Stretching the Final Glide
Old December 12th 09, 01:59 AM posted to rec.aviation.soaring
Markus Graeber
Default Stretching the Final Glide
If you read the title at the beginning of the video it says EGC (as in
European Gliding Championships) 2005 in Nitra (Slovakia). This is a
competition finish at a major gliding competition, there won't be any
student pilots on solo nor will there be "normal" patterns (especially
not at 1000 feet) when it starts raining gliders coming home from the
task at the end of the day...
The final got a bit marginal but he elected for a rolling finish after
going into ground effect on the last few 100 meters, again a valid
procedure for experienced pilots at a competition like this, I have
seen a lot worse... No spectators, cars etc in the way either like
there have been at plenty other competitions...
Markus
Old December 12th 09, 02:51 AM posted to rec.aviation.soaring
Dave Nadler
On Dec 11, 8:20*pm, AGL wrote:
*Our club rule (advice) is that at 1000 agl you're in a
"circuit," or a "pattern" for the chosen field. *Didn't he consider
the other gliders in the normal circuit? *What if there was a student
pilot on solo concentrating on making his first landing while this
joker was sneaking in just over the fence?
This is not your local club.
At championships like this a "normal" pattern is
often FORBIDDEN, because it can be too hazardous
when 100 gliders are finishing and landing in a short time.
When I flew in the Bayreuth pre-worlds, we were
REQUIRED to land straight ahead without pattern...
This does look rather lower than healthy however !
Please do not try this at home,
Old December 12th 09, 04:30 PM posted to rec.aviation.soaring
GARY BOGGS CFIG
I was wondering when the comments were going to start bashing this
guy. One thing I was wondering about is that I didn't hear him
announcing his intentions over the radio. It seems like that would be
a good idea, considering that there were obviously other gliders
landing at the same time. Maybe he announced before the beginning of
the video? He did say something at one point, does anybody know what
he said?
And what the hell was making that rattling noise?
Gary Boggs
Old December 14th 09, 09:07 AM posted to rec.aviation.soaring
jimboffin
On 11 Dec, 21:09, jeplane wrote:
This guy is an idiot.
It's far from showing an example. He is cutting it way too close to
the trees toward the end of the video, as well as only 50 feet
perhaps, above a power line like Tony mentions.
I would be ****ed if I saw anyone doing that at my local airport!....:-
Richard
Phoenix, AZ
Looked like a pretty well judged final glide to me. He had enough
height to put in a 30 degree banked turn prior to landing and
sufficient energy remaining to do a very long ground run to the glider
rigging area. I'll bet if we could see his asi we would see that he
deliberately put it low to increase glide performance over the last
field.
I believe that ground effect final glides of up to 5km have been used
at Nitra in previous contests.
Old December 12th 09, 05:17 PM posted to rec.aviation.soaring
glidergeek
On Dec 10, 10:56*am, vontresc wrote:
A freind of mine sent me this youtube vid today. The pilot hets a wee
bit low during his final glide.
www.youtube.com/watch?v=wZxvYMC2QvI
Enjoy
Pete
Looks like alot of landing options and speed to gain altitude if
needed. Wish the camera was on his instruments at the same time.
Old December 12th 09, 08:38 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Agree. Said 133 KPH or 80 MPH glide speed, lots of nice fields so
that if things went to worms, he had options. And for those worried
about "clearing power lines by only 50 feet of altitude" I can assure
you that if I am going into a short field, I am not going to be 50
feet above obstacles! Yes, it was a close glide, but if you notice,
as he turns the corner onto the field, another glider goes by and also
lands straight ahead in front of him. And his ground roll was 30
seconds. This shows he had a fair amount of energy even at touchdown.
Maybe not the optimum glide in, but it worked.
Old December 13th 09, 02:04 AM posted to rec.aviation.soaring
toad
I liked how he seems to ridge soar the trees along the creek.
Old December 13th 09, 02:19 AM posted to rec.aviation.soaring
jcarlyle
Maybe it's like ridge running. When you first see it you think "this
guy's crazy". When you try it you're 300 feet above the ridge
initially, then as you watch people pass you underneath you move down
to 100 feet. I can't help but think this guy's done this a few times
before!
As for me, I'll definitely pass. I had white knuckles while seated in
my chair, fearing for his safety.
-John
Old December 13th 09, 12:54 AM posted to rec.aviation.soaring
Tim Taylor
Enjoy
Pete
I must be missing something, I don't see the nice fields to land in.
I would expect a ground loop in every field he crossed. The one to
the right of the river is the only one that looks reasonable for the
entire glide.
That said, I have had one final glide like this at the 2006 US
Nationals that was close to this with a forced deviation around power
lines and a hanger to land at 8 pm. The fields under me were better
and I hope to not do that again.
Old December 13th 09, 04:46 AM posted to rec.aviation.soaring
glidergeek
Enjoy
Pete
I would expect a ground loop in every field he crossed. *The one to
entire glide.
lines and a hanger to land at 8 pm. *The fields under me were better
Tim
I didn't say nice fields to land in, I said alot of landing options.
The quality of the camera vs what he was seeing vs what everybody
perceived is vastly different. And it looks like he was rather
committed to either make it to the glider port or commit to a off
field landing. He obviously made the right choice. I'll bet you a six
pack of Fat Tire Beer there were at least that many good land out
fields available to him.
Final Glide - JD (US) Roy Clark, B6 Soaring 1 September 19th 07 07:17 AM
final glide estimates bagmaker Soaring 44 March 16th 06 11:57 PM
AC Williams -Final Glide [email protected] Soaring 4 January 23rd 06 04:52 AM
Final glide Dick Beck Bruce Soaring 0 November 10th 05 08:16 PM
Final Glide for Don Dorrell JJ Sinclair Soaring 2 December 2nd 03 02:56 PM
