Launch point logging software flight accounting
Old December 3rd 09, 02:43 AM posted to rec.aviation.soaring
Andy[_10_]
Default Launch point logging software flight accounting
On Nov 26, 6:32*pm, "BT" wrote:
The manual operations required to download gps files from all the aircraft,
loading into a computer and adding pilot billing accounts would take more
time than transferring a manual log to a spreadsheet.
The trick is to get the spreadsheet data into the accounting and billing
system.
"bildan" wrote in message
On Nov 26, 5:05 pm, stevehaley wrote:
Like many clubs mine blows hot and cold on using launchpoint logging
software.
At present we have a legacy system handling flight recording from
paper records taken at the launch point with a link to our accounting
system which was written by a club member who left some time ago and
the system should probably be overhauled/replaced regardless of adding
a launchpoint bit. While it does tick the simple easy to use box I
suspect that savings could be made in terms of staff time entering the
data later.
I suspect that many other clubs are in a similar position or are
paying for the software. I would like to explore the possibility of a
collaborative venture making the end result open source which will
hopefully ensure that the support continues into the future and the
package moves forward
Would anyone who is interested in participating please contact me on
the email address below. Would also be interested to hear from anyone
who has a good robust system and is willing to donate it to the
community as a starting point.
A critical mass of at least 5-6 clubs and 4+ developers is probably
required - location is not seen as an issue and it should be easy
enough to make the software multilingual.
I would also like to hear of other clubs experiences using launchpoint
logging systems with respect to reliability, redundancy, ease of use
etc etc.
rgds
Stephen
sjhcon_at_gmail.com
Good idea.
It strikes me that if both gliders and tugs carried GPS loggers, all
flight data could be automatically captured except for matching
flights to member names which should be fairly easy to do manually.
Tows would be matched to glider flights since the logs are time
stamped. *A tow starting at exactly the same time as a glider flight
would link them together.
A software package that created a daily screen from the logs data
where pilot names could be entered manually would make billing easier
- and a lot more accurate.
Partly true. It only works for the towed pilots who give you a log
file - absent that you have a mixed system of computer and manual
matching, which of course means that the tow pilots or ops director
need some sort of hand-written record.
9B
Old December 3rd 09, 04:46 PM posted to rec.aviation.soaring
Craig[_2_]
On Nov 29, 10:23*am, Andy wrote:
On Nov 28, 9:27*am, bildan wrote:
On Nov 28, 10:10*am, Andy wrote:
Wireless tech would make a nifty system but it isn't absolutely
needed. *If the GPS loggers recorded on SD cards, just bring them to
the club office for the software to read. *You'd still have to
manually log who flew which glider but the altitudes and flight
durations would be perfectly accurate.
Here's a logger with SD capability and Bluetooth:
http://www.sparkfun.com/commerce/pro...oducts_id=8823
I still see a few potential problems:
- I you relieve the ops/launch director and tow pilots from recording
times and altitudes you are making the day's operations subject to the
reliability of the technology. Since tow pilots wouldn't be using the
logger for anything related to their duties they would have no idea
whether it is functioning properly until the end of day data
collection exercise - at which point it's really too late to recover.
If you keep written logs as a backup you are giving up most of the
benefit as I don't see much operational benefit to the end of day
accounting - in one case you have to download a bunch of logs and
manually sync them up with the aircraft bring towed versus simply
putting in the altitudes and registration numbers off the tow pilots'
sheets.
- There are similar issues for logging club glider flights. Managing
SD cards, making sure they are in and that the logger battery is
charged before each flight are a couple of the operational issues I
can imagine.
- Wireless would be a way for the ops director to sync up after each
flight and ensure that everything is working properly - but then you'd
have to have a process to acquire the signal from the towplane each
time. Bluetooth isn't great at this and the loggers may not be smart
enough to automatically download.
- At $150 a pop this becomes expensive, particularly if you want to
include gliders in addition to just towplanes. You might rather have
igc loggers in gliders, but that is even more expensive.
