#11
In message , Mark Dickson
writes If you are thinking of buying a transponder, Paul, you should buy a mode S transponder. You are correct that a lot of the ATC units you may contact will not be Mode S equipped, but they will still recieve the mode A and mode C (4 digit assigned code and altitude). Buying a non-mode S transponder would be a waste of money, as you will need it to enter certain areas and types of airspace in the UK. A transponder mandatory zone means a mode S transponder mandatory zone. Suspect (but am not sure) that all new transponder installations in the UK must be mode S. At 19:15 12 September 2009, Andy Melville wrote: As a very uneducated pilot,following Paul Remdes suggestions, I was considering buying a Transponder mode S but then various people said local airports didnt have mode S yet so it woulld be a waste of time for some time to come..is this true? If I buy mode S can it be accessed/ used by the current systems? Some easy to understand stuff would be most welcome! Regards from UK -- Surfer! Email to: ramwater at uk2 dot net |
“ . . . in the UK. A transponder mandatory zone means a mode S transponder mandatory zone. “ Wrong, at least for the new Stansted TMZ’s: “ . . . access is permitted to any aircraft which is operating a fully functioning pressure altitude reporting transponder in accordance with the CAA’s TMZ Policy Statement or to those aircraft which the aircraft commander has obtained permission from the air traffic control unit at Stansted Airport, Farnborough Radar, or Essex Radar, as may be appropriate, to enter the restricted airspace.” So it needs Mode C, not necessarily Mode S, thought the latter also incorporates mode C. However, for new installations, I believe that Surfer is right – new installations have to mode S. If not so, no doubt somebody else will be along soon, To clarify. Chris N. |
By the way, any UK glider operator proposing to fit a transponder has to pay attention to EASA requirements, in many cases. As I have recently written elsewhe Most UK gliders are now regulated under EASA, and all modifications for those must have EASA approval. I am told that instrument panel, or wiring, or extra battery provision, are all modifications requiring approved schemes. I understand that BGA is negotiating with CAA to try to simplify and make practical obtaining such approval, more like how we used to be able to make technical and safety improvements, with BGA Technical Committee approval, before EASA and CAA regulated gliders; but I won’t believe it is possible, seeing how Europe works these days, until it is done. As far as I know, few if any EASA modifications to fit transponders, including details of wiring and battery changes, have been officially approved. A transponder on a long glider flight is likely to need at least one extra 7 amp hour battery, maybe more. I have specifically been told that to fit to my Lak 17A a Trig 2-unit transponder (the only one I am sure will fit), and an additional battery, needs all that installation to be approved. The Lak factory has EASA approval to a modification which specifies antenna, 3 specific models of transponder which do not include the Trig, and as far as I can see does not provide for any additional battery nor the wiring changes to feed the remote amplifier unit and a lead from there to the small control unit in the instrument panel. EASA thus prevents me from having a transponder. I have no design authority, nor skills or facilities, to research it, build a prototype installation, and then conduct whatever ground and flight tests are required etc., to submit a properly engineered modification scheme for EASA approval. [To run Flarm, I use a separate battery, and it is all personal carry- on equipment. PCAS is self contained, or can use a lead from the same carry-on battery, so I regard it all as personal equipment. I have, of course, ensured that it all safely stowed. PCAS and Flarm rest on Velcro-type strips in top of my instrument panel coaming. Carry-on transponders do not exist.] Chris N. |
As of 2012 it will be mode S, so not much point in buying anything else.
