#11
activating RW lighting
Bob Noel wrote:
In article , wrote: Even better is to find one that is not towered and do it with PCL. Be sure to let me know how many non-towered airports with precision approach lighting you find. Would KBED (when the tower is closed) and KCON count? No, neither of those airports has precision lights and it's not likely you'll find them at less than class C. See the first page of Chapter 2 in the AIM. -- Jim Pennino Remove .spam.sux to reply. |
... Bob Noel wrote: In article , wrote: Even better is to find one that is not towered and do it with PCL. Be sure to let me know how many non-towered airports with precision approach lighting you find. Would KBED (when the tower is closed) and KCON count? No, neither of those airports has precision lights and it's not likely you'll find them at less than class C. See the first page of Chapter 2 in the AIM. You don't consider a MALSR on an ILS runway to be a "precision approach lighting system?" -- Doug Semler, MCPD a.a. #705, BAAWA. EAC Guardian of the Horn of the IPU (pbuhh). The answer is 42; DNRC o- Gur Hfrarg unf orpbzr fb shyy bs penc gurfr qnlf, abbar rira erpbtavmrf fvzcyr guvatf yvxr ebg13 nalzber. Fnq, vfa'g vg? |
Doug Semler wrote:
wrote in message ... Bob Noel wrote: In article , wrote: Even better is to find one that is not towered and do it with PCL. Be sure to let me know how many non-towered airports with precision approach lighting you find. Would KBED (when the tower is closed) and KCON count? No, neither of those airports has precision lights and it's not likely you'll find them at less than class C. See the first page of Chapter 2 in the AIM. You don't consider a MALSR on an ILS runway to be a "precision approach lighting system?" I don't remember if MALSR is concidered "precision" or not. I'm referring to ALSF-1 and ALSF-2 systems. See the runway lighting info in airnav for KCON and KONT. KONT has ALSF-2 with centerline sequenced flashers and a 4 light PAPI on 26L and MALSR on 8L/26R. -- Jim Pennino Remove .spam.sux to reply. |
... Doug Semler wrote: You don't consider a MALSR on an ILS runway to be a "precision approach lighting system?" I don't remember if MALSR is concidered "precision" or not. OK, in terms of that response: Can a precision approach include a non precision lighting system? (And no, I don't know myself, so I can't answer) The orignal point was that KCON has a pilot controlled MALSR; the point made in response to a request for non-towered precision approach lighting systems. That's why I asked if you considered MALSR a precision approach lighting system. If you don't, then the points are moot, but I would like to know the answer to my last question... I'm referring to ALSF-1 and ALSF-2 systems. I think you should have said that in the first place, because obviously the original response wrt the pilot controlled MALSR @ KCON assumed that MALSR *is* precision lighting (with the sequenced flashers as well) See the runway lighting info in airnav for KCON and KONT. KONT has ALSF-2 with centerline sequenced flashers and a 4 light PAPI on 26L and MALSR on 8L/26R. I looked at both. None of KONT's lights are pilot controlled. KCON's MALSR is (along with 17-35 HILR, 12-30 MILR), and nonpilot controlled VASI on 35 and PAPI on 17. -- Doug Semler, MCPD a.a. #705, BAAWA. EAC Guardian of the Horn of the IPU (pbuhh). The answer is 42; DNRC o- Gur Hfrarg unf orpbzr fb shyy bs penc gurfr qnlf, abbar rira erpbtavmrf fvzcyr guvatf yvxr ebg13 nalzber. Fnq, vfa'g vg? |
Doug Semler wrote:
wrote in message ... Doug Semler wrote: You don't consider a MALSR on an ILS runway to be a "precision approach lighting system?" I don't remember if MALSR is concidered "precision" or not. OK, in terms of that response: Can a precision approach include a non precision lighting system? (And no, I don't know myself, so I can't answer) The orignal point was that KCON has a pilot controlled MALSR; the point made in response to a request for non-towered precision approach lighting systems. That's why I asked if you considered MALSR a precision approach lighting system. If you don't, then the points are moot, but I would like to know the answer to my last question... Like I said, I don't remember if MALSR is concidered "precision" lighting or not. There is precision approache and precision lighting, and AIR, you can have a precision approach without precision lighting. I'm referring to ALSF-1 and ALSF-2 systems. I think you should have said that in the first place, because obviously the original response wrt the pilot controlled MALSR @ KCON assumed that MALSR *is* precision lighting (with the sequenced flashers as well) See the runway lighting info in airnav for KCON and KONT. KONT has ALSF-2 with centerline sequenced flashers and a 4 light PAPI on 26L and MALSR on 8L/26R. I looked at both. None of KONT's lights are pilot controlled. KCON's MALSR is (along with 17-35 HILR, 12-30 MILR), and nonpilot controlled VASI on 35 and PAPI on 17. Since the KONT tower is open 24 hours, why would the lighting be pilot controlled? AFAIK, all ALSF sytems are run in -acronym I forgot- mode in good weather as ALSF mode is really too bright. In that mode, the lights look like Podunk Municipal. Having the tower turn everything on while on approach is dramatic; that was my point. -- Jim Pennino Remove .spam.sux to reply. |
Similar Threads | ||||
HID Lighting | Mike Rapoport | Owning | 35 | October 5th 06 09:02 PM |
EL Cockpit Lighting? | JB | Owning | 10 | October 21st 05 07:23 PM |
Runway Lighting | Slick | Piloting | 28 | January 31st 05 09:02 PM |
Electroluminescent Lighting | dave | Home Built | 10 | February 27th 04 03:46 PM |
Electroluminescent Lighting | dave | Owning | 3 | February 27th 04 03:46 PM |
