On Nov 18, 4:12*pm, Craig wrote:
On Nov 18, 3:35*pm, glider wrote: *The process is very messy and can be hazardous to your health. And it takes many, many hours of careful preperation. *Labor intensive. *As JJ said, mass balance of controls *is very important. * 400-1000 hours is possible...no joke. *Polyurethane may be best way to go. *GA Jim Phoenix nicely documented the refinish on his Nimbus 3.http://www.jimphoenix.com/?page_id=42 Heck, anything less than 18m will seem like a cakewalk. *Just don't plan on having a social life this winter... Best regards, Craig Funston Jim Phoenix reads RAS from time to time, so I'll try not to tell any lies. I corresponded with him quite some time ago, about the time I was re-finishing a small portion of my fuselage with gelcoat. Regarding the gelcoat vs poly, I'm pretty sure he said if he had it to do over again, he wouldn't gelcoat, he'd shoot polyurethane. |
![]() "Uncle Fuzzy" wrote Jim Phoenix reads RAS from time to time, so I'll try not to tell any lies. I corresponded with him quite some time ago, about the time I was re-finishing a small portion of my fuselage with gelcoat. Regarding the gelcoat vs poly, I'm pretty sure he said if he had it to do over again, he wouldn't gelcoat, he'd shoot polyurethane. Is that polly paint, or something else you are talking about? What polly product builds as thick as jell coat? I'm still trying to learn about the glass and more exotic composites. I'm a wood or metal kinda' guy! -- Jim in NC |
On Nov 18, 9:17*pm, Uncle Fuzzy wrote:
On Nov 18, 4:12*pm, Craig wrote: On Nov 18, 3:35*pm, glider wrote: *The process is very messy and can be hazardous to your health. And it takes many, many hours of careful preperation. *Labor intensive. *As JJ said, mass balance of controls *is very important. * 400-1000 hours is possible...no joke. *Polyurethane may be best way to go. *GA Jim Phoenix nicely documented the refinish on his Nimbus 3.http://www.jimphoenix.com/?page_id=42 Heck, anything less than 18m will seem like a cakewalk. *Just don't plan on having a social life this winter... Best regards, Craig Funston Jim Phoenix reads RAS from time to time, so I'll try not to tell any lies. *I corresponded with him quite some time ago, about the time I was re-finishing a small portion of my fuselage with gelcoat. Regarding the gelcoat vs poly, *I'm pretty sure he said if he had it to do over again, he wouldn't gelcoat, he'd shoot polyurethane.- Hide quoted text - - Show quoted text - I've refinished in both Acrylic Urethane and polyester topcoat (commonly called "gelcoat'). From my experience, each has it's place. Gelcoat goes on thick and is tolerant of a lot of sins. Amatuer spraying skills don't make a disaster. It does get hard and takes quite a bit of work to sand out and polish. Life expectancy, if done right and stored properly, should be plenty long. It is comparatively inexpensive- roughly $500 for a 15 meter glider for material and catalyst. AU- I use PPG Concept as suggested by JJ and others, requires excellent preparation and as perfect a surface as you can get because it does not have much thickness. Gloss is great and is sands easier than gelcoat. BUT. Time and effort, from my experience with both is that the extra time in prep before spraying AU exceeds the difference to sand out and polish gelcoat. AU is outstanding in UV protection and far exceeds gelcoat with respect to weathering. AU costs about 2 1/2 times as much as gelcoat. AU must be sprayed in a safer environment and MUST be done using full positive pressure protection gear as it contains what is essentially a nerve toxin(aliphatic isocyanate). Gelcoat is easier for fixing up that occasional ding. So- long winded- which to use and why. We did our ASK-21's in AU because of amount of time in weather and harder life. We do others in gelcoat for easier touchup, lower cost , and less toxic exposure. If you are going to do one glider one time as a beginner, I would suggest polyester finish. JJ likes AU but remember he has a huge amount of experience that a new person won't have. Choice may well also be affected by availability of experienced help. FWIW UH |
On Nov 19, 5:58*am, wrote:
