On Sep 28, 1:36*am, D Ramapriya wrote:
On Sep 28, 8:36*am, Clark wrote: D Ramapriya wrote in news:2f5fa47a-a9a0-4d76-897e- : Jeez, in most videos I've seen of yours, the stall horn has sounded just before touchdown. I bet you like hairy landings ![]() Just an educational point: a perfect landing includes a full stall about a foot off the ground. Typically the stall horn will sound about 5 to 10 knots above the actual stall. Alan's landings appear to be quite good. In other words, there is no harm in stalling within a few inches of the runway. On the other hand, there can be great harm in attempting to land way to fast. Thanks, mate. Won't this lead to dodgy finals in a situation where the headwind tails off for some reason (a gust or some such)? Ramapriya In most of our SELs the stall warning sounds 5 or 8 knots before the stall. That's a nice margin. The only time I am not going to want the stall to sound is if there's a big cross wind and I am running out of rudder authority at low air speeds. Too much airspeed in the flair is, in this pilot's opinion, the sign of an airplane driver who has not been trained well. Ditto, for that matter, for the guy who touches down in a SEL 2000 feet from his turn off, then finds himself driving the airplane on the ground for an extra 1000 plus feet. A good landing in my view is where there's a stall warning, throttle aft, touchdown, and make the turn off without using throttle or break. |
![]() "a" wrote A good landing in my view is where there's a stall warning, throttle aft, touchdown, and make the turn off without using throttle or break. Or without using the brakes, in case nothing is broken. ;-) -- Jim in NC |
On Sep 28, 6:44*pm, "Morgans" wrote:
"a" wrote A good landing in my view is where there's a stall warning, throttle aft, touchdown, and make the turn off without using throttle or break. Or without using the brakes, in case nothing is broken. ;-) -- Jim in NC Nice catch! But it is good not to break anything and if you brake too hard you may. It IS Monday, I think it's going to be a bad weak. |
On Sep 28, 10:00*am, Clark wrote:
D Ramapriya wrote in news:e238c979-3550-4a59-87f1- : On Sep 28, 8:36*am, Clark wrote: D Ramapriya wrote in news:2f5fa47a-a9a0-4d76-897e - : Jeez, in most videos I've seen of yours, the stall horn has sounded just before touchdown. I bet you like hairy landings ![]() Just an educational point: a perfect landing includes a full stall about a foot off the ground. Typically the stall horn will sound about 5 to 10 kn ots above the actual stall. Alan's landings appear to be quite good. In other words, there is no harm in stalling within a few inches of the runway. On the other hand, there can be great harm in attempting to land way to fast. Thanks, mate. Won't this lead to dodgy finals in a situation where the headwind tails off for some reason (a gust or some such)? Final is typically flown at 1.3*Vso which translated means 30% above stall speed. The extra velocity is lost in the roundout at the bottom of the approach. If the winds are gusty then 1/2 the gust factor is added to the approach speed. The gust factor is the difference between the base wind velocity and the maximum gust velocity. Folks have been doing this for a long time and the numbers work really well. Correct me if I'm wrong but there may also be the possibility that in aircraft where the computer doesn't correlate data from the AOA sensor, you'll probably get a slightly slower airspeed indication than actual during the flare, in which case even the stall horn would be a kind of false alarm ![]() Ramapriya |
![]() "D Ramapriya" wrote in message ... On Sep 28, 10:00 am, Clark wrote: D Ramapriya wrote in news:e238c979-3550-4a59-87f1- : On Sep 28, 8:36 am, Clark wrote: D Ramapriya wrote in news:2f5fa47a-a9a0-4d76-897e - : Jeez, in most videos I've seen of yours, the stall horn has sounded just before touchdown. I bet you like hairy landings ![]() Just an educational point: a perfect landing includes a full stall about a foot off the ground. Typically the stall horn will sound about 5 to 10 kn ots above the actual stall. Alan's landings appear to be quite good. In other words, there is no harm in stalling within a few inches of the runway. On the other hand, there can be great harm in attempting to land way to fast. Thanks, mate. Won't this lead to dodgy finals in a situation where the headwind tails off for some reason (a gust or some such)? Final is typically flown at 1.3*Vso which translated means 30% above stall speed. The extra velocity is lost in the roundout at the bottom of the approach. If the winds are gusty then 1/2 the gust factor is added to the approach speed. The gust factor is the difference between the base wind velocity and the maximum gust velocity. Folks have been doing this for a long time and the numbers work really well. Correct me if I'm wrong but there may also be the possibility that in aircraft where the computer doesn't correlate data from the AOA sensor, you'll probably get a slightly slower airspeed indication than actual during the flare, in which case even the stall horn would be a kind of false alarm ![]() Ramapriya Small aircraft do not use any computers to actuate the stall horn. Instead, there are ports on the leading edge of the wing in a precise location so that the air moves from one to the other at stall only, which blows a reed horn, or some have a little flap that blows over at the leading edge that turns on a switch to sound an electric horn. In either case, it is aerodynamic airflow that triggers the stall horn. -- Jim in NC |
On Sep 30, 3:13*am, Clark wrote:
D Ramapriya wrote in news:2c0fab6a-a8d4-4889-a0ef- : As for the accuracy of the airspeed indicator, well we generally stall the aircraft in training and proficiency flights so we know exactly when the stall occurs even if the indicated airspeed might be in error. As an aside, the aircraft will usually tell you through handling characteristics and vibration that it's going to stall. The aircraft that don't tell you about the impending stall are the ones with which to be very careful. Thanks, especially for the above bit. Don't know if it's because someone once told me or something I'd read somewhere but I was under the impression that when flying and if you didn't have external visual references of the ground, there's NO way that a pilot can know the airspeed of his aircraft. On another matter, everything I've read so far about the AF447 crash suggests that the aircraft was upset because it flew too slow (iced pitot leading to erroneous airspeed readings) and pretty much went down like a bag of cement and possibly hit the water at a nearly level attitude! Ramapriya |
On Sep 29, 9:29*pm, D Ramapriya wrote:
Thanks, especially for the above bit. Don't know if it's because someone once told me or something I'd read somewhere but I was under the impression that when flying and if you didn't have external visual references of the ground, there's NO way that a pilot can know the airspeed of his aircraft. Visually, you are correct and even "sensually" (feeling), while IMC there is no way to tell speed or what direction the nose of the plane is pointed (up, down, right or left). The instrumentation is the only source of information you have telling you what direction the ground and sky points to. With regards to airspeed, there are other clues to be watched for airspeed besides the airspeed indicator and one is engine RPM. Generally speaking, under normal flight attitudes, the engine RPM will increase as you point down which subsequently means your airspeed is building. You hear this increase just as if you hear the engine noise level go down, that would normally indicate the nose of the plane is pointed up and your airspeed is decreasing. |
ILS approach and VOR Alpha Approach video | DOCTOR Mary Ellen Hall McIntire Yasay, Ph.D, (Div.) | Piloting | 3 | May 22nd 08 01:52 PM |
ILS approach and VOR Alpha Approach video | [email protected] | Instrument Flight Rules | 10 | May 22nd 08 02:15 AM |
ILS approach and VOR Alpha Approach video | [email protected] | Piloting | 4 | May 17th 08 01:19 PM |
First approach to minimums | Steven Barnes | Instrument Flight Rules | 0 | October 21st 05 07:47 PM |
CAT II Minimums on a CAT I Approach | Giwi | Instrument Flight Rules | 11 | July 24th 03 07:46 AM |
