US: Soaring Magazine 1937 through 1967 available online
Old November 25th 09, 07:14 PM posted to rec.aviation.soaring
Greg Arnold
Default Soaring Magazine 1937 through 1967 available online
I am too dense to figure this out on my own. Could you explain the
steps to take to get to the scanned issues? I am not having much luck
getting there from the listings by year.
John Leibacher wrote:
Sorry, Andy. The content is linked everywhere BUT the search tool,
for the moment. I'll get it there over the T'Day holidays I hope.
Just go to the listings by year, for the moment.
John L
On Nov 25, 7:55 am, Andy wrote:
On Nov 25, 2:09 pm, John Leibacher wrote:
http://soaringweb.org/Soaring_Indexisthe top level URL for the
index. For any of the listings (by Issue, Subject, Author, etc...)
for a year in this interval, click on a highlighted page number to get
the scanned page. Or you can select "Content" to get links to the
whole year, page by page.
Thanks for making this available. I found the search easy to use and
found several references I wanted to look at. That's as far as I was
able to go. I tried clicking all over the place but never found out
how to get to the search results. I saw no highlighted page numbers.
Is IE 6.x supported ?
Yes, it works fine. The search isn't supported quite yet, that's all.
Andy
Old November 25th 09, 07:30 PM posted to rec.aviation.soaring
Tim Taylor
index. *For any of the listings (by Issue, Subject, Author, etc...)
the scanned page. *Or you can select "Content" to get links to the
Thanks for making this available. *I found the search easy to use and
found several references I wanted to look at. *That's as far as I was
able to go. *I tried clicking all over the place but never found out
how to get to the search results. *I saw no highlighted page numbers.
Andy
No highlighted page numbers in Firefox.
Greg,
Try:
http://soaringweb.org/Soaring_Index/listings.html
Then pick any year from 1937 to 1967. Or click on the "Contents" link
for those years and you should access the images of the pages in pdf
format. Make sure you have a good pdf viewer installed on your
computer.
If you need a viewer try Adobe or any of the other free viewers out
there.
http://www.adobe.com/products/reader/
Old November 25th 09, 08:01 PM posted to rec.aviation.soaring
Greg Arnold
Thanks. We are making progress, but I see that the URL of the scanned
pages ends with .html rather than .pdf. See, for example, any of the
links at:
http://soaringweb.org/Soaring_Index/...pdf_index.html.
I don't know anything about computers, but wouldn't you use a .pdf
suffix for a PDF file? Or am I still looking in the wrong place?
Trying to open a link either crashes Firefox, or I get a message that my
pdf reader (FoxIt) refuses to load.
Andy
Greg,
Try:
computer.
there.
Old November 25th 09, 08:54 PM posted to rec.aviation.soaring
mike
Default US: Soaring Magazine 1937 through 1967 available online
Thanks Kathy.
This is really great!
Mike C
make for extremely interesting reading.
This is a "beta" release, and there are bound to be glitches in
getting
the pages of the scan matched up with the index, so please pass along
any problems that you encounter and suggestions for the improvement of
access to this wonderful resource.
Thanks also to Bertha Ryan for helping making all of this happen.
MANY THANKS Kathy, the rest of you enjoy!
John Leibacher
Old November 25th 09, 08:58 PM posted to rec.aviation.soaring
Tim Taylor
On Nov 25, 1:01*pm, Greg Arnold wrote:
Thanks. *We are making progress, but I see that the URL of the scanned
pages ends with .html rather than .pdf. *See, for example, any of the
links at:http://soaringweb.org/Soaring_Index/...pdf_index.html..
suffix for a PDF file? *Or am I still looking in the wrong place?
Greg,
Sounds like your pdf reader, FOXIT, is not working with the webpages.
Mine works fine with Adobe Acrobat Plug-in turned on.
You cna load adobe acrobate and then make sure that the plug in is
turned on in FireFox.
Follw these menues in FireFox
Tools
Options
Add-ons
Old November 25th 09, 09:03 PM posted to rec.aviation.soaring
Tim Taylor
http://soaringweb.org/Soaring_Indexisthetop level URL for the
Andy
Greg,
Try:
Then pick any year from 1937 to 1967. *Or click on the "Contents" link
format. *Make sure you have a good pdf viewer installed on your
computer.
there.
Greg,
You can load adobe acrobat and then make sure that the plug in is
Follow these menus in FireFox
Tools
Options
Add-ons
Manage Add-ons
Click the plug-in tab and make sure that Adobe Acrobat Plug-in
is enabled.
Good luck
Old November 25th 09, 09:07 PM posted to rec.aviation.soaring
Bob
Snip
I must admit I was confused until I read more carefully that only 1937
to 1967 has the hot links on the page numbers, and they show in
Firefox, and from there you get to page through the entire issue. The
links take you to 'standard' html pages, not pdf's... at least for me.
What a great job! Well done!
For those wanting even more to read, the Canadian journal, Free
Flight, thanks to Tony Burton,
is available from 1981 forward at: http://www.sac.ca/index.php?option=c...18&Itemi d=26
Old November 25th 09, 09:40 PM posted to rec.aviation.soaring
Bob
snipks at:http://soaringweb.org/Soaring_Index/1945/PDF/
1945_pdf_index.html.
*snip
Looks like all links are to an html page which in turn will launch an
embedded pdf file. Working for me in Firefox 3.5.5 and Acrobat reader.
Here's March 1965 page 21 as an example:
http://soaringweb.org/Soaring_Index/...65_Mar_21.html
It's an html link, but that has the embedded page 21 scan in it. Once
there, you move page to page using the top controls.
Old November 25th 09, 09:58 PM posted to rec.aviation.soaring
Robert Danewid
I also have Firefox 3.5.5 and Acrobat Reader 6.0 , and it does not work.
It says "Operation is not allowed".
/Robert
snip
Old November 25th 09, 10:00 PM posted to rec.aviation.soaring
Chris Reed[_2_]
I had to update to the latest version of Reader (9.2 I think) to access
these.
/Robert
snip
Futuristic sailplane on December 1967 Soaring cover John White Soaring 3 August 28th 09 01:24 PM
Soaring Server "soaring.aerobatics.ws" is back online John Leibacher Soaring 0 December 23rd 04 04:33 AM
Soaring Server/Worldwide Soaring Turnpoint Exchange back online John Leibacher Soaring 0 June 21st 04 05:25 PM
New, free online Magazine Bob Rotorcraft 1 January 20th 04 07:37 PM
"Soaring" magazine on CD-ROM like EAA Burt Compton Soaring 5 July 12th 03 10:20 PM