On Nov 18, 9:17*pm, Uncle Fuzzy wrote: On Nov 18, 4:12*pm, Craig wrote: On Nov 18, 3:35*pm, glider wrote: *The process is very messy and can be hazardous to your health. And it takes many, many hours of careful preperation. *Labor intensive. *As JJ said, mass balance of controls *is very important. * 400-1000 hours is possible...no joke. *Polyurethane may be best way to go. *GA Jim Phoenix nicely documented the refinish on his Nimbus 3.http://www..jimphoenix.com/?page_id=42 Heck, anything less than 18m will seem like a cakewalk. *Just don't plan on having a social life this winter... Best regards, Craig Funston Jim Phoenix reads RAS from time to time, so I'll try not to tell any lies. *I corresponded with him quite some time ago, about the time I was re-finishing a small portion of my fuselage with gelcoat. Regarding the gelcoat vs poly, *I'm pretty sure he said if he had it to do over again, he wouldn't gelcoat, he'd shoot polyurethane.- Hide quoted text - - Show quoted text - I've refinished in both Acrylic Urethane and polyester topcoat (commonly called "gelcoat'). From my experience, each has it's place. Gelcoat goes on thick and is tolerant of a lot of sins. Amatuer spraying skills don't make a disaster. It does get hard and takes quite a bit of work to sand out and polish. Life expectancy, if done right and stored properly, should be plenty long. It is comparatively inexpensive- roughly $500 for a 15 meter glider for material and catalyst. AU- I use PPG Concept as suggested by JJ and others, requires excellent preparation and as perfect a surface as you can get because it does not have much thickness. Gloss is great and is sands easier than gelcoat. BUT. Time and effort, from my experience with both is that the extra time in prep before spraying AU exceeds the difference to sand out and polish gelcoat. AU is outstanding in UV protection and far exceeds gelcoat with respect to weathering. AU costs about 2 1/2 times as much as gelcoat. AU must be sprayed in a safer environment and MUST be done using full positive pressure protection gear as it contains what is essentially a nerve toxin(aliphatic isocyanate). Gelcoat is easier for fixing up that occasional ding. So- long winded- which to use and why. We did our ASK-21's in AU because of amount of time in weather and harder life. We do others in gelcoat for easier touchup, lower cost , and less toxic exposure. If you are going to do one glider one time as a beginner, I would suggest polyester finish. JJ likes AU but remember he has a huge amount of experience that a new person won't have. Choice may well also be affected by availability of experienced help. FWIW UH UH, I am guessing the "gelcoat" is Prestec, made by Simtec Coatings? I sprayed my Apis with it. I do like using it also. The guys at Simtec will tell you they call it a "polyester topcoat". The one nagging problem I can't seem to get away from is that here in the Pacific NW, my Apis grows nasty blisters in the paint every year around this time. I have a well insulated trailer, with a vent. But, I am not able to run power to the trailer for a heat source and a small fan. Cheers, Brad |
![]() Heck, anything less than 18m will seem like a cakewalk. *Just don't plan on having a social life this winter... I am restoring an LS-1 right now. And I can truely attest to the amount of work it's taking. I'm taking my time, going very slow and using the advice from 6 mentors who have repainted a glider before. One of which is giving me weekly advice, sometimes daily. My friend Ralph Luebke who has built many gliders before gave me a peice of a wing that came from a grob twin astir. I would HIGHLY recommend getting a small peice from a wrecked glider and practing on that first. This was a great idea that has taught me a bunch. I took a 3 foot section about mid wing that was sawed off on both sides, then aggresively took a sander to it to see just how it would look to go through the gelcoat and into the fiberglass. You can destroy the bottom side perhaps to learn by pushing the limits of a sander, or you could take another section and restore it with "no fear" of hurting a wing. It was great to purposely make a mistake on a wrecked gliders wing verses accidently making mistake on an airworthy glider like my LS-1. If your retired, part time or on an airline pilot schedule like me (20 days off/month)...the amount of work can easily be scheduled as to avoid interferring with your social life. I have really had alot of fun in the garage listening to talk radio, listening to my ipod and spending time on my favorite hobby during a rainy day. So far, it's alot of work, but enjoyable to see this old glider come back to life! Anybody got a wrecked fiberglass glider wing (1 to 3 foot section) they could give to jeplane? |
Source for Gelcoat in USA? | John Bojack[_2_] | Soaring | 1 | June 9th 09 05:25 AM |
Gelcoat sag? | [email protected] | Soaring | 10 | December 17th 07 08:07 PM |
Fiberglass/gelcoat repair question | Kilo Charlie | Soaring | 9 | April 19th 05 03:30 PM |
Ferro gelcoat | Basil Fairston | Soaring | 0 | December 16th 03 08:34 AM |
Refinishing gelcoat | tango4 | Soaring | 21 | November 3rd 03 07:29 AM |
