CNN article on problems in Air Travel, as seen by FAA
Old October 31st 07, 02:00 AM posted to rec.aviation.piloting,rec.travel.air
John Kulp
Default CNN article on problems in Air Travel, as seen by FAA
On Tue, 30 Oct 2007 08:26:51 -0500, "Gig 601XL Builder"
wrDOTgiaconaATsuddenlink.net wrote:
John Kulp wrote:
Gates can be a problem sometime but not runways. The GPS system would
handle about 25% more flights on the same runways. Aren't you paying
enough all ready for flights? Want to pay more when the politicos are
stealing what money is already being paid for?
What makes you think that GPS could decrease the needed separation?
Because that is exactly what it is designed to do?
I didn't say anything about paying more. What I suggested in this forum a
month or so ago was the same net cost just make it cheaper off peak and more
expensive on-peak. That's how economics should work. Things should cost more
when they are in higher demand and less when they are in lower demand.
Well, I didn't see your post then so I can't comment
  #182
Old October 31st 07, 03:50 AM posted to rec.aviation.piloting,rec.travel.air
Morgans[_2_]
It _may_ be able to more precisely control separation out in the airways,
and get them set up for landing sequence, but notice I said "may." They do
a pretty good job with radar, right now.
What it _can not_ do is put more aircraft on the runways per hour in the big
airports operating with all of the landing slots full. The separation for
wake turbulence is always going to be the limiting factor in how many
aircraft can land at a given busy airport at peak times. GPS is not going
to change that.
  #183
Old October 31st 07, 03:04 PM posted to rec.aviation.piloting,rec.travel.air
Newps
Ah, no. GPS was not designed for that nor can it provide that. Most in
trail separation today is based on wake turbulence. Even if you got rid
of wake turbulence you still can't get less than 2.5-3 miles for jets
because that's how long it takes to land, slow down and exit the runway.
If it's dry. And that spacing doesn't allow departures to get out
between the arrivals. So you go to five miles and if everything works
out perfect that's barely enough room to get the jet departures out.
The plain simple fact of the matter is the limiting factor is lack of
runways. No amount of technology can force more airplanes onto the
runways we have now.
  #184
Old October 31st 07, 04:20 PM posted to rec.aviation.piloting,rec.travel.air
Gig 601XL Builder
Neil Gould wrote:
Recently, Newps posted:
[...] The plain simple fact of the matter is the limiting
factor is lack of runways. No amount of technology can force more
airplanes onto the runways we have now.
Isn't that somewhat dependent on the definition of "...the runways we
have now"? The problem is easily addressed by abandoning the hub
system that overburdens a few locations and barely worked when demand
was low. Alternatively, add hubs to some of the underutlilzed
airports. Of course, the airlines would probably find this to be a
threat to direct service to locations of highest demand, but from a
passenger's point of view, it's becoming more difficult to get a
flight direct to very many places anyway.
Neil
Sure that will work but to do it would mean more smaller aircraft in the
system, which I don't personally think is a bad thing but it could bring
about another problem where the ATC is over burdened. Of course it is a lot
easier to hire and train mor controllers than it is to build more runways.
  #185
Old October 31st 07, 05:21 PM posted to rec.aviation.piloting,rec.travel.air
John Kulp
Funny none of the airlines I know of are saying this. They are all
advocating just this upgrade and the FAA is going to have it build.
So just what do you know that those running the business don't?
  #186
Old October 31st 07, 05:34 PM posted to rec.aviation.piloting,rec.travel.air
Newps
GPS was designed and built by the military. Imagine that, the airlines
not wanting to change anything but have others change to meet their
outmoded business plan. You can't change basic physics. GPS can
generate some minor efficiencies in getting aircraft to the start of the
arrival which is 150 nm from the airport. Then everybody gets lined up
and fed to the airport. GPS is of little value from that point on in
reducing spacing. How are you going to overcome the basic fact that
2.5-3 miles is the minimum useable spacing, assuming no departures?
Many studies have been done that the optimal runway occupancy time is
approx 45 seconds for a landing aircraft. More typical is 1 minute, in
good weather. That's approx 2.5-3 miles separation. You want more
operations? Lay more concrete.
  #187
Old October 31st 07, 05:38 PM posted to rec.aviation.piloting,rec.travel.air
Marty Shapiro
(John Kulp) wrote in
Let's see. US airline management, which, collectively since day one
of air travel in the US, have managed to operate at a net loss, says GPS
will solve our problem. An air traffic controller tells you about spacing
requirements for both wake turbulence and operational requirements. And
you believe the airline management?
Airlines LIE. Pure and simple. Airlines LIE.
For example, I was once on a coast to coast flight when, just after
the cabin doors closed, but before push back, our captain gets on the horn
and tells us there will be a two hour delay due to weather. Well, as I
normally pull an FAA weather briefing before any flight I take, whether I'm
flying the airplane or just a passenger, I pulled out my briefing and could
not see any weather probelms anywhere on our route. The passenger in the
seat next to me noticed what I was reading and said that she worked at the
FAA ARTCC which covered our departure airport. She calls her coworkers at
center and they don't know of any weather delays. They then call the FAA
flow control center to see if there are any problems anywhere in the USA.
Nope, none whatsoever. Yet the airline is saying there is a weather
problem.
Airlines LIE.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
  #188
Old October 31st 07, 05:54 PM posted to rec.aviation.piloting,rec.travel.air
Neil Gould
Isn't that somewhat dependent on the definition of "...the runways we have
now"? The problem is easily addressed by abandoning the hub system that
overburdens a few locations and barely worked when demand was low.
Alternatively, add hubs to some of the underutlilzed airports. Of course,
the airlines would probably find this to be a threat to direct service to
locations of highest demand, but from a passenger's point of view, it's
becoming more difficult to get a flight direct to very many places anyway.
Neil
  #189
Old October 31st 07, 06:09 PM posted to rec.aviation.piloting,rec.travel.air
Gig 601XL Builder
Of course they are saying that. They want GA to pay more and if they
admitted the problems were caused by their own scheduling then they wouldn't
be able to reduce the amount they pay into the system.
  #190
Old October 31st 07, 06:18 PM posted to rec.aviation.piloting,rec.travel.air
John Kulp
So what? I use it all the time in my car to find where I am and where
I'm going. Just like the airlines want.
Imagine you not knowing what you're talking about. The airlines have
made huge changes in their business plans which you obviously know
nothing about.
Uh, when someone else pointed out that it is currently 5-6miles you
don't call that increased efficiency? Where did you study math?
a. what studies?
b. that would increase efficiency about 50% if it is currently 6 miles
wouldn't it?
Travel aid [email protected] Soaring 0 February 7th 06 12:25 PM
Travel aid [email protected] Restoration 0 February 7th 06 12:25 PM
Travel aid [email protected] General Aviation 0 February 7th 06 12:25 PM
Travel aid [email protected] Aviation Marketplace 0 February 7th 06 12:25 PM
Travel Supplements Jetnw Aviation Marketplace 0 September 15th 04 07:50 AM