- Even with all of this you still have to sync up each flight/tow with
a customer. Some people just aren't good at doing this on a computer
versus pen and paper.
Not that it couldn't be done - eventually it will be I expect. But you
need to get the infrastructure in place - I expect pure record keeping
isn't enough justification for most clubs. *A first step would be
allowing off-the-shelf commercial loggers to be used for badge
flights. *If you already had a logger in every aircraft it would open
up their use for other purposes.
For the flight line I expect a touchscreen e-paper tablet would be a
good solution.
http://www.engadget.com/2009/03/03/h...ual-panel-touc...
Still needs development...
9B
Seems like existing package tracking technology using bar codes could
be pretty easily implemented. There are ruggedized hand held scanners
that are used in shipping ports, etc. Each glider would have a bar
code label as would each pilot. There might even be a way to put a
tag at the end of the towrope identifying the towplane, although this
end of the rope gets a lot of abuse. Scans at take off and landing
would log all the important info. A paper backup and option for
exceptions would need to be handy, but overall it could reduce the
effort of time entry for billing.
Craig
Old December 3rd 09, 05:08 PM posted to rec.aviation.soaring
Darryl Ramm
sheets.
can imagine.
good solution.
9B
be pretty easily implemented. *There are ruggedized hand held scanners
that are used in shipping ports, etc. *Each glider would have a bar
code label as would each pilot. *There might even be a way to put a
end of the rope gets a lot of abuse. *Scans at take off and landing
would log all the important info. *A paper backup and option for
Craig
I suspect many places would not think it was a good idea to burden the
flight line crew in immediate proximity to the glider with data
collection responsibilities. Those folks should focus on safe handling
and launch of the gliders. In some places they do take tow-tickets
etc. from pilots but in many others the recording is done near flight
line by other staff. Then for large scale operations with gliders
rolling out after landing over large areas you want somebody to go
chase down each glider to record a landing? Then what about visiting
gliders or pilots who forget their barcode badge?
I think many of these ideas are solutions seeking a problem. A pencil
and paper seems pretty neat to me. The places this works best I've
seen use either tow-tickets handed to the ground staff before push-out
(or no push-out) or have a person dedicated to just writing down tow
plane, take off time, contest IDs/pilot names. Both seem relatively
easy to correlate to the tow-plane log.
But wait - there is ADS-B (or Flarm) as long as all tow planes and
gliders are in range of a base-station receiver you could just work it
out from that data. But again, I think this is (even more) technology
looking for a problem solvable with pen and paper (high contrast,
daylight viewable, ulta-low power, archival, digital (your
fingers), ....).
Darryl
Old December 3rd 09, 05:24 PM posted to rec.aviation.soaring
bildan
sheets.
can imagine.
good solution.
http://www.engadget.com/2009/03/03/h...ual-panel-touc....
9B
Craig
fingers), ....).
Darryl
Hey, don't knock technology. It's -5C and snowing outside and
discussions like this are fun.
So, how about club membership cards with RFID chips? The glider's
logging device recognizes the RFID chip in the members wallet so the
glider flight time log can be connected with the members name for
billing.
There may be no need for a logger in the tug since glider flight
analysis software now can reliably recognize release heights.
If the loggers have enough flash memory, the club treasurer can
collect the data from the loggers once a month.
Old December 3rd 09, 05:36 PM posted to rec.aviation.soaring
Darryl Ramm
Old December 3rd 09, 06:09 PM posted to rec.aviation.soaring
bildan
sheets.
can imagine.
good solution.
9B
Craig
fingers), ....).
Darryl
Hey, don't knock technology. *It's -5C and snowing outside and
So, how about club membership cards with RFID chips? *The glider's
billing.
You need to move to a warmer climate :-)
Technology is wonderful, I can see somebody casually wandering by the
flight line with their RFID card in their wallet and being billed for
the next tow.
