asset. Keith I might could buy resupply with C-130's . They are STOL themselves, landing fully loaded in under 500 ft. We would need a lot of them though, to set up a deep mission. Maybe a situation like OIF where Turkey would not let the Army come in from the north. With enough C-130's maybe you could quickly set up a wing of F-35B's up in Kurdistan, with a regiment of Marines to support them. The thing is though there were usable airstrips there already. Even if there weren't any, the first C-130's should be bringing in the runway, then you could bring in C-5's for supply and you could build twice the force in the same amount of time. Any your fighters could have normal range and loads. f-35B's seem like an Idea without a mission to me. Well, maybe some isolated rescue stuff, but what do the marines need 400 of them for? I could see two dozen maybe, to go along with their Ospreys. That should be it. |
#183
![]() "puttster" wrote in message om... Chad Irby wrote in message . com... In article , (puttster) wrote: Then let me ask why the Marines need the V/Stol capability. I cannot get a good picture of a mission where the marines would need 400+ of them with all the support for them but still not have a decent runway! Why are you limiting the situation to needing 400+ at once? The situation is more like "we need a dozen for this small brushfire war in a place where there are no good airstrips," or we need to put a small landing force in at this area, and the bad guys have a few planes, so we need a little fighter cover from the LHDs." Well that was my question, if the biggest mission that con be realiatically conjures is a dozen, why order 400+? Because you need only a dozen PER SHIP or base but you need cover for a dozen locations or so. Then figure in the aircraft required for training, the 20% or so that will be under maintenance at any time and an attrition reserve for the 30 years it will be in service and the 400 appears rather reasonable. Having one squadron on a ship in the Pacific isnt a lot of use if a problem pops up in Africa. Keith |
#184
![]() "puttster" wrote in message om... "Keith Willshaw" wrote in message ... By ship , C-130 or other battlefield airlift asset. Keith I might could buy resupply with C-130's . They are STOL themselves, landing fully loaded in under 500 ft. We would need a lot of them though, to set up a deep mission. Which is why we have em Maybe a situation like OIF where Turkey would not let the Army come in from the north. With enough C-130's maybe you could quickly set up a wing of F-35B's up in Kurdistan, with a regiment of Marines to support them. The thing is though there were usable airstrips there already. Not many in point of fact and that isnt always the case. Even if there weren't any, the first C-130's should be bringing in the runway, then you could bring in C-5's for supply and you could build twice the force in the same amount of time. Any your fighters could have normal range and loads. And what pray tell is protecting the C-5's and C-130's in the meantime ? f-35B's seem like an Idea without a mission to me. The RAF , RN and USMC disagree Well, maybe some isolated rescue stuff, but what do the marines need 400 of them for? I could see two dozen maybe, to go along with their Ospreys. That should be it. Lacking either a crystal ball for perfect prediction or the ability to limit the forces an enemy can bring to bear I disagree There are a lot of even 3rd world airforces that can bring more than a dozen modern fighters to a hot spot. Keith |
#185
![]() "Keith Willshaw" wrote in message ... "puttster" wrote in message om... "Keith Willshaw" wrote in message ... By ship , C-130 or other battlefield airlift asset. Keith I might could buy resupply with C-130's . They are STOL themselves, landing fully loaded in under 500 ft. We would need a lot of them though, to set up a deep mission. Which is why we have em Maybe a situation like OIF where Turkey would not let the Army come in from the north. With enough C-130's maybe you could quickly set up a wing of F-35B's up in Kurdistan, with a regiment of Marines to support them. The thing is though there were usable airstrips there already. Not many in point of fact and that isnt always the case. Even if there weren't any, the first C-130's should be bringing in the runway, then you could bring in C-5's for supply and you could build twice the force in the same amount of time. Any your fighters could have normal range and loads. And what pray tell is protecting the C-5's and C-130's in the meantime ? Plus it never ceases to amaze me the number of folks who think that (a) bringing in enough aluminum matting (and we don't use PSP anymore) to build a fighter strip is a piece of cake (and trying to support a C-5 on one is a mean proposition), (b) installing the matting is all there is to it (no cut/fill, drainage work, or subbabse and base course prep required), getting the requisite engineer equipment and units into the site is an easy matter, and (d) this will all happen over a matter of a day or two. Laying in a fighter-length strip from scaratch is a *major* engineer operation, and quite different from that required to construct a minimum length rough field C-130 strip. f-35B's seem like an Idea without a mission to me. The RAF , RN and USMC disagree Add the USAF to that equation--they just officially announced that they are interested in revamping their programmed buy to include some B models as well. Brooks Well, maybe some isolated rescue stuff, but what do the marines need 400 of them for? I could see two dozen maybe, to go along with their Ospreys. That should be it. Lacking either a crystal ball for perfect prediction or the ability to limit the forces an enemy can bring to bear I disagree There are a lot of even 3rd world airforces that can bring more than a dozen modern fighters to a hot spot. Keith |
#186
#187
#188
#189
In message , Kevin Brooks
writes Plus it never ceases to amaze me the number of folks who think that (a) bringing in enough aluminum matting (and we don't use PSP anymore) to build a fighter strip is a piece of cake (and trying to support a C-5 on one is a mean proposition), (b) installing the matting is all there is to it (no cut/fill, drainage work, or subbabse and base course prep required), getting the requisite engineer equipment and units into the site is an easy matter, and (d) this will all happen over a matter of a day or two. Laying in a fighter-length strip from scaratch is a *major* engineer operation, and quite different from that required to construct a minimum length rough field C-130 strip. Compare this with the effort needed to create HMS Sheathbill in the Falklands (which was a basic "land, refuel, leave or GLI" strip). It's *much* easier to pick a stretch of highway, fly in fuel bladders and maybe ordnance & first-line servicing - than to build a fixed-wing CTOL strip from scratch (lots of supplies and equipment needed just to build the runway before anything else arrives) The USMC's AV-8Bs did this to very good effect in 1991, for instance. -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#190
![]() "Gord Beaman" wrote in message news ![]() Then you have departed from reality. Jesus Christ John, this is ridiculous...I've read a lot about this accident and agree with the consensus that the a/c did all any a/c could have done given the parameters this not too bright bulb asked it to do. You mean the pilot stalled the wing? Then you are well advanced from Weiss' understanding. How in hell could the system have done more than, as JW explained, hold the AoA at the max lift point just short of stall while the autothrottle system applied max power The autothrottle only knows land and go around in the situation we are discussing and the pilot was beyond the point of either flight mode. The operator has to follow the POH, as it is part of the type Certificate. |
Replace fabric with glass | Ernest Christley | Home Built | 38 | April 17th 04 11:37 AM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Naval Aviation | 2 | February 22nd 04 06:22 AM |
RAN to get new LSD class vessel to replace 5 logistic vessels ... | Aerophotos | Military Aviation | 10 | November 3rd 03 11:49 PM |
Air Force to replace enlisted historians with civilians | Otis Willie | Military Aviation | 1 | October 22nd 03 09:41 AM |