At 21:06 12 September 2009, Chris Nicholas wrote: =93 . . . in the UK. A transponder mandatory zone means a mode S transponder mandatory zone. =93 Wrong, at least for the new Stansted TMZ=92s: =93 . . . access is permitted to any aircraft which is operating a fully functioning pressure altitude reporting transponder in accordance with the CAA=92s TMZ Policy Statement or to those aircraft which the aircraft commander has obtained permission from the air traffic control unit at Stansted Airport, Farnborough Radar, or Essex Radar, as may be appropriate, to enter the restricted airspace.=94 So it needs Mode C, not necessarily Mode S, thought the latter also incorporates mode C. However, for new installations, I believe that Surfer is right =96 new installations have to mode S. If not so, no doubt somebody else will be along soon, To clarify. Chris N. |
On Sep 12, 2:45*pm, Mark Dickson wrote:
As of 2012 it will be mode S, so not much point in buying anything else. At 21:06 12 September 2009, Chris Nicholas wrote: =93 . . . in the UK. *A transponder mandatory zone means a mode S transponder mandatory zone. =93 Wrong, at least for the new Stansted TMZ=92s: =93 . . . access is permitted to any aircraft which is operating a fully functioning pressure altitude reporting transponder in accordance with the CAA=92s TMZ Policy Statement or to those aircraft which the aircraft commander has obtained permission from the air traffic control unit at Stansted Airport, Farnborough Radar, or Essex Radar, as may be appropriate, to enter the restricted airspace.=94 So it needs Mode C, not necessarily Mode S, thought the latter also incorporates mode C. However, for new installations, I believe that Surfer is right =96 new installations have to mode S. If not so, no doubt somebody else will be along soon, To clarify. Chris N. And for USA readers we have much longer to worry about Mode-S type things, so normally I would have said just install a Mode-C, save some money and in a decade replace it with Mode-S or whatever. However the Trig TT-21 is a game changer. You get Mode S/1090ES ADS-B out capabilities for future possible use and more immediately, it is more compact, easier to install and uses less power than other options. So for those folks flying in those high density/fast jet traffic areas like near Reno, there is even less excuses not to be using a transponder. It will be interesting to see how Becker and others respond. Becker's new more compact VHF radio looks really nice. Darryl |
Użytkownik Darryl Ramm napisał:
However the Trig TT-21 is a game changer. You get Mode S/1090ES ADS-B out capabilities for future possible use and more immediately, it is more compact, easier to install and uses less power than other options. Could you confirm that Trig will not work in A/C-only radar environment? -- Wojtu¶.net |
On Sep 13, 2:08*pm, Wojciech Scigala wrote:
Użytkownik Darryl Ramm napisał: However the Trig TT-21 is a game changer. You get Mode S/1090ES ADS-B out capabilities for future possible use and more immediately, it is more compact, easier to install and uses less power than other options. Could you confirm that Trig will not work in A/C-only radar environment? -- Wojtu¶.net It is a Mode S transponder. It is compatible with Mode A/C SSR. Think of Mode S as an enhancement to Mode A/C. It's not an alternate choice. It really makes no sense to ask if these Mode S transponders support mode A/C. Darryl |
It is a Mode S transponder. It is compatible with Mode A/C SSR. Think of Mode S as an enhancement to Mode A/C. It's not an alternate choice. It really makes no sense to ask if these Mode S transponders support mode A/C. Paul's comparision table says it's just "Mode S", while Becker 6401 is "Mode A, A+C, S". Technically it is possible to create a mode-S only transponder. But I'm not sure if it's legal (certifiable). If Trig supports A/C, that's good to know! -- Wojtu¶.net |
During my certification testing, the tech initially used a Mode A/C tester
as his Mode S test set was out being calibrated. The TRIG passed all Mode A/C tests. John |
| Thread Tools | |
| Display Modes | |
| Crossover table? | trailgalore | Piloting | 1 | February 15th 08 01:33 AM |
| Airspeed comparison table | grubertm | Piloting | 6 | September 1st 05 12:10 AM |
| diesel engines for general aviation - small comparison table | max | Home Built | 2 | August 29th 05 09:19 PM |
| Help requested with Soaring Flight Software Comparison Table | Paul Remde | Soaring | 25 | September 3rd 04 08:16 AM |