If untangling written records is hard now, think what untangling this
will be with missing/deleted log files, dead flight recorders, wrong
glider/pilot info in the files, ID cards/devices mixed up etc.
Darryl
No problem. Just program the logging device to read the RFID card at
tow release. It's pretty hard to read the wrong RFID card that far
from the flight line. Or just read and log the RFID card every 15
minutes during the flight.
Old December 3rd 09, 07:21 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Murphy says it would probably bill a day's flying to the instructor
rather than his students.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 3rd 09, 09:29 PM posted to rec.aviation.soaring
bildan
On Dec 3, 12:21*pm, Martin Gregorie
No problem. *Just program the logging device to read the RFID card at
tow release. *It's pretty hard to read the wrong RFID card that far
from the flight line. *Or just read and log the RFID card every 15
martin@ * | Martin Gregorie
org * * * |
Easy to set the software to never charge an instructor unless it's a
solo flight. If it's a non-instructional shared-cost joyride, it
would be up the the instructor to see that his passenger is not
automatically charged for the whole flight. The software would also
know it's an instructor's duty day and not charge him.
On the other hand, a club using manual paper records charged over
$1000 of my student's fees to my account. When a challenged the fees,
the said the paper logs were lost and refused to reverse the charges.
It was an effort to force instructors to do all the club's
accounting. This even though I charged nothing for my services. I
eventually just paid it and left the club. Some clubs wonder why they
can't get instructors.
Having GPS logs for every flight in every glider could also be very
useful to the safety committee investigating an incident and for
instructors keeping an eye on their solo students.
Old December 3rd 09, 10:49 PM posted to rec.aviation.soaring
valsoar
We (Valley Soaring club) considered a few options but stuck with paper
logging at the launch point. Easy to log flights, no batteries
required, no sunlight readability problems, no 'computer training'
required for loggers and our launch point is open to the elements and
has no power.
What I did was build a MS Access program into which the logsheet can
be keyed (columns on paper logsheets match exactly data entry columns
in the program). This makes it pretty easy and fast to key in the
logsheet at the end of the day. The MS Access program uses QOBC (ODBC
driver for quickbooks) and turns each flight into multiple
transactions which get pushed automatically into quickbooks. Each one
line flight record entered in Access feeds separate Tow and rental or
lesson charges to quickbooks together with credits for the instructors
and tow-pilots or commerical pilots flying rides. So basically we key
in the logsheet once and at the end of the month members get emailed
statements from quickbooks with all their charges detailed out. The
Access program also serves as a log-book for all the clubs members and
gliders (including reminders of when 100hrs are due etc). The flight
logs are also ftp'd weekly from our Access database to our website (in
Excel format) so that any members can check the logsheet detail if
they have a question when they get their statement or even simply if
they need info to fill in their logbook. It's not launch point but it
works pretty well.
Alasdair Crawford
www.valleysoaring.org
Old December 3rd 09, 11:41 PM posted to rec.aviation.soaring
On Thu, 03 Dec 2009 13:29:55 -0800, bildan wrote:
On Dec 3, 12:21Â*pm, Martin Gregorie
solo flight. If it's a non-instructional shared-cost joyride, it would
be up the the instructor to see that his passenger is not automatically
charged for the whole flight. The software would also know it's an
I was meaning that the RFID reader might refuse to read anything but the
instructor's tag.
I know nothing about RFID readers and whether they can get locked onto
the 'loudest' tag, but if its a cheap reader, cheap tags and there's the
faintest possibility of this happening, Murphy will make sure it does
while ensuring that his intervention isn't believed.
org |
Turn point website and flight logs Udo Soaring 2 December 5th 06 10:03 PM
Logging Flight Time Question Phoenix Pilot Piloting 1 June 13th 04 06:23 PM
Flight Logging - Cheap Marry Daniel or David Grah Soaring 10 March 10th 04 01:22 AM
Safelog software/flight log software question Mark Piloting 2 December 8th 03 02:34 PM
Club Accounting S/W WDM Soaring 0 October 27th 03 04:39 PM
